[postgis-tickets] [PostGIS] #4721: SQL Error [XX000] with ST_AddEdgeModFace
PostGIS trac at osgeo.org
Wed Jul 15 05:42:15 PDT 2020
  Reporter:  jeromeu   |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  critical  |  Milestone:  PostGIS PostgreSQL
 Component:  topology  |    Version:  3.0.x
Resolution:            |   Keywords:  topology edge Error
Comment (by jeromeu):
 I tried, but currently I can't: When just copying the 4 edges into a new
 topology (or even a bit more), adding that new edge works.
 Of course the topology schema I want to add that edge into is much larger
 than 4 edges. I ran
 SELECT topology.ValidateTopology, and there is a number of Errors, but
 none seems in the vicinity of that edge I am trying to add.
 I will keep on investigating. If anyone has any idea, I am interested.
 Thanks for your help
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4721#comment:2>
