[postgis-tickets] [PostGIS] #4712: Coordinate transformation from NAV4 to WGS84 is exact in Linux but in Windows it differs by 176 meters
trac at osgeo.org
Wed Jul 1 08:39:52 PDT 2020
Reporter: zellner | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.0.2
Component: postgis | Version: 3.0.x
Resolution: | Keywords:
Comment (by Algunenano):
Coordinate transformation is handled via PROJ. Can you try updating your
PROJ installation in Windows to match the one you are using under Linux
(6.3.1 vs 5.2.0) to see if the issue persist?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4712#comment:2>
