[postgis-tickets] [PostGIS] #4802: Spatial query with find_srid() not using the spatial index
trac at osgeo.org
Thu Dec 3 09:45:19 PST 2020
Reporter: Paco Calvo | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.0
Component: postgis | Version: 3.0.x
Resolution: | Keywords:
Comment (by pramsey):
Yes, it probably is related to support functions. You can test by re-
defining find_srid() as an IMMUTABLE (rather than STABLE) function and see
if the problem goes away. I suspect that PgSQL doesn't consider the
function to pass is_pseudo_constant_for_index(). Since there's a
workaround and the problem is rare, I'm not inclined to spend a lot of
time trying to unpick this knot.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4802#comment:3>
