[postgis-tickets] [PostGIS] #4748: Incorrect coordinate transformation
trac at osgeo.org
Tue Aug 25 12:47:11 PDT 2020
Reporter: MattBlissett | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.0
Component: postgis | Version: master
Keywords: |
Converting coordinates to EPSG:3031 projection gives incorrect results,
with the coordinates swapped:
SELECT postgis_full_version();
POSTGIS="3.1.0dev b9c792c" [EXTENSION] PGSQL="120" GEOS="3.9.0dev-
CAPI-1.14.0" PROJ="7.2.0" LIBXML="2.9.4" LIBJSON="0.12.1"
LIBPROTOBUF="1.3.1" WAGYU="0.5.0 (Internal)" TOPOLOGY
SELECT ST_AsEWKT(ST_Transform(ST_SetSRID(ST_Point(-36.75, -54.25), 4326),
3031));
SRID=3031;POINT(3213318.496649317 -2399498.730067588)
The expected result, and the result on 3.0.2, is
`SRID=3031;POINT(-2399498.73006759 3213318.49664932)`.
There was some discussion on IRC:
http://irclogs.geoapt.com/postgis/%23postgis.2020-08-24.log starting at
20:28:
> PaulRamsey: axis swapping behaviour changed in proj too
> ReginaObe: did things switch in proj 6?
> PaulRamsey: yes, that's when it got the in built epsg database and
went to epsg axis ordering
> ReginaObe: okay on my 3.1.0alpha2 with proj 5.2.0 I get
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4748>
