#4726: Garden hang on ST_VoronoiLines
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.1.0
Component: postgis | Version: master
Resolution: | Keywords:
Comment (by Algunenano):
Can confirm it hangs in current GEOS master / HEAD.
I've attached gdb to the process and it's doing stuff:
#0 0x00007fc3eacf126c in geos::triangulate::quadedge::Vertex::isCCW
(this=<optimized out>, b=..., c=...) at
../../../include/geos/triangulate/quadedge/Vertex.h:226
#1 geos::triangulate::quadedge::Vertex::rightOf (this=0x55bba48b9720,
e=...) at Vertex.cpp:83
#2 0x00007fc3eace807c in
geos::triangulate::IncrementalDelaunayTriangulator::insertSite
(this=<optimized out>, v=...) at IncrementalDelaunayTriangulator.cpp:90
#3 0x00007fc3eace7e4b in
geos::triangulate::IncrementalDelaunayTriangulator::insertSites
(this=0x7ffe3cf96408, vertices=...) at
IncrementalDelaunayTriangulator.cpp:40
#4 0x00007fc3eace9f5d in geos::triangulate::VoronoiDiagramBuilder::create
(this=0x7ffe3cf964b8) at VoronoiDiagramBuilder.cpp:93
#5 0x00007fc3eacea45b in
geos::triangulate::VoronoiDiagramBuilder::getDiagramEdges
(this=0x7ffe3cf964b8, geomFact=...) at VoronoiDiagramBuilder.cpp:122
#6 0x00007fc3eba9c83e in GEOSVoronoiDiagram_r::$_188::operator()
(this=<optimized out>) at geos_ts_c.cpp:3261
#7 execute<GEOSVoronoiDiagram_r::$_188,
(decltype(nullptr))0>(GEOSContextHandle_HS*,
GEOSVoronoiDiagram_r::$_188&&) (extHandle=0x55bba48b88b0, f=...) at
geos_ts_c.cpp:379
#8 GEOSVoronoiDiagram_r (extHandle=0x55bba48b88b0, g1=0x55bba48b6840,
env=0x55bba48e6f40, tolerance=20.100000000000001, onlyEdges=1) at
geos_ts_c.cpp:3253
#9 0x00007fc3ebc02ecb in lwgeom_voronoi_diagram (g=<optimized out>,
env=0x7ffe3cf965c0, tolerance=20.100000000000001,
output_edges=-1534355264) at lwgeom_geos.c:1926
#10 0x00007fc3ebb3267e in ST_Voronoi (fcinfo=0x55bba48fbb20) at
lwgeom_geos.c:3465
#11 0x000055bba3c126e1 in ExecInterpExpr (state=<optimized out>,
econtext=<optimized out>, isnull=0x7ffe3cf9675f) at execExprInterp.c:625
#12 0x000055bba3c45874 in ExecEvalExprSwitchContext (state=0x55bba48fba48,
econtext=0x55bba48fb770, isNull=0x7ffe3cf9675f) at
../../../src/include/executor/executor.h:307
(gdb) c
Continuing.
^C
Program received signal SIGINT, Interrupt.
geos::triangulate::quadedge::Vertex::isCCW (this=<optimized out>, b=...,
c=...) at ../../../include/geos/triangulate/quadedge/Vertex.h:227
227 > (b.p.y - p.y) * (c.p.x - p.x);
(gdb) bt
#0 geos::triangulate::quadedge::Vertex::isCCW (this=<optimized out>,
b=..., c=...) at ../../../include/geos/triangulate/quadedge/Vertex.h:227
#1 geos::triangulate::quadedge::Vertex::rightOf (this=0x55bba48b9ee0,
geos_ts_c.cpp:379
geos_ts_c.cpp:3253
lwgeom_geos.c:3465
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4726#comment:1>
