[postgis-tickets] [PostGIS] #4745: Possible problem with new version 2.5.5
PostGIS trac at osgeo.org
Wed Aug 19 08:02:04 PDT 2020
 Reporter:  ezimanyi  |      Owner:  pramsey
     Type:  defect    |     Status:  new
 Priority:  medium    |  Milestone:  PostGIS 3.1.0
Component:  postgis   |    Version:  2.5.x
 Keywords:            |
 It could be the case that there is a problem with the new version 2.5.5.
 Since yesterday we have had problems making our tests work.
 After many trials we made a fork of a commit 4e510dc that worked before
 https://github.com/MobilityDB/MobilityDB/commits/develop
 but it is no longer the case in my local repository
 In particular we have this error
 SELECT round(azimuth(temp), 12) FROM tbl_tgeogpoint3D WHERE azimuth(temp)
 IS NOT NULL LIMIT 10;
 ERROR:  syntax error at or near "null"
 LINE 1: ...ECT proj4text, auth_name, auth_srid, srtext FROM (null) WHER...
 QUERY:  SELECT proj4text, auth_name, auth_srid, srtext FROM (null) WHERE
 srid = 4326 LIMIT 1
 Could you please take a look ?
 Many thanks for your help
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4745>
