[postgis-tickets] [PostGIS] #4745: Possible problem with new version 2.5.5
trac at osgeo.org
Fri Aug 21 01:45:05 PDT 2020
Reporter: ezimanyi | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.5.6
Component: postgis | Version: 2.5.x
Resolution: wontfix | Keywords:
Changes (by Algunenano):
* status: new => closed
* resolution: => wontfix
Comment:
MobilityDB is depending on Postgis' C functions, which is certainly not
supported.
In #4461 I fixed a bug when accessing `spatial_ref_sys` in some
circunstances, but it relies on the fact that the table will be installed
in the same schema as the function being called. This also means that the
C function `FunctionCallInfo fcinfo` needs to be properly populated (check
if the `call_functionN` functions do that).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4745#comment:2>
