[postgis-tickets] [SCM] PostGIS branch master updated. 7a54134c70582a52676c1c4fae709db9e2a29c9a
git at osgeo.org
git at osgeo.org
Fri Jan 24 14:50:32 PST 2020
the project "PostGIS".
via 7a54134c70582a52676c1c4fae709db9e2a29c9a (commit)
from 8033b2844f14708e84ea9ae29e3129a03e457bd0 (commit)
revisions in full, below.
commit 7a54134c70582a52676c1c4fae709db9e2a29c9a
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Jan 24 13:56:17 2020 -0800
Add docs for ST_Hexagon and ST_Square
diff --git a/doc/reference_constructor.xml b/doc/reference_constructor.xml
index b52f083..e39761e 100644
--- a/doc/reference_constructor.xml
+++ b/doc/reference_constructor.xml
@@ -951,6 +951,95 @@ WHERE ST_Intersects(admin1.geom, hexes.geom)
</refsection>
</refentry>
+ <refentry id="ST_Hexagon">
+ <refnamediv>
+ <refname>ST_Hexagon</refname>
+ <refpurpose>Returns a single hexagon, using the provided edge size and
+ cell coordinate within the hexagon grid space.</refpurpose>
+ </refnamediv>
+ <refsynopsisdiv>
+ <funcsynopsis>
+ <funcprototype>
+ <funcdef>geometry <function>ST_Hexagon</function></funcdef>
+ <paramdef><type>float8</type> <parameter>size</parameter></paramdef>
+ <paramdef><type>integer</type> <parameter>cell_i</parameter></paramdef>
+ <paramdef><type>integer</type> <parameter>cell_j</parameter></paramdef>
+ <paramdef choice="opt"><type>geometry</type> <parameter>origin</parameter></paramdef>
+ </funcprototype>
+ </funcsynopsis>
+ </refsynopsisdiv>
+ <refsection>
+ <title>Description</title>
+ <para>Uses the same hexagon tiling concept as <xref linkend="ST_HexagonGrid" />, but generates just one hexagon at the desired cell coordinate. Optionally,
+ can adjust origin coordinate of the tiling, the default origin is at 0,0.
+ </para>
+ <para>Hexagons are generated with no SRID set, so use <xref linkend="ST_SetSRID" /> to set the SRID to the one you expect.</para>
+ <para>Availability: 3.1</para>
+ </refsection>
+ <refsection>
+ <title>Example: Creating a hexagon at the origin</title>
+ <programlisting>SELECT ST_AsText(ST_SetSRID(ST_Hexagon(1.0, 0, 0), 3857));
+POLYGON((-1 0,-0.5
+ -0.866025403784439,0.5
+ -0.866025403784439,1
+ 0,0.5
+ 0.866025403784439,-0.5
+ 0.866025403784439,-1 0)) </programlisting>
+ </refsection>
+ <refsection>
+ <title>See Also</title>
+ <para><xref linkend="ST_TileEnvelope" />, <xref linkend="ST_HexagonGrid" />, <xref linkend="ST_Square" /></para>
+ </refsection>
+ </refentry>
+ <refentry id="ST_Square">
+ <refnamediv>
+ <refname>ST_Square</refname>
+ <refpurpose>Returns a single square, using the provided edge size and
+ </refnamediv>
+ <refsynopsisdiv>
+ <funcsynopsis>
+ <funcprototype>
+ <funcdef>geometry <function>ST_Square</function></funcdef>
+ </funcprototype>
+ </funcsynopsis>
+ </refsynopsisdiv>
+ <refsection>
+ <para>Uses the same square tiling concept as <xref linkend="ST_SquareGrid" />, but generates just one square at the desired cell coordinate. Optionally,
+ </para>
+ <para>Squares are generated with no SRID set, so use <xref linkend="ST_SetSRID" /> to set the SRID to the one you expect.</para>
+ </refsection>
+ <refsection>
+ <title>Example: Creating a square at the origin</title>
+ <programlisting>SELECT ST_AsText(ST_SetSRID(ST_Square(1.0, 0, 0), 3857));
+ POLYGON((0 0,0 1,1 1,1 0,0 0))</programlisting>
+ </refsection>
+ <refsection>
+ <para><xref linkend="ST_TileEnvelope" />, <xref linkend="ST_SquareGrid" />, <xref linkend="ST_Hexagon" /></para>
+ </refsection>
+ </refentry>
Summary of changes:
doc/reference_constructor.xml | 89 +++++++++++++++++++++++++++++++++++++++++++
1 file changed, 89 insertions(+)
hooks/post-receive
