[postgis-tickets] [PostGIS] #4636: ST_Subdivide degrade data
PostGIS trac at osgeo.org
Fri Aug 21 07:57:50 PDT 2020
  Reporter:  sirsosp  |      Owner:  strk
      Type:  defect   |     Status:  assigned
  Priority:  high     |  Milestone:  PostGIS 3.1.0
 Component:  postgis  |    Version:  2.5.x
Resolution:           |   Keywords:
Comment (by strk):
 Interesting enough (Martin, are you reading this?) the OverlayNG code also
 requires (in a single case) multiple iterations over the precision
 reduction loop, but succeeds earlier (succeeds at 1e-10).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4636#comment:12>
