[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-165-gf0b631a
git at osgeo.org
git at osgeo.org
Wed Jul 15 07:36:50 PDT 2020
the project "PostGIS".
via f0b631a808d5e4bc0bf30055e2777e2649b8df0f (commit)
from 3bd678013beefac822c760fd84a02acd9acb94b0 (commit)
revisions in full, below.
commit f0b631a808d5e4bc0bf30055e2777e2649b8df0f
Author: Sandro Santilli <strk at kbt.io>
Date: Wed Jul 15 16:33:42 2020 +0200
Fix crash on TopoGeo_addPoint null arguments
References #4722 in master branch (3.1.0dev)
diff --git a/topology/postgis_topology.c b/topology/postgis_topology.c
index 32bedb0..3acc5c6 100644
--- a/topology/postgis_topology.c
+++ b/topology/postgis_topology.c
@@ -4658,6 +4658,12 @@ Datum TopoGeo_AddPoint(PG_FUNCTION_ARGS)
LWPOINT *pt;
LWT_TOPOLOGY *topo;
+ if ( PG_ARGISNULL(0) || PG_ARGISNULL(1) || PG_ARGISNULL(2) )
+ lwpgerror("SQL/MM Spatial exception - null argument");
+ PG_RETURN_NULL();
toponame_text = PG_GETARG_TEXT_P(0);
toponame = text_to_cstring(toponame_text);
PG_FREE_IF_COPY(toponame_text, 0);
diff --git a/topology/test/regress/topogeo_addpoint.sql b/topology/test/regress/topogeo_addpoint.sql
index c023327..b7c4f92 100644
--- a/topology/test/regress/topogeo_addpoint.sql
+++ b/topology/test/regress/topogeo_addpoint.sql
@@ -7,6 +7,10 @@ set client_min_messages to ERROR;
SELECT 'invalid', TopoGeo_addPoint('city_data', 'LINESTRING(36 26, 38 30)');
SELECT 'invalid', TopoGeo_addPoint('city_data', 'MULTIPOINT((36 26))');
SELECT 'invalid', TopoGeo_addPoint('invalid', 'POINT(36 26)');
+-- See #4722
+SELECT 'invalid', TopoGeo_addPoint(null::varchar, null::geometry, null::float8);
+SELECT 'invalid', TopoGeo_addPoint(null::varchar, 'POINT(36 36)'::geometry, null::float8);
+SELECT 'invalid', TopoGeo_addPoint('city_data', null::geometry, null::float8);
-- Save max node id
select 'node'::text as what, max(node_id) INTO city_data.limits FROM city_data.node;
diff --git a/topology/test/regress/topogeo_addpoint_expected b/topology/test/regress/topogeo_addpoint_expected
index f7e791d..5daedaa 100644
--- a/topology/test/regress/topogeo_addpoint_expected
+++ b/topology/test/regress/topogeo_addpoint_expected
@@ -5,6 +5,9 @@ t
ERROR: Invalid geometry type (LINESTRING) passed to TopoGeo_AddPoint, expected POINT
ERROR: Invalid geometry type (MULTIPOINT) passed to TopoGeo_AddPoint, expected POINT
ERROR: No topology with name "invalid" in topology.topology
+ERROR: SQL/MM Spatial exception - null argument
iso_uni|23
iso_f3|24
iso_ex|23
Summary of changes:
topology/postgis_topology.c | 6 ++++++
topology/test/regress/topogeo_addpoint.sql | 4 ++++
topology/test/regress/topogeo_addpoint_expected | 3 +++
3 files changed, 13 insertions(+)
hooks/post-receive
