[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-62-g3d049c8
Fri Aug 21 04:38:49 PDT 2020
the project "PostGIS".
       via  3d049c8ef29297fb3473b5df4f24f7edb5fc34f9 (commit)
      from  6ae7988e4def3c64c4b5c0f1d7cb2f6ed70b65f7 (commit)
revisions in full, below.
commit 3d049c8ef29297fb3473b5df4f24f7edb5fc34f9
Author: Raúl Marín <git at rmr.ninja>
Date:   Fri Aug 21 13:37:54 2020 +0200
    Micro optimizations to the serialization process
    Closes #4746
    Closes https://github.com/postgis/postgis/pull/577
diff --git a/NEWS b/NEWS
index 68365de..895a11a 100644
--- a/NEWS
+++ b/NEWS
@@ -29,6 +29,7 @@ Only tickets not included in 3.1.0alpha2
            Documentation adjusted (Darafei Praliaskouski)
   - #4737, Improve performance and reduce memory usage in ST_AsMVT, especially in
            queries involving parallelism (Raúl Marín)
+  - #4746, Micro optimizations to the serialization process (Raúl Marín)
 * Bug fixes *
   - #4691, Fix segfault during gist index creation with empty geometries (Raúl Marín)
diff --git a/liblwgeom/gserialized2.c b/liblwgeom/gserialized2.c
index f141157..353c107 100644
--- a/liblwgeom/gserialized2.c
+++ b/liblwgeom/gserialized2.c
@@ -684,6 +684,7 @@ static size_t gserialized2_from_lwpoly_size(const LWPOLY *poly)
 	size_t size = 4; /* Type number. */
 	uint32_t i = 0;
+	const size_t point_size = FLAGS_NDIMS(poly->flags) * sizeof(double);
 	assert(poly);
@@ -694,7 +695,7 @@ static size_t gserialized2_from_lwpoly_size(const LWPOLY *poly)
 	for (i = 0; i < poly->nrings; i++)
 		size += 4; /* Number of points in ring. */
-		size += poly->rings[i]->npoints * FLAGS_NDIMS(poly->flags) * sizeof(double);
+		size += poly->rings[i]->npoints * point_size;
 	LWDEBUGF(3, "polygon size = %d", size);
@@ -1098,36 +1099,24 @@ static size_t gserialized2_from_extended_flags(lwflags_t lwflags, uint8_t *buf)
 static size_t gserialized2_from_gbox(const GBOX *gbox, uint8_t *buf)
 	uint8_t *loc = buf;
-	float f;
+	float *f;
+	uint8_t i = 0;
 	size_t return_size;
 	assert(buf);
-	f = next_float_down(gbox->xmin);
-	memcpy(loc, &f, sizeof(float));
-	loc += sizeof(float);
-	f = next_float_up(gbox->xmax);
-	f = next_float_down(gbox->ymin);
-	f = next_float_up(gbox->ymax);
+	f = (float *)buf;
+	f[i++] = next_float_down(gbox->xmin);
+	f[i++] = next_float_up(gbox->xmax);
+	f[i++] = next_float_down(gbox->ymin);
+	f[i++] = next_float_up(gbox->ymax);
+	loc += 4 * sizeof(float);
 	if (FLAGS_GET_GEODETIC(gbox->flags))
-		f = next_float_down(gbox->zmin);
-		f = next_float_up(gbox->zmax);
+		f[i++] = next_float_down(gbox->zmin);
+		f[i++] = next_float_up(gbox->zmax);
+		loc += 2 * sizeof(float);
 		return_size = (size_t)(loc - buf);
 		LWDEBUGF(4, "returning size %d", return_size);
@@ -1136,25 +1125,16 @@ static size_t gserialized2_from_gbox(const GBOX *gbox, uint8_t *buf)
 	if (FLAGS_GET_Z(gbox->flags))
 	if (FLAGS_GET_M(gbox->flags))
-		f = next_float_down(gbox->mmin);
-		f = next_float_up(gbox->mmax);
+		f[i++] = next_float_down(gbox->mmin);
+		f[i++] = next_float_up(gbox->mmax);
@@ -1214,12 +1194,7 @@ GSERIALIZED* gserialized2_from_lwgeom(LWGEOM *geom, size_t *size)
 	/* Calculate size as returned by data processing functions. */
 	return_size = ptr - (uint8_t*)g;
-	if (expected_size != return_size) /* Uh oh! */
-		lwerror("Return size (%lu) not equal to expected size (%lu)!", return_size, expected_size);
-		return NULL;
+	assert(expected_size == return_size);
 	if (size) /* Return the output size to the caller if necessary. */
 		*size = return_size;
@@ -1232,9 +1207,10 @@ GSERIALIZED* gserialized2_from_lwgeom(LWGEOM *geom, size_t *size)
 * De-serialize GSERIALIZED into an LWGEOM.
-static LWGEOM* lwgeom_from_gserialized2_buffer(uint8_t *data_ptr, lwflags_t lwflags, size_t *size);
+static LWGEOM *lwgeom_from_gserialized2_buffer(uint8_t *data_ptr, lwflags_t lwflags, size_t *size, int32_t srid);
-static LWPOINT* lwpoint_from_gserialized2_buffer(uint8_t *data_ptr, lwflags_t lwflags, size_t *size)
+static LWPOINT *
+lwpoint_from_gserialized2_buffer(uint8_t *data_ptr, lwflags_t lwflags, size_t *size, int32_t srid)
 	uint8_t *start_ptr = data_ptr;
 	LWPOINT *point;
@@ -1243,7 +1219,7 @@ static LWPOINT* lwpoint_from_gserialized2_buffer(uint8_t *data_ptr, lwflags_t lw
 	assert(data_ptr);
 	point = (LWPOINT*)lwalloc(sizeof(LWPOINT));
-	point->srid = SRID_UNKNOWN; /* Default */
+	point->srid = srid;
 	point->bbox = NULL;
 	point->type = POINTTYPE;
 	point->flags = lwflags;
@@ -1265,7 +1241,8 @@ static LWPOINT* lwpoint_from_gserialized2_buffer(uint8_t *data_ptr, lwflags_t lw
 	return point;
-static LWLINE* lwline_from_gserialized2_buffer(uint8_t *data_ptr, lwflags_t lwflags, size_t *size)
+static LWLINE *
+lwline_from_gserialized2_buffer(uint8_t *data_ptr, lwflags_t lwflags, size_t *size, int32_t srid)
 	LWLINE *line;
@@ -1274,7 +1251,7 @@ static LWLINE* lwline_from_gserialized2_buffer(uint8_t *data_ptr, lwflags_t lwfl
 	assert(data_ptr);
 	line = (LWLINE*)lwalloc(sizeof(LWLINE));
-	line->srid = SRID_UNKNOWN; /* Default */
+	line->srid = srid;
 	line->bbox = NULL;
 	line->type = LINETYPE;
 	line->flags = lwflags;
@@ -1297,7 +1274,8 @@ static LWLINE* lwline_from_gserialized2_buffer(uint8_t *data_ptr, lwflags_t lwfl
 	return line;
-static LWPOLY* lwpoly_from_gserialized2_buffer(uint8_t *data_ptr, lwflags_t lwflags, size_t *size)
+static LWPOLY *
+lwpoly_from_gserialized2_buffer(uint8_t *data_ptr, lwflags_t lwflags, size_t *size, int32_t srid)
 	LWPOLY *poly;
@@ -1308,7 +1286,7 @@ static LWPOLY* lwpoly_from_gserialized2_buffer(uint8_t *data_ptr, lwflags_t lwfl
 	assert(data_ptr);
 	poly = (LWPOLY*)lwalloc(sizeof(LWPOLY));
-	poly->srid = SRID_UNKNOWN; /* Default */
+	poly->srid = srid;
 	poly->bbox = NULL;
 	poly->type = POLYGONTYPE;
 	poly->flags = lwflags;
@@ -1354,7 +1332,8 @@ static LWPOLY* lwpoly_from_gserialized2_buffer(uint8_t *data_ptr, lwflags_t lwfl
 	return poly;
-static LWTRIANGLE* lwtriangle_from_gserialized2_buffer(uint8_t *data_ptr, lwflags_t lwflags, size_t *size)
+static LWTRIANGLE *
+lwtriangle_from_gserialized2_buffer(uint8_t *data_ptr, lwflags_t lwflags, size_t *size, int32_t srid)
 	LWTRIANGLE *triangle;
@@ -1363,7 +1342,7 @@ static LWTRIANGLE* lwtriangle_from_gserialized2_buffer(uint8_t *data_ptr, lwflag
 	assert(data_ptr);
 	triangle = (LWTRIANGLE*)lwalloc(sizeof(LWTRIANGLE));
-	triangle->srid = SRID_UNKNOWN; /* Default */
+	triangle->srid = srid; /* Default */
 	triangle->bbox = NULL;
 	triangle->type = TRIANGLETYPE;
 	triangle->flags = lwflags;
@@ -1385,7 +1364,8 @@ static LWTRIANGLE* lwtriangle_from_gserialized2_buffer(uint8_t *data_ptr, lwflag
 	return triangle;
-static LWCIRCSTRING* lwcircstring_from_gserialized2_buffer(uint8_t *data_ptr, lwflags_t lwflags, size_t *size)
+static LWCIRCSTRING *
+lwcircstring_from_gserialized2_buffer(uint8_t *data_ptr, lwflags_t lwflags, size_t *size, int32_t srid)
 	LWCIRCSTRING *circstring;
@@ -1394,7 +1374,7 @@ static LWCIRCSTRING* lwcircstring_from_gserialized2_buffer(uint8_t *data_ptr, lw
 	assert(data_ptr);
 	circstring = (LWCIRCSTRING*)lwalloc(sizeof(LWCIRCSTRING));
-	circstring->srid = SRID_UNKNOWN; /* Default */
+	circstring->srid = srid;
 	circstring->bbox = NULL;
 	circstring->type = CIRCSTRINGTYPE;
 	circstring->flags = lwflags;
@@ -1416,7 +1396,8 @@ static LWCIRCSTRING* lwcircstring_from_gserialized2_buffer(uint8_t *data_ptr, lw
 	return circstring;
-static LWCOLLECTION* lwcollection_from_gserialized2_buffer(uint8_t *data_ptr, lwflags_t lwflags, size_t *size)
+static LWCOLLECTION *
+lwcollection_from_gserialized2_buffer(uint8_t *data_ptr, lwflags_t lwflags, size_t *size, int32_t srid)
 	uint32_t type;
@@ -1430,7 +1411,7 @@ static LWCOLLECTION* lwcollection_from_gserialized2_buffer(uint8_t *data_ptr, lw
 	data_ptr += 4; /* Skip past the type. */
 	collection = (LWCOLLECTION*)lwalloc(sizeof(LWCOLLECTION));
-	collection->srid = SRID_UNKNOWN; /* Default */
+	collection->srid = srid;
 	collection->bbox = NULL;
 	collection->type = type;
 	collection->flags = lwflags;
@@ -1464,7 +1445,7 @@ static LWCOLLECTION* lwcollection_from_gserialized2_buffer(uint8_t *data_ptr, lw
 			lwfree(collection);
 			return NULL;
-		collection->geoms[i] = lwgeom_from_gserialized2_buffer(data_ptr, lwflags, &subsize);
+		collection->geoms[i] = lwgeom_from_gserialized2_buffer(data_ptr, lwflags, &subsize, srid);
 		data_ptr += subsize;
@@ -1474,7 +1455,8 @@ static LWCOLLECTION* lwcollection_from_gserialized2_buffer(uint8_t *data_ptr, lw
 	return collection;
-LWGEOM* lwgeom_from_gserialized2_buffer(uint8_t *data_ptr, lwflags_t lwflags, size_t *g_size)
+LWGEOM *
+lwgeom_from_gserialized2_buffer(uint8_t *data_ptr, lwflags_t lwflags, size_t *g_size, int32_t srid)
 	uint32_t type;
@@ -1488,15 +1470,15 @@ LWGEOM* lwgeom_from_gserialized2_buffer(uint8_t *data_ptr, lwflags_t lwflags, si
 	switch (type)
 	case POINTTYPE:
-		return (LWGEOM *)lwpoint_from_gserialized2_buffer(data_ptr, lwflags, g_size);
+		return (LWGEOM *)lwpoint_from_gserialized2_buffer(data_ptr, lwflags, g_size, srid);
 	case LINETYPE:
-		return (LWGEOM *)lwline_from_gserialized2_buffer(data_ptr, lwflags, g_size);
+		return (LWGEOM *)lwline_from_gserialized2_buffer(data_ptr, lwflags, g_size, srid);
 	case CIRCSTRINGTYPE:
-		return (LWGEOM *)lwcircstring_from_gserialized2_buffer(data_ptr, lwflags, g_size);
+		return (LWGEOM *)lwcircstring_from_gserialized2_buffer(data_ptr, lwflags, g_size, srid);
 	case POLYGONTYPE:
-		return (LWGEOM *)lwpoly_from_gserialized2_buffer(data_ptr, lwflags, g_size);
+		return (LWGEOM *)lwpoly_from_gserialized2_buffer(data_ptr, lwflags, g_size, srid);
 	case TRIANGLETYPE:
-		return (LWGEOM *)lwtriangle_from_gserialized2_buffer(data_ptr, lwflags, g_size);
+		return (LWGEOM *)lwtriangle_from_gserialized2_buffer(data_ptr, lwflags, g_size, srid);
 	case MULTIPOINTTYPE:
 	case MULTILINETYPE:
 	case MULTIPOLYGONTYPE:
@@ -1507,7 +1489,7 @@ LWGEOM* lwgeom_from_gserialized2_buffer(uint8_t *data_ptr, lwflags_t lwflags, si
 	case POLYHEDRALSURFACETYPE:
 	case TINTYPE:
 	case COLLECTIONTYPE:
-		return (LWGEOM *)lwcollection_from_gserialized2_buffer(data_ptr, lwflags, g_size);
+		return (LWGEOM *)lwcollection_from_gserialized2_buffer(data_ptr, lwflags, g_size, srid);
 	default:
 		lwerror("Unknown geometry type: %d - %s", type, lwtype_name(type));
 		return NULL;
@@ -1544,7 +1526,7 @@ LWGEOM* lwgeom_from_gserialized2(const GSERIALIZED *g)
 	if (FLAGS_GET_BBOX(lwflags))
 		data_ptr += gbox_serialized_size(lwflags);
-	lwgeom = lwgeom_from_gserialized2_buffer(data_ptr, lwflags, &size);
+	lwgeom = lwgeom_from_gserialized2_buffer(data_ptr, lwflags, &size, srid);
 	if (!lwgeom)
 		lwerror("%s: unable create geometry", __func__); /* Ooops! */
@@ -1565,8 +1547,6 @@ LWGEOM* lwgeom_from_gserialized2(const GSERIALIZED *g)
 		lwgeom->bbox = NULL;
-	lwgeom_set_srid(lwgeom, srid);
 	return lwgeom;
diff --git a/libpgcommon/lwgeom_pg.c b/libpgcommon/lwgeom_pg.c
index aecc38a..4dbaa76 100644
--- a/libpgcommon/lwgeom_pg.c
+++ b/libpgcommon/lwgeom_pg.c
@@ -214,11 +214,6 @@ pg_alloc(size_t size)
 	POSTGIS_DEBUGF(5, "  pg_alloc(%d) returning %p", (int)size, result);
-	if ( ! result )
-		ereport(ERROR, (errmsg_internal("Out of virtual memory")));
-		return NULL;
 	return result;
@@ -309,13 +304,12 @@ pg_install_lwgeom_handlers(void)
 GSERIALIZED* geography_serialize(LWGEOM *lwgeom)
-	size_t ret_size = 0;
-	GSERIALIZED *g = NULL;
+	size_t ret_size;
+	GSERIALIZED *g;
 	/** force to geodetic in case it's not **/
 	lwgeom_set_geodetic(lwgeom, true);
 	g = gserialized_from_lwgeom(lwgeom,  &ret_size);
-	if ( ! g ) lwpgerror("Unable to serialize lwgeom.");
 	SET_VARSIZE(g, ret_size);
 	return g;
@@ -327,11 +321,10 @@ GSERIALIZED* geography_serialize(LWGEOM *lwgeom)
 GSERIALIZED* geometry_serialize(LWGEOM *lwgeom)
+	size_t ret_size;
+	GSERIALIZED *g;
 	return g;
diff --git a/postgis/lwgeom_functions_basic.c b/postgis/lwgeom_functions_basic.c
index 1ed7942..369ea1e 100644
--- a/postgis/lwgeom_functions_basic.c
+++ b/postgis/lwgeom_functions_basic.c
@@ -1923,8 +1923,6 @@ Datum LWGEOM_noop(PG_FUNCTION_ARGS)
 	GSERIALIZED *in = PG_GETARG_GSERIALIZED_P(0);
 	LWGEOM *lwgeom = lwgeom_from_gserialized(in);
 	GSERIALIZED *out = geometry_serialize(lwgeom);
-	lwgeom_free(lwgeom);
-	PG_FREE_IF_COPY(in, 0);
 	PG_RETURN_POINTER(out);
Summary of changes:
 NEWS                             |   1 +
 liblwgeom/gserialized2.c         | 118 ++++++++++++++++-----------------------
 libpgcommon/lwgeom_pg.c          |  15 ++---
 postgis/lwgeom_functions_basic.c |   2 -
 4 files changed, 54 insertions(+), 82 deletions(-)
hooks/post-receive
