[postgis-tickets] [PostGIS] #4728: Remove UPDATE for pgis_abs from upgrade script
trac at osgeo.org
Thu Jul 23 18:24:01 PDT 2020
Reporter: khannaekta | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.5.5
Component: postgis | Version: 2.5.x
Resolution: fixed | Keywords:
Comment (by khannaekta):
Replying to [comment:1 strk]:
> No reason. Indeed the type is DROP in the same file, earlier.
> It was removed as per #4035 in 2.5.0. I'll drop that UPDATE. Good catch!
(how did you find out ?)
Thanks for the quick fix. I bumped int this when trying to upgrade from
2.1.5 -> 2.5.4 using `ALTER EXTENSION postgis UPDATE to '2.5.4';` and it
failed with the following error:
`ERROR: permission denied: "pg_type" is a system catalog`.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4728#comment:5>
