[postgis-tickets] [PostGIS] #4744: St_AsMVT Errors on Some Polygons with Inner Rings
trac at osgeo.org
Tue Aug 18 08:18:07 PDT 2020
Reporter: reyemtm | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.0
Component: postgis | Version: 3.0.x
Keywords: vector tiles |
This is possibly related to issue #3712. I have an impervious surface
layer which is a multipolygon layer with many inner rings. Above zoom
level 18, so 0-17, the "holes" get filled in using Mapbox GL JS, while the
GeoJSON export of this layer when used directly draws with minimal
artifacts. It would seem like this is due to simplification, not sure. I
did try to use the ST_AsMVT(ST_MakeValid(geom)) but that did nothing.
For an example picture see the issue I made on the pg_tileserv repo -
https://github.com/CrunchyData/pg_tileserv/issues/48. This has a link to
the GeoJSON data as well.
If there is anything I should try or other tricks let me know.
Thanks
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4744>
