[postgis-tickets] [PostGIS] #4713: Degenerated polygons from ST_Difference
trac at osgeo.org
Thu Jul 2 21:03:35 PDT 2020
Reporter: espinafre | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.0
Component: postgis | Version: 3.0.x
Keywords: |
When trying to do a ST_Difference between two fairly complex
MultiPolygons, the result is a MultiPolygon composed of rectangles and
triangles, looking like overly simplified shapes.
* Database version: PostgreSQL 12.3
* OS/Architecture: Gentoo Linux, AMD64 (also reproduced with CentOS 8/PGDG
repo)
* PostGIS version: 3.0.1
* GEOS version: 3.8.1
* GDAL version: 3.1.0
* PROJ version: 7.0.1
The table definitions are as follows:
CREATE TABLE tb_test_a
id integer PRIMARY KEY,
geom geometry(MultiPolygon,4674)
CREATE TABLE tb_test_b
They have a single record each, with a different geometry in each case,
which I'm attaching to this report; they are both ST_Valid()
MultiPolygons.
This is what generates the degenerated polygons:
SELECT
ST_Difference(a.geom, b.geom) geom
FROM
tb_test_a a,
tb_test_b b
If I wrap both geometries with ST_MakeValid(ST_SnapToGrid()), I get the
expected results:
SELECT
ST_Difference(
ST_MakeValid(ST_SnapToGrid(a.geom, 0.0000000001)),
ST_MakeValid(ST_SnapToGrid(b.geom, 0.0000000001)) ) geom
FROM
tb_test_a a,
tb_test_b b
I have to make ST_MakeValid after snapping because of self-intersection
errors.
I've also seen cases of ST_Intersection failing the same way (generating
too simplified results) with similarly complex source MultiPolygons (but
not with the attached data).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4713>
