[postgis-tickets] [PostGIS] #4814: GEOS roundtrip conversion drops empty components
PostGIS trac at osgeo.org
Thu Dec 10 13:13:34 PST 2020
  Reporter:  strk     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 3.1.0
 Component:  postgis  |    Version:  2.5.x
Resolution:           |   Keywords:
Comment (by strk):
 Thanks Komzpa, your skipping EMPTY in #3579 was probably a good short-term
 solution but in the long run we want those crashes fixed upstream, in
 GEOS. I could revert [1c7c85c4/git] and [846d74b/git] to re-introduce the
 skip but this would then end up having different results from MakeValid
 depending on whether or not we use GEOS to perform the operation - see
 mail on https://lists.osgeo.org/pipermail/postgis-
 devel/2020-December/028710.html
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4814#comment:8>
