[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-58-gb9c792c
git at osgeo.org
git at osgeo.org
Tue Aug 18 07:37:15 PDT 2020
the project "PostGIS".
via b9c792ce1a9873b80f03362feab7e3795805f09d (commit)
from c0d947e005e67e8b36a3f0b2d997229782c356c5 (commit)
revisions in full, below.
commit b9c792ce1a9873b80f03362feab7e3795805f09d
Author: Raúl Marín <git at rmr.ninja>
Date: Tue Aug 18 15:22:15 2020 +0200
Travis: Use the latest Docker
I updated the images with the latest PG minor releases and
Travis is having issues running them. With this we make sure
it's running the latest stable release of Docker
diff --git a/.travis.yml b/.travis.yml
index 7e0a658..71a34f5 100644
--- a/.travis.yml
+++ b/.travis.yml
@@ -30,6 +30,12 @@ matrix:
- pip install flake8 # lint Python code for syntax errors
- flake8 . --count --select=E9,F63,F72,F82 --show-source --statistics
+before_install:
+ - curl -fsSL https://download.docker.com/linux/ubuntu/gpg | sudo apt-key add -
+ - sudo add-apt-repository "deb [arch=amd64] https://download.docker.com/linux/ubuntu $(lsb_release -cs) stable"
+ - sudo apt-get update
+ - sudo apt-get -y -o Dpkg::Options::="--force-confnew" install docker-ce
script:
- echo "/tmp/logbt-coredumps/core.%p.%E" | sudo tee /proc/sys/kernel/core_pattern
- echo "FROM postgis/postgis-build-env:${tag}" > Dockerfile
Summary of changes:
.travis.yml | 6 ++++++
1 file changed, 6 insertions(+)
hooks/post-receive
