[postgis-tickets] [PostGIS] #4723: ST_ApproximateMedialAxis SFCGAL crash on windows
trac at osgeo.org
Wed Jul 15 08:35:26 PDT 2020
Reporter: robe | Owner: robe
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 3.0.2
Component: sfcgal | Version: 2.5.x
Resolution: | Keywords: windows
Comment (by robe):
Looks like it hasn't been fixed yet. Algunenano tested building from
sfcgal head (CGAL CGAL: 4.14.2) and he got the same crash.
His trace is here
Program terminated with signal SIGSEGV, Segmentation fault.
#0
CGAL::Straight_skeleton_builder_2<CGAL::Straight_skeleton_builder_traits_2<CGAL::Epick>,
CGAL::Straight_skeleton_2<CGAL::Epick, CGAL::Straight_skeleton_items_2,
std::allocator<int> >,
CGAL::Dummy_straight_skeleton_builder_2_visitor<CGAL::Straight_skeleton_2<CGAL::Epick,
CGAL::Straight_skeleton_items_2, std::allocator<int> > > >::GetTrisegment
(aV=..., this=0x7ffc871b3dc0) at
/usr/include/boost/smart_ptr/intrusive_ptr.hpp:191
191 T & operator*() const BOOST_SP_NOEXCEPT_WITH_ASSERT
(gdb) bt
#0
#1
>::AreSkeletonNodesCoincident (aY=..., aX=..., this=0x7ffc871b3dc0) at
/usr/include/CGAL/Straight_skeleton_builder_2.h:554
#2
>::MergeCoincidentNodes (this=this at entry=0x7ffc871b3dc0) at
/usr/include/CGAL/Straight_skeleton_2/Straight_skeleton_builder_2_impl.h:1713
#3 0x00007f87b4a61511 in
CGAL::Straight_skeleton_items_2, std::allocator<int> > > >::FinishUp
(this=0x7ffc871b3dc0) at /usr/include/c++/10.1.0/bits/stl_algo.h:3838
#4
CGAL::Straight_skeleton_items_2, std::allocator<int> > > >::Run
/usr/include/CGAL/Straight_skeleton_2/Straight_skeleton_builder_2_impl.h:1787
#5
>::construct_skeleton (this=this at entry=0x7ffc871b3dc0,
aNull_if_failed=aNull_if_failed at entry=true)
at
/usr/include/CGAL/Straight_skeleton_2/Straight_skeleton_builder_2_impl.h:1797
#6 0x00007f87b4a35085 in
CGAL::create_interior_straight_skeleton_2<__gnu_cxx::__normal_iterator<CGAL::Point_2<CGAL::Epeck>*,
std::vector<CGAL::Point_2<CGAL::Epeck>,
std::allocator<CGAL::Point_2<CGAL::Epeck> > > >,
std::_List_const_iterator<CGAL::Polygon_2<CGAL::Epeck,
std::allocator<CGAL::Point_2<CGAL::Epeck> > > > >, CGAL::Epick>
(aHolesEnd=..., aHolesBegin=..., aOuterContour_VerticesEnd=...,
aOuterContour_VerticesBegin=...)
at /usr/include/CGAL/create_straight_skeleton_2.h:84
#7 SFCGAL::algorithm::(anonymous namespace)::straightSkeleton (poly=...)
at /home/raul/.cache/yay/sfcgal-
git/src/sfcgal/src/algorithm/straightSkeleton.cpp:191
#8 0x00007f87b4a3662b in SFCGAL::algorithm::approximateMedialAxis (g=...)
git/src/sfcgal/src/algorithm/straightSkeleton.cpp:359
#9 0x00007f87b4ac10cc in sfcgal_geometry_approximate_medial_axis
(ga=0x55637a58ed30) at /home/raul/.cache/yay/sfcgal-
git/src/sfcgal/src/capi/sfcgal_c.cpp:782
#10 0x00007f87b50331f9 in sfcgal_approximate_medial_axis
(fcinfo=<optimized out>) at lwgeom_sfcgal.c:319
#11 0x00005563793c073d in ExecInterpExpr (state=<optimized out>,
econtext=<optimized out>, isnull=0x7ffc871b43df) at execExprInterp.c:649
#12 0x000055637948a67e in ExecEvalExprSwitchContext (state=0x55637a556a90,
econtext=0x55637a5458a0, isNull=0x7ffc871b43df) at
../../../../src/include/executor/executor.h:307
#13 evaluate_expr (expr=<optimized out>, result_type=11198173,
result_typmod=-1, result_collation=0) at clauses.c:4812
#14 0x000055637948b0fd in evaluate_function (funcid=12296625,
result_type=11198173, result_typmod=-1, result_collid=0, input_collid=0,
args=0x55637a5209c8, funcvariadic=<optimized out>, context=0x7ffc871b4750,
func_tuple=<optimized out>)
at clauses.c:4354
#15 simplify_function (funcid=<optimized out>, result_type=11198173,
result_typmod=-1, result_collid=0, input_collid=0, args_p=<optimized out>,
funcvariadic=<optimized out>, process_args=<optimized out>,
allow_non_const=true, context=0x7ffc871b4750)
at clauses.c:3984
#16 0x0000556379489523 in eval_const_expressions_mutator
(node=0x55637a51f988, context=0x7ffc871b4750) at clauses.c:2477
#17 0x0000556379420e39 in expression_tree_mutator (node=0x55637a51fa08,
mutator=0x5563794889c0 <eval_const_expressions_mutator>,
context=0x7ffc871b4750) at /usr/include/bits/string_fortified.h:34
#18 0x0000556379488acb in eval_const_expressions_mutator
(node=0x55637a51fa08, context=0x7ffc871b4750) at clauses.c:3539
#19 0x0000556379421116 in expression_tree_mutator (node=<optimized out>,
context=0x7ffc871b4750) at nodeFuncs.c:3012
#20 0x0000556379488acb in eval_const_expressions_mutator
(node=0x55637a51f9d8, context=0x7ffc871b4750) at clauses.c:3539
#21 0x00005563794889a0 in eval_const_expressions (root=<optimized out>,
node=0x55637a50c9f0) at clauses.c:2269
#22 0x0000556379471e3b in preprocess_expression (root=0x55637a51fb08,
expr=0x55637a5458a0, kind=1) at planner.c:1087
#23 subquery_planner (glob=<optimized out>, parse=0x55637a464d18,
parent_root=<optimized out>, hasRecursion=<optimized out>,
tuple_fraction=0) at planner.c:769
#24 0x000055637947143f in standard_planner (parse=0x55637a464d18,
cursorOptions=256, boundParams=0x0) at planner.c:406
#25 0x0000556379544e91 in pg_plan_query (querytree=0x55637a464d18,
cursorOptions=256, boundParams=0x0) at postgres.c:878
#26 pg_plan_queries (querytrees=<optimized out>, cursorOptions=256,
boundParams=0x0) at postgres.c:968
#27 0x00005563795491a4 in exec_simple_query (
query_string=0x55637a463580 "select
st_approximatemedialaxis(st_geomfromtext('MULTIPOLYGON(((55115 56075,55915
56075,55975 56075,55975 58675,56075 58675,56075 57425,57425 57425,57425
56075,58775 56075,60025 56075,61375 56075,6137"...)
at postgres.c:1143
#28 0x0000556379546ccb in PostgresMain (argc=<optimized out>,
argv=<optimized out>, dbname=<optimized out>, username=<optimized out>) at
postgres.c:4243
#29 0x00005563794b9686 in BackendRun (port=0x55637a489560) at
postmaster.c:4448
#30 0x00005563794b8cf4 in BackendStartup (port=0x55637a489560) at
postmaster.c:4139
#31 ServerLoop () at postmaster.c:1704
#32 0x00005563794b5cb6 in PostmasterMain (argc=3, argv=0x55637a45d2a0) at
postmaster.c:1377
#33 0x000055637941eea5 in main (argc=3, argv=0x55637a45d2a0) at main.c:228
(gdb)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4723#comment:3>
