[postgis-tickets] [PostGIS] #4732: long planning time
trac at osgeo.org
Wed Aug 19 01:31:41 PDT 2020
Reporter: michal | Owner: pramsey
Type: enhancement | Status: closed
Priority: low | Milestone: PostGIS 3.1.0
Component: postgis | Version: 3.0.x
Resolution: wontfix | Keywords:
Comment (by Algunenano):
> just to understand: the most expensive step is to calculate perfectly
round buffer around the point, which is calculated in the planning time
(and not execution time).
No, the most expensive step is to convert the geography to the best SRS as
this requires initializing PROJ. Once you have the best SRS, generating
the buffer is really fast.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4732#comment:6>
