[postgis-tickets] [PostGIS] #4643: PostgreSQL 13 no longer supports FROM in CREATE EXTENSION
trac at osgeo.org
Thu Feb 27 00:56:15 PST 2020
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS PostgreSQL
Component: build/upgrade/install | Version: master
Resolution: | Keywords:
Comment (by strk):
I've implemented the suggestion from Chapman Flack (found in the pgsql-
hackers thread above) into
https://git.osgeo.org/gitea/postgis/postgis/pulls/45
Basically, we install an empty postgis--unpackaged.sql script and use it
to fool PostgreSQL into thinking we need unpackaged--targetversion for
upgrading it...
The run_test.pl was changed to stop using the `FROM unpackaged` syntax and
instead use the workaround syntax of creating the empty extension and then
upgrading it.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4643#comment:7>
