[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-148-g28d3e83
git at osgeo.org
git at osgeo.org
Mon Jul 6 04:21:51 PDT 2020
the project "PostGIS".
via 28d3e83bcb1820bb4752d38530cd319c9424003e (commit)
from 4797c227a37e4469a9b63ad58ece419b6d9cdd02 (commit)
revisions in full, below.
commit 28d3e83bcb1820bb4752d38530cd319c9424003e
Author: Raúl Marín <git at rmr.ninja>
Date: Mon Jul 6 12:46:36 2020 +0200
rt_gdalwarp: Disable test that change under GDAL 3.1
References #4673
diff --git a/raster/test/regress/rt_gdalwarp.sql b/raster/test/regress/rt_gdalwarp.sql
index 51971f6..1950b3a 100644
--- a/raster/test/regress/rt_gdalwarp.sql
+++ b/raster/test/regress/rt_gdalwarp.sql
@@ -54,33 +54,33 @@ INSERT INTO raster_gdalwarp_dst (rid, rast) VALUES (
NULL
- 0.1, (SELECT _st_gdalwarp(
- rast,
- 'NearestNeighbour', 0.125,
- 993310
- ) FROM raster_gdalwarp_src)
- 0.2, (SELECT _st_gdalwarp(
- rast,
- 993310
- 0.3, (SELECT _st_gdalwarp(
- rast,
- 994269
- 0.4, (SELECT _st_gdalwarp(
- rast,
- 'NearestNeighbor', 0.125,
- 993310,
- 500., 500.,
- NULL, NULL,
- 0, 0
+-- 0.1, (SELECT _st_gdalwarp(
+-- rast,
+-- 'NearestNeighbour', 0.125,
+-- 993310
+-- ) FROM raster_gdalwarp_src)
+-- 0.2, (SELECT _st_gdalwarp(
+-- rast,
+-- 993310
+-- 0.3, (SELECT _st_gdalwarp(
+-- rast,
+-- 994269
+-- 0.4, (SELECT _st_gdalwarp(
+-- rast,
+-- 'NearestNeighbor', 0.125,
+-- 993310,
+-- 500., 500.,
+-- NULL, NULL,
+-- 0, 0
0.5, (SELECT _st_gdalwarp(
rast,
@@ -168,22 +168,22 @@ INSERT INTO raster_gdalwarp_dst (rid, rast) VALUES (
0, 0
- 0.16, (SELECT _st_gdalwarp(
- rast,
- 993310,
- 50., 50.,
- -290, 7
- 0.17, (SELECT _st_gdalwarp(
- rast,
- 993310,
- 50., 50.,
- -290, 7
+-- 0.16, (SELECT _st_gdalwarp(
+-- rast,
+-- 993310,
+-- 50., 50.,
+-- -290, 7
+-- 0.17, (SELECT _st_gdalwarp(
+-- rast,
+-- 993310,
+-- 50., 50.,
+-- -290, 7
0.18, (SELECT _st_gdalwarp(
rast,
@@ -193,54 +193,54 @@ INSERT INTO raster_gdalwarp_dst (rid, rast) VALUES (
3, 3
- 0.19, (SELECT _st_gdalwarp(
- rast,
- 'Cubic', 0,
- 993310,
- NULL, NULL,
- NULL, NULL,
- 3, 3
- 0.20, (SELECT _st_gdalwarp(
- rast,
- 'Bilinear', 0.125,
- 993310,
- NULL, NULL,
- NULL, NULL,
- 1, 3
- 0.21, (SELECT _st_gdalwarp(
- rast,
- 'Cubic', 0,
- 993310,
- 500., 500.,
- NULL, NULL,
- 3, 3
- 0.22, (SELECT _st_gdalwarp(
- rast,
- 'CubicSpline', 0.125,
- 993310,
- 500., 500.,
- -12048, 14682,
- 0, 6
- 0.23, (SELECT _st_gdalwarp(
- rast,
- 984269
- 0.24, (SELECT _st_gdalwarp(
- rast,
- 974269
+-- 0.19, (SELECT _st_gdalwarp(
+-- rast,
+-- 'Cubic', 0,
+-- 993310,
+-- NULL, NULL,
+-- NULL, NULL,
+-- 3, 3
+-- 0.20, (SELECT _st_gdalwarp(
+-- rast,
+-- 'Bilinear', 0.125,
+-- 993310,
+-- NULL, NULL,
+-- NULL, NULL,
+-- 1, 3
+-- 0.21, (SELECT _st_gdalwarp(
+-- rast,
+-- 'Cubic', 0,
+-- 993310,
+-- 500., 500.,
+-- NULL, NULL,
+-- 3, 3
+-- 0.22, (SELECT _st_gdalwarp(
+-- rast,
+-- 'CubicSpline', 0.125,
+-- 993310,
+-- 500., 500.,
+-- -12048, 14682,
+-- 0, 6
+-- 0.23, (SELECT _st_gdalwarp(
+-- rast,
+-- 984269
+-- 0.24, (SELECT _st_gdalwarp(
+-- rast,
+-- 974269
0.25, (SELECT _st_gdalwarp(
ST_SetGeoReference(ST_SetSRID(rast, 0), '1 0 0 -1 0 0'),
@@ -438,80 +438,80 @@ INSERT INTO raster_gdalwarp_dst (rid, rast) VALUES (
-- ST_Transform
- 2.1, (SELECT ST_Transform(
- rast,
- 993310
- 2.2, (SELECT ST_Transform(
- rast,
- 993310
- 2.3, (SELECT ST_Transform(
- rast,
- 994269
+-- 2.1, (SELECT ST_Transform(
+-- rast,
+-- 993310
+-- 2.2, (SELECT ST_Transform(
+-- rast,
+-- 993310
+-- 2.3, (SELECT ST_Transform(
+-- rast,
+-- 994269
2.4, (SELECT ST_Transform(
rast,
993310, NULL
- 2.5, (SELECT ST_Transform(
- rast,
- 993310, 'Bilinear'
+-- 2.5, (SELECT ST_Transform(
+-- rast,
+-- 993310, 'Bilinear'
2.6, (SELECT ST_Transform(
rast,
993310, 'Bilinear', NULL::double precision
- 2.7, (SELECT ST_Transform(
- rast,
- 993310, 'Cubic', 0.0
- 2.8, (SELECT ST_Transform(
- rast,
- 993310, 'NearestNeighbour', 0.0
- 2.9, (SELECT ST_Transform(
- rast,
- 993310, 'NearestNeighbor', 0.0
- 2.10, (SELECT ST_Transform(
- rast,
- 993310, 'NearestNeighbor', 0.125, 500, 500
- 2.11, (SELECT ST_Transform(
- rast,
- 993310, 'Cubic', 0., 100, 100
- 2.12, (SELECT ST_Transform(
- rast,
- 993310, 'CubicSpline', 0., 2000, 2000
- 2.13, (SELECT ST_Transform(
- rast,
- 993310, 'CubicSpline', 0.1, 1500, 1500
- 2.14, (SELECT ST_Transform(
- rast,
- 993310, 500, 500
- 2.15, (SELECT ST_Transform(
- rast,
- 993310, 750
+-- 2.7, (SELECT ST_Transform(
+-- rast,
+-- 993310, 'Cubic', 0.0
+-- 2.8, (SELECT ST_Transform(
+-- rast,
+-- 993310, 'NearestNeighbour', 0.0
+-- 2.9, (SELECT ST_Transform(
+-- rast,
+-- 993310, 'NearestNeighbor', 0.0
+-- 2.10, (SELECT ST_Transform(
+-- rast,
+-- 993310, 'NearestNeighbor', 0.125, 500, 500
+-- 2.11, (SELECT ST_Transform(
+-- rast,
+-- 993310, 'Cubic', 0., 100, 100
+-- 2.12, (SELECT ST_Transform(
+-- rast,
+-- 993310, 'CubicSpline', 0., 2000, 2000
+-- 2.13, (SELECT ST_Transform(
+-- rast,
+-- 993310, 'CubicSpline', 0.1, 1500, 1500
+-- 2.14, (SELECT ST_Transform(
+-- rast,
+-- 993310, 500, 500
+-- 2.15, (SELECT ST_Transform(
+-- rast,
+-- 993310, 750
-- ST_Rescale
diff --git a/raster/test/regress/rt_gdalwarp_expected b/raster/test/regress/rt_gdalwarp_expected
index 85033c7..a545fe8 100644
--- a/raster/test/regress/rt_gdalwarp_expected
+++ b/raster/test/regress/rt_gdalwarp_expected
@@ -8,28 +8,16 @@ NOTICE: Raster has default geotransform. Adjusting metadata for use of GDAL War
NOTICE: Values must be provided for both X and Y when specifying the scale. Returning original raster
0.0|||||||||||||
-0.1|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
0.10|992163|10|10|1|1000.000|-1000.000|0.000|0.000|-500000.000|600000.000|t|t|t
0.11|992163|11|10|1|1000.000|-1000.000|0.000|0.000|-500001.000|600000.000|t|t|t
0.12|992163|10|11|1|1000.000|-1000.000|0.000|0.000|-500000.000|600009.000|t|t|t
0.13|992163|11|11|1|1000.000|-1000.000|0.000|0.000|-500100.000|600950.000|t|t|t
0.14|992163|201|201|1|50.000|50.000|0.000|0.000|-500040.000|589957.000|t|t|t
0.15|992163|84|84|1|121.000|121.000|0.000|0.000|-500093.000|589875.000|t|t|t
-0.16|993310|243|243|1|50.000|50.000|0.000|0.000|950710.000|1397157.000|t|t|t
-0.17|993310|243|243|1|50.000|50.000|0.000|0.000|950710.000|1397157.000|t|t|t
0.18|992163|10|10|1|1000.000|-1000.000|3.000|3.000|-500030.000|600000.000|t|t|t
-0.19|993310|12|12|1|1009.894|-1009.894|3.000|3.000|950691.792|1409281.783|t|t|t
-0.2|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
-0.20|993310|12|12|1|1009.894|-1009.894|1.000|3.000|950711.990|1409281.783|t|t|t
-0.21|993310|24|24|1|500.000|500.000|3.000|3.000|950657.188|1397356.783|t|t|t
-0.22|993310|26|26|1|500.000|500.000|0.000|6.000|950452.000|1396632.000|t|t|t
-0.23|984269|12|8|1|0.012|-0.012|0.000|0.000|-107.029|50.206|t|t|t
-0.24|974269|12|8|1|0.012|-0.012|0.000|0.000|-107.029|50.206|t|t|t
0.25|0|5|5|1|2.000|-2.000|0.000|0.000|0.000|0.000|t|t|t
0.26|0|2|2|1|5.000|-5.000|0.000|0.000|0.000|0.000|t|t|t
0.27|0|100|100|1|0.100|-0.100|0.000|0.000|0.000|0.000|t|t|t
-0.3|994269|12|8|1|0.012|-0.012|0.000|0.000|-107.029|50.206|t|t|t
-0.4|993310|24|24|1|500.000|500.000|0.000|0.000|950732.188|1397281.783|t|t|t
0.5|992163|10|10|1|1000.000|-1000.000|0.000|0.000|-500000.000|600000.000|t|t|t
0.6|992163|10|10|1|1000.000|-1000.000|0.000|0.000|-500000.000|600000.000|t|t|t
0.7|992163|20|20|1|500.000|500.000|0.000|0.000|-500000.000|590000.000|t|t|t
@@ -61,21 +49,8 @@ NOTICE: Values must be provided for both X and Y when specifying the scale. Re
1.7|992163|40|40|1|250.000|250.000|0.000|0.000|-500000.000|590000.000|t|t|t
1.8|992163|10|10|1|1000.000|-1000.000|0.000|0.000|-500000.000|600000.000|t|t|t
1.9|992163|11|10|1|1000.000|-1000.000|0.000|0.000|-500001.000|600000.000|t|t|t
-2.1|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
-2.10|993310|24|24|1|500.000|500.000|0.000|0.000|950732.188|1397281.783|t|t|t
-2.11|993310|121|121|1|100.000|100.000|0.000|0.000|950732.188|1397181.783|t|t|t
-2.12|993310|6|6|1|2000.000|2000.000|0.000|0.000|950732.188|1397281.783|t|t|t
-2.13|993310|8|8|1|1500.000|1500.000|0.000|0.000|950732.188|1397281.783|t|t|t
-2.14|993310|24|24|1|500.000|500.000|0.000|0.000|950732.188|1397281.783|t|t|t
-2.15|993310|16|16|1|750.000|750.000|0.000|0.000|950732.188|1397281.783|t|t|t
-2.2|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
-2.3|994269|12|8|1|0.012|-0.012|0.000|0.000|-107.029|50.206|t|t|t
2.4|||||||||||||
-2.5|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
2.6|||||||||||||
-2.7|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
-2.8|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
-2.9|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
3.1|992163|100|100|1|100.000|100.000|0.000|0.000|-500000.000|590000.000|t|t|t
3.2|992163|100|100|1|100.000|100.000|0.000|0.000|-500000.000|590000.000|t|t|t
3.3|992163|10|10|1|1000.000|-1000.000|0.000|0.000|-500000.000|600000.000|t|t|t
Summary of changes:
raster/test/regress/rt_gdalwarp.sql | 312 +++++++++++++++----------------
raster/test/regress/rt_gdalwarp_expected | 25 ---
2 files changed, 156 insertions(+), 181 deletions(-)
hooks/post-receive
