[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-166-g2ae93c1
git at osgeo.org
git at osgeo.org
Sat Jul 18 12:59:34 PDT 2020
the project "PostGIS".
via 2ae93c1ff9588b5403575423b0a6a30552e216d2 (commit)
from f0b631a808d5e4bc0bf30055e2777e2649b8df0f (commit)
revisions in full, below.
commit 2ae93c1ff9588b5403575423b0a6a30552e216d2
Author: Regina Obe <lr at pcorp.us>
Date: Sat Jul 18 15:59:16 2020 -0400
Prep for PostGIS 3.1.0alpha2
diff --git a/NEWS b/NEWS
index a71acf8..2c3e48b 100644
--- a/NEWS
+++ b/NEWS
@@ -1,11 +1,8 @@
PostGIS 3.1.0alpha2
-2020/07/XX
+2020/07/18
Only tickets not included in 3.1.0alpha1
-* Breaking changes *
* New features *
- #4656, Cast a geojson_text::geometry for implicit GeoJSON ingestion (Raúl Marín)
- #4687, Expose GEOS MaximumInscribedCircle (Paul Ramsey)
diff --git a/README.md b/README.md
index 611c307..08ce090 100644
--- a/README.md
+++ b/README.md
@@ -18,7 +18,9 @@ Bessie:
Bessie32:
[](https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=bessie32/)
Berrie:
- [](https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=berrie/)
+ [](https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=berrie/)
+ Berrie64:
+ [](https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=berrie64/)
This file is here to play nicely with modern code repository facilities.
diff --git a/README.postgis b/README.postgis
index 8ebb0cd..8379a79 100644
--- a/README.postgis
+++ b/README.postgis
@@ -1,8 +1,8 @@
PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 3.1.0alpha1
-:Date: 2020-02-01
+:Version: 3.1.0alpha2
+:Date: 2020-07-18
:Website: https://postgis.net
This distribution contains a module which implements GIS simple features, ties
diff --git a/Version.config b/Version.config
index e618043..053257a 100644
--- a/Version.config
+++ b/Version.config
@@ -5,7 +5,7 @@
POSTGIS_MAJOR_VERSION=3
POSTGIS_MINOR_VERSION=1
-POSTGIS_MICRO_VERSION=0dev
+POSTGIS_MICRO_VERSION=0alpha2
# Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
# when changing POSTGIS_MINOR_VERSION
diff --git a/ci/winnie/build_postgis.sh b/ci/winnie/build_postgis.sh
index 41c96a4..561f2f4 100644
--- a/ci/winnie/build_postgis.sh
+++ b/ci/winnie/build_postgis.sh
@@ -1,11 +1,11 @@
#!/usr/bin/env bash
set -e
if [[ "${OVERRIDE}" == '' ]] ; then
- export GEOS_VER=3.8.0
- export GDAL_VER=2.4.3
+ export GEOS_VER=3.8.1
+ export GDAL_VER=2.4.4
export PROJ_VER=5.2.0
- export SFCGAL_VER=1.3.2
- export CGAL_VER=4.11
+ export SFCGAL_VER=1.3.8
+ export CGAL_VER=5.0.2
export ICON_VER=1.15
export ZLIB_VER=1.2.11
export PROTOBUF_VER=3.2.0
diff --git a/ci/winnie/package_postgis.sh b/ci/winnie/package_postgis.sh
index 34103fb..4e86959 100644
--- a/ci/winnie/package_postgis.sh
+++ b/ci/winnie/package_postgis.sh
@@ -16,8 +16,8 @@
#otherwise use the ones jenkins passes thru
#!/usr/bin/env bash
@@ -246,7 +246,7 @@ if [ -n "$SFCGAL_VER" ]; then
echo "SFCGAL VERSION: ${SFCGAL_VER} http://www.sfcgal.org https://github.com/Oslandia/SFCGAL" >> $verfile
fi;
-if [ -f ${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/gdal_depends.txt ]; then
+if [ -f ${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/gdal_depends.txt ]; then
cat $verfile ${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/gdal_depends.txt > $verfile
fi
#echo "PAGC ADDRESS STANDARDIZER: http://sourceforge.net/p/pagc/code/HEAD/tree/branches/sew-refactor/postgresql " >> $verfile
diff --git a/ci/winnie/regress_postgis.sh b/ci/winnie/regress_postgis.sh
index bb61cca..0934013 100644
--- a/ci/winnie/regress_postgis.sh
+++ b/ci/winnie/regress_postgis.sh
@@ -2,10 +2,10 @@
set -e
Summary of changes:
NEWS | 5 +----
README.md | 4 +++-
README.postgis | 4 ++--
Version.config | 2 +-
ci/winnie/build_postgis.sh | 8 ++++----
ci/winnie/package_postgis.sh | 6 +++---
ci/winnie/regress_postgis.sh | 6 +++---
7 files changed, 17 insertions(+), 18 deletions(-)
hooks/post-receive
