[postgis-tickets] [SCM] PostGIS branch stable-3.0 updated. 3.0.2-5-gd405770
git at osgeo.org
git at osgeo.org
Fri Aug 21 06:19:21 PDT 2020
the project "PostGIS".
The branch, stable-3.0 has been updated
via d4057706afab0d9cb54448bb05152e33b855c4eb (commit)
from 11846bd1f7bf5df07b6919d0ebba0aacc45d82f1 (commit)
revisions in full, below.
commit d4057706afab0d9cb54448bb05152e33b855c4eb
Author: Raúl Marín <git at rmr.ninja>
Date: Tue Aug 18 15:22:15 2020 +0200
Travis: Use the latest Docker
I updated the images with the latest PG minor releases and
Travis is having issues running them. With this we make sure
it's running the latest stable release of Docker
Also, update clang reference to clang 9 (for the ASAN build)
diff --git a/.travis.yml b/.travis.yml
index dff4442..725d230 100644
--- a/.travis.yml
+++ b/.travis.yml
@@ -30,6 +30,12 @@ matrix:
- pip install flake8 # lint Python code for syntax errors
- flake8 . --count --select=E9,F63,F72,F82 --show-source --statistics
+before_install:
+ - curl -fsSL https://download.docker.com/linux/ubuntu/gpg | sudo apt-key add -
+ - sudo add-apt-repository "deb [arch=amd64] https://download.docker.com/linux/ubuntu $(lsb_release -cs) stable"
+ - sudo apt-get update
+ - sudo apt-get -y -o Dpkg::Options::="--force-confnew" install docker-ce
script:
- echo "/tmp/logbt-coredumps/core.%p.%E" | sudo tee /proc/sys/kernel/core_pattern
- echo "FROM postgis/postgis-build-env:${tag}" > Dockerfile
diff --git a/ci/travis/run_usan_clang.sh b/ci/travis/run_usan_clang.sh
index a3126ac..515176f 100644
--- a/ci/travis/run_usan_clang.sh
+++ b/ci/travis/run_usan_clang.sh
@@ -10,7 +10,7 @@ export ASAN_OPTIONS=halt_on_error=false,leak_check_at_exit=false,exitcode=0
export MSAN_OPTIONS=halt_on_error=false,leak_check_at_exit=false,exitcode=0
#Run postgres preloading sanitizer libs
-LD_PRELOAD=/usr/lib/clang/8/lib/linux/libclang_rt.asan-x86_64.so /usr/local/pgsql/bin/pg_ctl -c -l /tmp/logfile start
+LD_PRELOAD=/usr/lib/clang/9/lib/linux/libclang_rt.asan-x86_64.so /usr/local/pgsql/bin/pg_ctl -c -l /tmp/logfile start
# Build with Clang and usan flags
Summary of changes:
.travis.yml | 6 ++++++
ci/travis/run_usan_clang.sh | 2 +-
2 files changed, 7 insertions(+), 1 deletion(-)
hooks/post-receive
