[postgis-tickets] [PostGIS] #4744: St_AsMVT Errors on Some Polygons with Inner Rings
PostGIS trac at osgeo.org
Tue Aug 18 10:45:22 PDT 2020
  Reporter:  reyemtm  |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 3.1.0
 Component:  postgis  |    Version:  3.0.x
Resolution:           |   Keywords:  vector tiles
Comment (by Algunenano):
 Can you share the exact Postgis version the server is running (as in
 postgis_full_version) and the exact call and input for
 ST_AsMVT/ST_AsMVTGeom? Otherwise this requires mindless tests to try to
 reproduce your setup.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4744#comment:1>
