[postgis-tickets] [PostGIS] #4721: SQL Error [XX000] with ST_AddEdgeModFace
trac at osgeo.org
Mon Jul 13 14:28:26 PDT 2020
Reporter: jeromeu | Owner: strk
Type: defect | Status: new
Priority: critical | Milestone: PostGIS PostgreSQL
Component: topology | Version: 3.0.x
Keywords: topology edge Error |
Hello,
I am trying to manually add edges to a topology schema. I receive the
following error:
SQL Error [XX000]: ERROR: Second line start point too far from first
line
end point
My query is
SELECT topology.ST_AddEdgeModFace('zip', 4802117, 4802118,
ST_GeomFromText('LINESTRING(327015.5 6654998, 333892 6646902)', 3857))
The nodes seem correctly placed and their corredinates correspond to the
entered ones for the linestring. All 4 edges connected to the nodes do
have a left or right face 0.
In other words, I want to add a new edge, where there is no face yet. The
nodes are already created, let's call them point B (id: 4802117,
coordinates: 327015.5 6654998) on segment ABC and point E (id: 4802118,
coordinates: 333892 6646902) on segment DEF that is roughly parallel to
ABC. I want an edge connecting B and E.
I am using
POSTGIS="3.0.1 ec2a9aa" [EXTENSION] PGSQL="120" GEOS="3.8.0-CAPI-1.13.1
" SFCGAL="1.3.6" PROJ="Rel. 4.9.3, 15 August 2016" GDAL="GDAL 2.4.2,
released 2019/06/28 GDAL_DATA not found" LIBXML="2.9.4" LIBJSON="0.12.1"
LIBPROTOBUF="1.2.1" WAGYU="0.4.3 (Internal)" TOPOLOGY RASTER
and
PostgreSQL 12.1 (Ubuntu 12.1-1.pgdg18.04+1) on x86_64-pc-linux-gnu,
compiled by gcc (Ubuntu 7.4.0-1ubuntu1~18.04.1) 7.4.0, 64-bit
I would deeply appreciate your help in getting around that issue.
Kind regards
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4721>
