[postgis-tickets] [PostGIS] #4747: Re: [PostGIS] #4745: Possible problem with new version 2.5.5
trac at osgeo.org
Mon Aug 24 07:44:39 PDT 2020
Reporter: ezimanyi | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 3.1.0
Component: postgis | Version: 2.5.x
Resolution: duplicate | Keywords:
Comment (by ezimanyi):
I am really sorry to insist :-( but I am unable to find a solution to the
problem. I have tried the following solution
PG_FUNCTION_INFO_V1(call_transform);
* Call the PostGIS transform function
PGDLLEXPORT Datum
call_transform(PG_FUNCTION_ARGS)
Datum result = CallerFInfoFunctionCall2(
transform, fcinfo->flinfo, InvalidOid,
PG_GETARG_DATUM(0), PG_GETARG_DATUM(1));
/* Return null on null */
if ( ! result )
PG_RETURN_NULL();
PG_RETURN_DATUM(result);
* Transform the geometry to the given SRID
static Datum
datum_transform(Datum value, Datum srid)
PG_RETURN_DATUM(DirectFunctionCall2Coll(call_transform,
InvalidOid, value, srid));
and the problem persist
Program received signal SIGSEGV, Segmentation fault.
0x00007f6936b051f3 in GetGenericCacheCollection
(fcinfo=fcinfo at entry=0x7ffdfa21a110) at lwgeom_cache.c:67
67 GenericCacheCollection* cache = fcinfo->flinfo->fn_extra;
(gdb) bt
#0 0x00007f6936b051f3 in GetGenericCacheCollection
#1 0x00007f6936b05262 in GetPROJ4SRSCache
(fcinfo=fcinfo at entry=0x7ffdfa21a110) at lwgeom_cache.c:86
#2 0x00007f6936b04ea9 in GetPROJ4Cache
(fcinfo=fcinfo at entry=0x7ffdfa21a110) at lwgeom_transform.c:680
#3 0x00007f6936b04f10 in GetProjectionsUsingFCInfo
(fcinfo=fcinfo at entry=0x7ffdfa21a110, srid1=4326,
srid2=srid2 at entry=5676, pj1=pj1 at entry=0x7ffdfa21a0c8,
pj2=pj2 at entry=0x7ffdfa21a0d0) at lwgeom_transform.c:724
#4 0x00007f6936af3519 in transform (fcinfo=fcinfo at entry=0x7ffdfa21a110)
at lwgeom_transform.c:77
#5 0x0000556dc42c7270 in CallerFInfoFunctionCall2 (func=0x7f6936af34b0
<transform>, flinfo=<optimized out>,
collation=<optimized out>, arg1=<optimized out>, arg2=<optimized out>)
at fmgr.c:1098
#6 0x00007f692b4d960d in call_transform (fcinfo=0x7ffdfa21a1a0)
at /home/esteban/src/MobilityDB/point/src/tpoint_spatialfuncs.c:847
#7 0x0000556dc42c69f4 in DirectFunctionCall2Coll (func=0x7f692b4d95c9
<call_transform>, collation=<optimized out>,
arg1=<optimized out>, arg2=<optimized out>) at fmgr.c:825
#8 0x00007f692b4d9663 in datum_transform (value=93929958568328,
srid=5676)
at /home/esteban/src/MobilityDB/point/src/tpoint_spatialfuncs.c:864
Can you please explain what I am doing wrong ? Many many thanks for you
valuable help.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4747#comment:2>
