[postgis-tickets] [PostGIS] #4717: upgrading to 3.0.1 from 2.4.4 following docu does not work: "Updating extension postgis from 3.0.1 to 2.4.4" ?!
PostGIS trac at osgeo.org
Tue Jul 14 00:06:01 PDT 2020
  Reporter:  tpo      |      Owner:  pramsey
      Type:  defect   |     Status:  closed
  Priority:  medium   |  Milestone:  PostGIS 3.0.2
 Component:  postgis  |    Version:  3.0.x
Resolution:  wontfix  |   Keywords:
Comment (by tpo):
 @robe wrote:
 > This is a user issue and not a postgis issue so marking as won't fix.
 and later:
 > as noted in irc, that fact there is no postgis-3-scripts postgis.control
 file sounds like a packaging mistake.
 If both of these assertions should be true at the same time, then that
 would mean that the packaging mistake is a user issue and won't be fixed.
 Right?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4717#comment:6>
