[postgis-tickets] [PostGIS] #4405: Index over ST_Transform(constant, SRID) breaks pg_upgrade
trac at osgeo.org
Tue Aug 11 18:22:52 PDT 2020
Reporter: Algunenano | Owner: Algunenano
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 3.0.3
Component: build/upgrade/install | Version: 2.3.x
Resolution: | Keywords:
Changes (by robe):
* milestone: PostGIS 2.5.5 => PostGIS 3.0.3
Comment:
okay it's still an issue.
I tried upgrading from PostGIS 2.5.5 dev PG 12 to PG 13 PostGIS 2.5.5dev
and got same error
pg_restore: from TOC entry 3507; 1259 54514 INDEX idx_transf postgres
pg_restore: error: could not execute query: ERROR: GetProj4StringSPI:
Cannot find SRID (4326) in spatial_ref_sys
Command was:
-- For binary upgrade, must preserve pg_class oids
SELECT
pg_catalog.binary_upgrade_set_next_index_pg_class_oid('54514'::pg_catalog.oid);
CREATE INDEX "idx_transf" ON "public"."t95" USING "btree"
("public"."st_intersects"("the_geom",
"public"."st_transform"('0101000020E61000000000000000A060C0FAEDEBC0395B4440'::"public"."geometry",
3857)));
you think this is fixable. I haven't tried Proj 6 (this was testing with
Proj 5.2). Seems like such a rare case and we have a workaround (just
drop the index before you pg_upgrade)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4405#comment:6>
