[postgis-tickets] [PostGIS] #4712: postgis installer for windows has old proj
trac at osgeo.org
Tue Aug 25 00:54:34 PDT 2020
Reporter: zellner | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS Packaging
Component: postgis | Version: 3.0.x
Resolution: | Keywords: windows
Comment (by zellner):
Step by step I tried 3 zip files to update my PostgreSQL directory using
all subfolders and even the version.txt file downloaded from:
https://winnie.postgis.net/download/windows/pg12/buildbot/
These are the files:
- postgis-pg12-binaries-3.1.0devw64gcc81.zip
- pgrouting-pg12-binaries-developw64gcc81.zip
- pg12pgh3_w64.zip
I always stopped the PostgreSQL service and started it again. At last I
restarted the computer.
There are still shown the old versions:
SELECT version() UNION ALL
SELECT PostGIS_full_version();
PostgreSQL 12.2 on x86_64-pc-linux-gnu, compiled by gcc (GCC) 8.3.1
20190507 (Red Hat 8.3.1-4), 64-bit
POSTGIS="3.0.1 ec2a9aa" [EXTENSION] PGSQL="120" GEOS="3.8.0-CAPI-1.13.1 "
PROJ="6.3.1" LIBXML="2.9.7" LIBJSON="0.13.1" LIBPROTOBUF="1.3.0"
WAGYU="0.4.3 (Internal)"
And the results of ST_Transform(...) are still the wrong ones comparing
"my" PostgreSQL database running on Windows with a Linunx database:
-- (Windows wrong) ---------------------------------
NAV4 POINT(4443865 5506116)
WGS84 POINT(11.22192780146776 49.690197542586986)
NAV4 POINT(4443864.999999998 5506115.999999998)
-- (Linux right) ---------------------------------
WGS84 POINT(11.220567440054587 49.68909694949477)
NAV4 POINT(4443865.000344981 5506116.000483332)
The Linux versions are:
So the problem is not solved. Did I do something wrong when substituting
the sources as described above? Can you test it? You find the test block
in the very first comment in the ticket.
Axel
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4712#comment:7>
