[postgis-tickets] [PostGIS] #4684: concurrent topology construction routine may result in invalid topology
PostGIS trac at osgeo.org
Sat Jul 11 00:15:35 PDT 2020
  Reporter:  laopsahl  |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:
 Component:  topology  |    Version:  3.0.x
Resolution:            |   Keywords:
Comment (by laopsahl):
 A test case showing how to use row level lock to avoid Topology errors .
 Info from the db_topo_rowlevel_lock_readme.txt in file
 db_topo_rowlevel_lock.zip.
 # Create a empty database
 psql postgres -c'create database t1'
 # Add the code needed for testing
 t1 -f db_topo_rowlevel_lock_init.sql
 # Test with no rowlevel locking, should return something like this
 psql t1 -f db_topo_rowlevel_lock_test_fail.sql
  ?column?  |      error       | id1 | id2
  validation | face within face |   1 |   2
  validation | face within face |   2 |   1
  validation | face within face |   1 |   3
  validation | face within face |   2 |   3
 (4 rows)
 # Test with rowlevel locking , no topop errors should be found
 psql t1 -f db_topo_rowlevel_lock_test_ok.sql
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4684#comment:13>
