[postgis-tickets] [PostGIS] #3687: Add casts for (geometry, geography) -> (json, jsonb)
trac at osgeo.org
Wed Aug 19 12:55:18 PDT 2020
Reporter: dbaston | Owner: dbaston
Type: enhancement | Status: closed
Priority: medium | Milestone: PostGIS 3.0.0
Component: postgis | Version: master
Resolution: fixed | Keywords:
Comment (by jawj):
Is there a reason not also to add the reverse casts?
I've found the following manual additions helpful:
CREATE CAST (json AS geometry) WITH FUNCTION ST_GeomFromGeoJSON(json) AS
ASSIGNMENT;
CREATE CAST (jsonb AS geometry) WITH FUNCTION ST_GeomFromGeoJSON(jsonb) AS
ASSIGNMENT;
So that I can insert JSON values back in to a table.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3687#comment:9>
