[postgis-tickets] [PostGIS] #4747: Re: [PostGIS] #4745: Possible problem with new version 2.5.5
trac at osgeo.org
Wed Aug 26 01:10:38 PDT 2020
Reporter: ezimanyi | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 3.1.0
Component: postgis | Version: 2.5.x
Resolution: duplicate | Keywords:
Comment (by ezimanyi):
Dear Raúl
Many many thanks for helping me to solve the compatibility problem with
PostGIS 2.5.5. I was able to succeed the regression tests again
https://github.com/MobilityDB/MobilityDB/commits/develop
Indeed, as you suggested, I needed to cache the outermost fcinfo in a
global variable.
Concerning your suggestion to depend on PostGIS SQL API, this was the case
of our initial MobilityDB implementation but it was impossible to use
because it was too slow. A typical use case for MobilityDB is to analyze
maritime data as explained in the MobilityDB workshop.
https://github.com/MobilityDB/MobilityDB-workshop
Example of such open data is provided by the Danish Maritime authority
ftp://ftp.ais.dk/ais_data/
Each of these CSV files for a single day contains around 300 ship trips
for a total of more than 10M points which means that each trip has between
3K and 4K timestamped points. We need to analyze the potential collision
risks as shown next
* [https://docs.mobilitydb.com/MobilityDB-
workshop/master/ch01s08.html#imgApproach1]
workshop/master/ch01s08.html#imgApproach2]
We cannot afford to use the SQL API for performance reasons. Indeed, to
create a single trip with 4K points we need to
* call 4K times the function ST_MakePoint
* call 4K times the function ST_SetSRID to specify that the input data is
in 4326 SRID
* call 4K times the function ST_Transform to put the data in the 25832
SRID.
And all this only to load the data of a single day before analyzing every
couple of trips in the data set, synchronizing the two trips to obtain 2
trips of 4K + 4K synchronized points and
* call 4K + 4K times the function ST_Distance for each couple of trips.
As you can imagine, for such kind of manipulations we really need to
access directly the liblwgeom library. The situation is much more
challenging for aviation data obtained from, e.g.,
https://developer.laminardata.aero/
For these reasons we really need to collaborate with you in order to
connect as efficiently as possible MobilityDB and PostGIS. Indeed, the
overall philosophy of MobilityDB is take care of the temporal aspects and
completely delegate the spatial manipulation to PostGIS. Our role is then
to understand at which timestamps the current value of a spatial function
may change and call PostGIS to compute the function at those timestamps.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4747#comment:6>
