[postgis-tickets] [PostGIS] #4711: ST_Union loses precision on complex multilinestring geometries
trac at osgeo.org
Thu Jul 2 21:47:59 PDT 2020
Reporter: dannytoone | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS GEOS
Component: postgis | Version: 3.0.x
Resolution: | Keywords:
Comment (by mdavis):
Replying to [comment:7 dannytoone]:
> On the subject of snapping, how would you go about doing that? Snapping
everything to a grid before unioning seems to work to some degree, but
some of the geometries still end up jagged, and some still end up squared.
The snapping mentioned above is a new technique developed for the
forthcoming OverlayNG. The algorithm is surprisingly simple: (i) scan
all vertices of the input geometries and snap each one to previously
scanned ones; (ii) scan all segments and snap them at intersections and
to nearby anchor points. This is liable to introduce topology collapses,
but these are removed by the overlay algorithm when it reforms the
topology.
This is a heuristic algorithm - i.e. the snapping can produce situations
with topology so invalid that it causes the overlay to fail. But these
are very rare in practice, and so far can all be handled by just snapping
more aggresively.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4711#comment:10>
