[postgis-tickets] [PostGIS] #4636: ST_Subdivide degrade data
trac at osgeo.org
Fri Aug 21 07:52:27 PDT 2020
Reporter: sirsosp | Owner: strk
Type: defect | Status: assigned
Priority: high | Milestone: PostGIS 3.1.0
Component: postgis | Version: 2.5.x
Resolution: | Keywords:
Changes (by strk):
* status: new => assigned
* owner: pramsey => strk
Comment:
I've enabled debugging of BinaryOp in GEOS to find out what was going on
and I found that in one of the recursive intersection cases all the
heuristics fail until geometry precision reduction step is entered. The
precision reduction starts with a grid of 1e-16 and grows the grid by 10
everytime the intersection fails with a topology exception. The biggest
grid eventually succeeding is 1, which is visible in the output as a grid.
This also explains the time difference, as it basically takes 16 attempts
only in the precision reduction step, not counting earlier attempts with
snapping and common-bits removal...
More stats: precision reduction is engaged 26 times. Of these, 2 times we
have to get down to 1 as a grid size (I guess this is due to using the
same middle-line for the binary subdivision of the same input polygon).
All the other 24 cases work at the very first 1e-16 grid size.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4636#comment:11>
