[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-163-ga02988f
git at osgeo.org
git at osgeo.org
Fri Jul 10 05:02:26 PDT 2020
the project "PostGIS".
via a02988fceaf16f8cd2487b0e7e8692bc68a7212d (commit)
from 7822ff80dc3c48dfdd759a30b050c557c3f972b6 (commit)
revisions in full, below.
commit a02988fceaf16f8cd2487b0e7e8692bc68a7212d
Author: Sandro Santilli <strk at kbt.io>
Date: Fri Jul 10 13:58:26 2020 +0200
Use POSTGIS_DEBUG for debugging
diff --git a/postgis/gserialized_estimate.c b/postgis/gserialized_estimate.c
index 5fcb3a3..fa4700e 100644
--- a/postgis/gserialized_estimate.c
+++ b/postgis/gserialized_estimate.c
@@ -1267,13 +1267,13 @@ gserialized_joinsel_internal(PlannerInfo *root, List *args, JoinType jointype, i
Var *var1 = (Var*) arg1;
Var *var2 = (Var*) arg2;
- elog(DEBUG2, "%s: entered function", __func__);
+ POSTGIS_DEBUGF(2, "%s: entered function", __func__);
/* We only do column joins right now, no functional joins */
/* TODO: handle g1 && ST_Expand(g2) */
if (!IsA(arg1, Var) || !IsA(arg2, Var))
- elog(DEBUG1, "%s called with arguments that are not column references", __func__);
+ POSTGIS_DEBUGF(1, "%s called with arguments that are not column references", __func__);
return DEFAULT_ND_JOINSEL;
@@ -1288,17 +1288,17 @@ gserialized_joinsel_internal(PlannerInfo *root, List *args, JoinType jointype, i
/* If we can't get stats, we have to stop here! */
if (!stats1)
- elog(DEBUG2, "%s: cannot find stats for \"%s\"", __func__, get_rel_name(relid2) ? get_rel_name(relid2) : "NULL");
+ POSTGIS_DEBUGF(2, "%s: cannot find stats for \"%s\"", __func__, get_rel_name(relid2) ? get_rel_name(relid2) : "NULL");
else if (!stats2)
selectivity = estimate_join_selectivity(stats1, stats2);
- elog(DEBUG2, "got selectivity %g", selectivity);
+ POSTGIS_DEBUGF(2, "got selectivity %g", selectivity);
pfree(stats1);
pfree(stats2);
return selectivity;
@@ -1321,19 +1321,19 @@ Datum gserialized_gist_joinsel(PG_FUNCTION_ARGS)
JoinType jointype = (JoinType) PG_GETARG_INT16(3);
int mode = PG_GETARG_INT32(4);
/* Check length of args and punt on > 2 */
if (list_length(args) != 2)
- elog(DEBUG2, "%s: got nargs == %d", __func__, list_length(args));
+ POSTGIS_DEBUGF(2, "%s: got nargs == %d", __func__, list_length(args));
PG_RETURN_FLOAT8(DEFAULT_ND_JOINSEL);
/* Only respond to an inner join/unknown context join */
if (jointype != JOIN_INNER)
- elog(DEBUG1, "%s: jointype %d not supported", __func__, jointype);
+ POSTGIS_DEBUGF(1, "%s: jointype %d not supported", __func__, jointype);
@@ -2235,31 +2235,31 @@ gserialized_sel_internal(PlannerInfo *root, List *args, int varRelid, int mode)
GBOX search_box;
float8 selectivity = 0;
if (!get_restriction_variable(root, args, varRelid, &vardata, &other, &varonleft))
- elog(DEBUG2, "%s: could not find vardata", __func__);
+ POSTGIS_DEBUGF(2, "%s: could not find vardata", __func__);
return DEFAULT_ND_SEL;
if (!IsA(other, Const))
ReleaseVariableStats(vardata);
- elog(DEBUG2, "%s: no constant argument, returning default selectivity %g", __func__, DEFAULT_ND_SEL);
+ POSTGIS_DEBUGF(2, "%s: no constant argument, returning default selectivity %g", __func__, DEFAULT_ND_SEL);
if (!gserialized_datum_get_gbox_p(((Const*)other)->constvalue, &search_box))
- elog(DEBUG2, "%s: search box is EMPTY", __func__);
+ POSTGIS_DEBUGF(2, "%s: search box is EMPTY", __func__);
return 0.0;
if (!vardata.statsTuple)
- elog(DEBUG1, "%s: no statistics available on table. Empty? Need to ANALYZE?", __func__);
+ POSTGIS_DEBUGF(1, "%s: no statistics available on table. Empty? Need to ANALYZE?", __func__);
@@ -2279,7 +2279,7 @@ Datum gserialized_gist_sel(PG_FUNCTION_ARGS)
int varRelid = PG_GETARG_INT32(3);
float8 selectivity = gserialized_sel_internal(root, args, varRelid, mode);
- elog(DEBUG2, "%s: selectivity is %g", __func__, selectivity);
+ POSTGIS_DEBUGF(2, "%s: selectivity is %g", __func__, selectivity);
PG_RETURN_FLOAT8(selectivity);
@@ -2343,7 +2343,7 @@ Datum gserialized_estimated_extent(PG_FUNCTION_ARGS)
/* Read the extent from the head of the spatial index, if there is one */
idx_oid = table_get_spatial_index(tbl_oid, col, &key_type);
if (!idx_oid)
- elog(DEBUG2, "index for \"%s.%s\" does not exist", tbl, text_to_cstring(col));
+ POSTGIS_DEBUGF(2, "index for \"%s.%s\" does not exist", tbl, text_to_cstring(col));
gbox = spatial_index_read_extent(idx_oid, key_type);
#endif
diff --git a/postgis/gserialized_supportfn.c b/postgis/gserialized_supportfn.c
index ff018a8..d783337 100644
--- a/postgis/gserialized_supportfn.c
+++ b/postgis/gserialized_supportfn.c
@@ -291,7 +291,7 @@ Datum postgis_index_supportfn(PG_FUNCTION_ARGS)
req->selectivity = gserialized_sel_internal(req->root, req->args, req->varRelid, 2);
- elog(DEBUG2, "%s: got selectivity %g", __func__, req->selectivity);
+ POSTGIS_DEBUGF(2, "%s: got selectivity %g", __func__, req->selectivity);
PG_RETURN_POINTER(req);
Summary of changes:
postgis/gserialized_estimate.c | 30 +++++++++++++++---------------
postgis/gserialized_supportfn.c | 2 +-
2 files changed, 16 insertions(+), 16 deletions(-)
hooks/post-receive
