[postgis-tickets] [PostGIS] #4744: St_AsMVT Errors on Some Polygons with Inner Rings
trac at osgeo.org
Wed Aug 19 07:07:09 PDT 2020
Reporter: reyemtm | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.0
Component: postgis | Version: 3.0.x
Resolution: | Keywords: vector tiles
Comment (by Algunenano):
I've done some more tests changing how big is the buffer around the tiles
and it does indeed look like a stiching issue.
Using a extent of 4096:
- Buffer of 0: Lots of artifacts when stitching across tile boundaries.
- Buffer of 4096/256 = 16 (the smallest one in CARTO): No artifacts at all
- Buffer of 256 (Postgis Defaults): Ocasional artifacts (less than with
buffer 0)
Note that CartoVL by default uses extent / 256 as the buffer for
historical reasons (from the time a tile was 256x256 pixels) but it could
probably be smaller.
Can you give a try to one of those services with a smaller extent and see
if that makes your issues go away? They are changed in ST_AsMVTGeom and I
from experience I would recommend it to be as small as possible (the
extent / 256 seems to be working well for us).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4744#comment:9>
