[postgis-tickets] [PostGIS] #4722: crash on null input to topogeo_addpoint()
PostGIS trac at osgeo.org
Wed Jul 15 04:20:25 PDT 2020
 Reporter:  Robins            |      Owner:  strk
     Type:  defect            |     Status:  new
 Priority:  medium            |  Milestone:  PostGIS 3.1.0
Component:  topology          |    Version:  3.0.x
 Keywords:  topogeo_addpoint  |
 When topogeo_addpoint() is called with NULLs it crashes the server.
 Sample SQLs:
 SELECT topogeo_addpoint(null::varchar, null::geometry, NULL::float8);
 SELECT topogeo_addpoint(cast(null as "varchar"),cast(null as
 geometry),cast(NULL as float8));
 SQL Output
 db=> SELECT postgis_full_version();
  POSTGIS="3.0.0 r17983" [EXTENSION] PGSQL="120" GEOS="3.8.0-CAPI-1.13.1 "
 PROJ="Rel. 5.2.0, September 15th, 2018" LIBXML="2.9.1" LIBJSON="0.13.1"
 LIBPROTOBUF="1.3.2" WAGYU="0.4.3 (Internal)" TOPOLOGY
 (1 row)
 db=> select version();
                                                  version
  PostgreSQL 12.3 on x86_64-pc-linux-gnu, compiled by gcc (GCC) 4.8.5
 20150623 (Red Hat 4.8.5-11), 64-bit
 (1 row)
 db=> \dx
                                          List of installed extensions
        Name       | Version |   Schema   |
 Description
  plpgsql          | 1.0     | pg_catalog | PL/pgSQL procedural language
  postgis          | 3.0.0   | public     | PostGIS geometry, geography,
 and raster spatial types and functions
  postgis_topology | 3.0.0   | topology   | PostGIS topology spatial types
 and functions
 (3 rows)
 db=> SELECT topogeo_addpoint(cast(null as "varchar"),cast(null as
 server closed the connection unexpectedly
         This probably means the server terminated abnormally
         before or while processing the request.
 The connection to the server was lost. Attempting reset: Failed.
 !?> \q
 ~$ psql db
 psql (13beta2, server 12.3)
 Type "help" for help.
 db=>
 Error Logs
 2020-07-15 02:35:32 UTC::@:[23172]:LOG:  server process (PID 27631) was
 terminated by signal 11: Segmentation fault
 2020-07-15 02:35:32 UTC::@:[23172]:DETAIL:  Failed process was running:
 2020-07-15 02:35:32 UTC::@:[23172]:LOG:  terminating any other active
 server processes
 2020-07-15 02:35:32 UTC::@:[26751]:WARNING:  terminating connection
 because of crash of another server process
 2020-07-15 02:35:32 UTC::@:[26751]:DETAIL:  The postmaster has commanded
 this server process to roll back the current transaction and exit, because
 another server process exited abnormally and possibly corrupted shared
 memory.
 2020-07-15 02:35:32 UTC::@:[26751]:HINT:  In a moment you should be able
 to reconnect to the database and repeat your command.
 2020-07-15 02:35:32 UTC::@:[23172]:LOG:  archiver process (PID 26752)
 exited with exit code 1
 2020-07-15 02:35:32 UTC:172.31.7.235(45906):postgres123 at db:[28053]:FATAL:
 the database system is in recovery mode
 2020-07-15 02:35:32 UTC::@:[23172]:LOG:  all server processes terminated;
 reinitializing
 2020-07-15 02:35:32 UTC::@:[28054]:LOG:  database system was interrupted;
 last known up at 2020-07-15 02:33:29 UTC
 2020-07-15 02:35:32 UTC::@:[28054]:LOG:  database system was not properly
 shut down; automatic recovery in progress
 2020-07-15 02:35:32 UTC::@:[28054]:LOG:  redo starts at 36/55478720
 2020-07-15 02:35:32 UTC::@:[28054]:LOG:  invalid record length at
 36/554E6F18: wanted 24, got 0
 2020-07-15 02:35:32 UTC::@:[28054]:LOG:  redo done at 36/554E5170
 2020-07-15 02:35:32 UTC::@:[28054]:LOG:  checkpoint starting: end-of-
 recovery immediate
 2020-07-15 02:35:32 UTC::@:[28054]:LOG:  checkpoint complete: wrote 62
 buffers (0.0%); 0 WAL file(s) added, 0 removed, 0 recycled; write=0.003 s,
 sync=0.002 s, total=0.015 s; sync files=13, longest=0.002 s, average=0.000
 s; distance=442 kB, estimate=442 kB
 2020-07-15 02:35:32 UTC::@:[23172]:LOG:  database system is ready to
 accept connections
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4722>
