[postgis-tickets] [PostGIS] #4732: long planning time
trac at osgeo.org
Wed Aug 19 01:22:41 PDT 2020
Reporter: michal | Owner: pramsey
Type: enhancement | Status: closed
Priority: low | Milestone: PostGIS 3.1.0
Component: postgis | Version: 3.0.x
Resolution: wontfix | Keywords:
Comment (by michal):
just to understand: the most expensive step is to calculate perfectly
round buffer around the point, which is calculated in the planning time
(and not execution time).
but then execution is significantly higher in the case of pre-calculated
buffer than the st_buffer buffer.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4732#comment:5>
