[postgis-tickets] [PostGIS] #4405: Index over ST_Transform(constant, SRID) breaks pg_upgrade
trac at osgeo.org
Mon Aug 17 02:22:46 PDT 2020
Reporter: Algunenano | Owner: Algunenano
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS Fund Me
Component: build/upgrade/install | Version: master
Resolution: | Keywords:
Changes (by Algunenano):
* version: 2.3.x => master
* milestone: PostGIS 3.0.3 => PostGIS Fund Me
Comment:
I don't think this is fixable with our current spatial_ref_sys desisgn. To
fix it in my migrations I've hardcoded the necessary SRID transformation
strings inside Postgis, but that isn't a proper solution.
I think that ideally we would have a set of static SRIDs inside
Postgis/PROJ (independent of spatial_ref_sys) that can't be modified by
the end user and then allow having other SRIDS (as long as they don't
collide with the static ones). This would mean a major change which I'm
not sure we want to tackle.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4405#comment:7>
