[postgis-tickets] [PostGIS] #4744: St_AsMVT Errors on Some Polygons with Inner Rings
trac at osgeo.org
Wed Aug 19 06:54:02 PDT 2020
Reporter: reyemtm | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.0
Component: postgis | Version: 3.0.x
Resolution: | Keywords: vector tiles
Comment (by Algunenano):
I've loaded the dataset into CartoVL (based on MapboxGL) and there are
some issues (lines across the polygons) in certain places, but when loaded
individually in QGIS the tiles are ok. They are also ok when analyzed
individually under node-mapnik.
I'm inclined to think this could be a problem during the stitching of the
polygons (there is nothing in the spec/format to make that easier) but I'm
not 100% certain about it and right now I don't have an easy way to test
with other renderers.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4744#comment:8>
