[postgis-tickets] [SCM] PostGIS branch stable-2.5 updated. 2.5.5-3-g15700cf
git at osgeo.org
git at osgeo.org
Tue Aug 18 09:48:59 PDT 2020
the project "PostGIS".
The branch, stable-2.5 has been updated
via 15700cf4312c446cfd2d2ff448795850f53fe5eb (commit)
from 348793a33c1660ba1c30cf7448454abf5ffc65f9 (commit)
revisions in full, below.
commit 15700cf4312c446cfd2d2ff448795850f53fe5eb
Author: Regina Obe <lr at pcorp.us>
Date: Tue Aug 18 12:48:48 2020 -0400
More version fixes for windows
diff --git a/ci/winnie/package_postgis.sh b/ci/winnie/package_postgis.sh
index c98014a..325dacd 100644
--- a/ci/winnie/package_postgis.sh
+++ b/ci/winnie/package_postgis.sh
@@ -120,8 +120,7 @@ export REL_PGVER=${PG_VER//./} #strip the period
export RELDIR=${PROJECTS}/postgis/builds/${POSTGIS_MINOR_VER}
export RELVERDIR=postgis-pg${REL_PGVER}-binaries-${POSTGIS_MINOR_VER}.${POSTGIS_MICRO_VERSION}w${OS_BUILD}${GCC_TYPE}
export PATH="${PATHOLD}:${PGPATH}/bin:${PGPATH}/lib"
-export PCRE_VER=8.33 #PATH="${PGPATH}/bin:${PGPATH}/lib:${MINGPROJECTS}/xsltproc:${MINGPROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gtkw${OS_BUILD}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/include:${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/bin:${PATH}"
-#echo PATH AFTER: $PATH
+export PCRE_VER=8.33
outdir="${RELDIR}/${RELVERDIR}"
package="${RELDIR}/${RELVERDIR}.zip"
verfile="${RELDIR}/${RELVERDIR}/version.txt"
@@ -138,15 +137,15 @@ mkdir $outdir/bin/postgisgui
mkdir $outdir/bin/postgisgui/share
mkdir $outdir/bin/postgisgui/lib
mkdir $outdir/utils
-cp ${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}/bin/*.dll $outdir/bin/postgisgui
+cp ${MINGPROJECTS}/rel-libiconv-${ICONV_VER}w${OS_BUILD}/bin/*.dll $outdir/bin/postgisgui
# it seems 9.2 and 9.3 doesn't come with its own libiconv good grief
# and trying to use their libiconv2.dll makes shp2pgsql crash
if [[ "$PG_VER" == *9.2* || "$PG_VER" == *9.3* ]]; then
- cp ${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/bin/*.dll $outdir/bin
+ cp ${MINGPROJECTS}/rel-libiconv-${ICONV_VER}w${OS_BUILD}${GCC_TYPE}/bin/*.dll $outdir/bin
fi;
cp ${PGPATHEDB}/bin/libpq.dll $outdir/bin/postgisgui
#cp ${PGPATHEDB}/bin/libiconv2.dll $outdir/bin/postgisgui
-cp ${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/bin/libicon*.dll $outdir/bin/postgisgui
+cp ${MINGPROJECTS}/rel-libiconv-${ICONV_VER}w${OS_BUILD}${GCC_TYPE}/bin/libicon*.dll $outdir/bin/postgisgui
cp ${PGPATHEDB}/bin/libintl*.dll $outdir/bin/postgisgui
cp ${PGPATHEDB}/bin/ssleay32.dll $outdir/bin/postgisgui
@@ -174,7 +173,7 @@ cp -p ${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin/*.dll $outdir/
#for protobuf
cp ${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/bin/libprotobuf-c-*.dll $outdir/bin
-echo "POSTGIS: ${POSTGIS_MINOR_VER} r${POSTGIS_SVN_REVISION} http://postgis.net/source" > $verfile
+echo "POSTGIS: ${POSTGIS_MINOR_VER} r${POSTGIS_SVN_REVISION} https://postgis.net/source" > $verfile
if [ "$POSTGIS_MAJOR_VERSION" == "2" ] ; then
## only copy gdal components if 2+. 1.5 doesn't have raster support
diff --git a/ci/winnie/regress_postgis.sh b/ci/winnie/regress_postgis.sh
index cc4d201..7d4ab4b 100644
--- a/ci/winnie/regress_postgis.sh
+++ b/ci/winnie/regress_postgis.sh
@@ -102,7 +102,7 @@ export RELVERDIR=postgis-pg${REL_PGVER}-binaries-${POSTGIS_MICRO_VER}w${OS_BUILD
#PATH="${MINGPROJECTS}/gettext/rel-gettext-0.18.1/bin:${MINGPROJECTS}/xsltproc:${MINGPROJECTS}/gtk/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}/bin:${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}/include:${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}/bin:${MINGPROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}/bin:${MINGPROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}/bin:${PATH}"
-PATH="${MINGPROJECTS}/xsltproc:${MINGPROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/rel-libiconv-${ICONV_VER}w${OS_BUILD}${GCC_TYPE}/lib:${MINGPROJECTS}/rel-libiconv-${ICONV_VER}w${OS_BUILD}${GCC_TYPE}/include:${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PATH}"
+PATH="${MINGPROJECTS}/xsltproc:${MINGPROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/rel-libiconv-${ICONV_VER}w${OS_BUILD}${GCC_TYPE}/lib:${MINGPROJECTS}/rel-libiconv-${ICONV_VER}w${OS_BUILD}${GCC_TYPE}/include:${MINGPROJECTS}/rel-libiconv-${ICONV_VER}w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PATH}"
#add protobuf
export PATH="${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
@@ -159,7 +159,7 @@ LDFLAGS="-L${PGPATH}/lib -L${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYP
--without-interrupt-tests \
--prefix=${PROJECTS}/postgis/liblwgeom-${POSTGIS_VER}w${OS_BUILD}${GCC_TYPE}
else
-CPPFLAGS="-I${PGPATH}/include -I${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/include" \
+CPPFLAGS="-I${PGPATH}/include -I${MINGPROJECTS}/rel-libiconv-${ICONV_VER}w${OS_BUILD}${GCC_TYPE}/include" \
CFLAGS="-Wall -fno-omit-frame-pointer" \
LDFLAGS="-L${PGPATH}/lib -L${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib -L${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/lib" ./configure \
--host=${MINGHOST} --with-xml2config=${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin/xml2-config \
@@ -170,7 +170,7 @@ LDFLAGS="-L${PGPATH}/lib -L${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYP
--with-gui --with-gettext=no \
--with-protobufdir=${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE} \
--with-jsondir=${MINGPROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE} \
- --with-libiconv=${PROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE} \
+ --with-libiconv=${PROJECTS}/rel-libiconv-${ICONV_VER}w${OS_BUILD}${GCC_TYPE} \
--with-xsldir=${PROJECTS}/docbook/docbook-xsl-1.76.1 \
Summary of changes:
ci/winnie/package_postgis.sh | 11 +++++------
ci/winnie/regress_postgis.sh | 6 +++---
2 files changed, 8 insertions(+), 9 deletions(-)
hooks/post-receive
