[postgis-tickets] [PostGIS] #4747: Re: [PostGIS] #4745: Possible problem with new version 2.5.5
PostGIS trac at osgeo.org
Sat Aug 22 10:25:53 PDT 2020
 Reporter:  ezimanyi  |      Owner:  pramsey
     Type:  defect    |     Status:  new
 Priority:  medium    |  Milestone:  PostGIS 3.1.0
Component:  postgis   |    Version:  2.5.x
 Keywords:            |
 Dear all
 Since none of the functions
 void postgis_initialize_cache(FunctionCallInfo fcinfo)
 const char *postgis_spatial_ref_sys()
 defined in the file lwgeom_pg.c are exported, could you please instruct
 how to solve this issue when using call_function2 for calling the PostGIS
 external function transform(PG_FUNCTION_ARGS)?
 If this help, here is a trace to follow the function calls
 Program received signal SIGSEGV, Segmentation fault.
 __strlen_avx2 () at ../sysdeps/x86_64/multiarch/strlen-avx2.S:65
 65      ../sysdeps/x86_64/multiarch/strlen-avx2.S: No such file or
 directory.
 (gdb) bt
 #0  __strlen_avx2 () at ../sysdeps/x86_64/multiarch/strlen-avx2.S:65
 #1  0x0000556088b94ef2 in dopr (target=target at entry=0x7ffe815b9e50,
 format=0x7fb348b5b036 " WHERE srid = %d LIMIT 1",
     args=0x7ffe815b9ea0) at snprintf.c:443
 #2  0x0000556088b95d6f in pg_vsnprintf (str=<optimized out>,
 count=<optimized out>, fmt=<optimized out>,
     args=args at entry=0x7ffe815b9ea0) at snprintf.c:195
 #3  0x0000556088b95e43 in pg_snprintf (
     str=str at entry=0x7ffe815b9f80 "SELECT proj4text, auth_name, auth_srid,
 srtext FROM `U", count=count at entry=255,
     fmt=fmt at entry=0x7fb348b5b000 "SELECT proj4text, auth_name, auth_srid,
 srtext FROM %s WHERE srid = %d LIMIT 1")
     at snprintf.c:208
 #4  0x00007fb348b0a775 in GetProj4StringSPI (srid=srid at entry=5676) at
 lwgeom_transform.c:345
 #5  0x00007fb348b0a96f in GetProj4String (srid=5676) at
 lwgeom_transform.c:397
 #6  AddToPROJ4SRSCache (other_srid=4326, srid=5676,
 PROJ4Cache=0x556089657398) at lwgeom_transform.c:496
 #7  AddToPROJ4Cache (cache=cache at entry=0x556089657398,
 srid=srid at entry=5676, other_srid=other_srid at entry=4326)
     at lwgeom_transform.c:476
 #8  0x00007fb348b0affe in GetProjectionsUsingFCInfo
 (fcinfo=fcinfo at entry=0x7ffe815ba270, srid1=5676,
     srid2=srid2 at entry=4326, pj1=pj1 at entry=0x7ffe815ba1c8,
 pj2=pj2 at entry=0x7ffe815ba1d0) at lwgeom_transform.c:683
 #9  0x00007fb348af95e9 in transform (fcinfo=0x7ffe815ba270) at
 lwgeom_transform.c:77
 #10 0x00007fb33cf5356d in call_function2 (func=0x7fb348af9580 <transform>,
 arg1=93873110335448, arg2=4326)
     at /home/esteban/src/MobilityDB/src/temporal_util.c:253
 Many thanks for your help.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4747>
