[postgis-tickets] [PostGIS] #4747: Re: [PostGIS] #4745: Possible problem with new version 2.5.5
trac at osgeo.org
Mon Aug 24 07:56:33 PDT 2020
Reporter: ezimanyi | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 3.1.0
Component: postgis | Version: 2.5.x
Resolution: duplicate | Keywords:
Comment (by Algunenano):
I **think** that you can't use DirectFunctionCall2Coll, as it initializes
the callee fcinfo with NULL information. You need to use
CallerFInfoFunctionCallXXXX all the time you might use the cache (or
always if you don't want to worry about it).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4747#comment:3>
