[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-7-ga714a46
git at osgeo.org
git at osgeo.org
Tue Jul 28 04:06:38 PDT 2020
the project "PostGIS".
via a714a468037fc30ce7b2a29db2bc02e0accda098 (commit)
from da2b1d8a0a5c3dd2d12fca0bc6d660f35a9c7be3 (commit)
revisions in full, below.
commit a714a468037fc30ce7b2a29db2bc02e0accda098
Author: Raúl Marín <git at rmr.ninja>
Date: Tue Jul 28 12:17:03 2020 +0200
Use finishGEOS to remove valgrind noise in unit tests
Closes https://github.com/postgis/postgis/pull/571
diff --git a/liblwgeom/cunit/cu_node.c b/liblwgeom/cunit/cu_node.c
index 1e16631..b97f1f3 100644
--- a/liblwgeom/cunit/cu_node.c
+++ b/liblwgeom/cunit/cu_node.c
@@ -15,6 +15,7 @@
#include "liblwgeom.h"
#include "liblwgeom_internal.h"
+#include "../lwgeom_geos.h"
static void test_lwgeom_node(void)
@@ -58,12 +59,19 @@ static void test_lwgeom_node(void)
lwfree(tmp); lwgeom_free(out); lwgeom_free(in);
+static int
+clean_geos_node_suite(void)
+ finishGEOS();
+ return 0;
** Used by test harness to register the tests in this file.
void node_suite_setup(void);
- CU_pSuite suite = CU_add_suite("noding", NULL, NULL);
+ CU_pSuite suite = CU_add_suite("noding", NULL, clean_geos_node_suite);
PG_ADD_TEST(suite, test_lwgeom_node);
diff --git a/liblwgeom/cunit/cu_split.c b/liblwgeom/cunit/cu_split.c
index 1e9e73b..6481c63 100644
--- a/liblwgeom/cunit/cu_split.c
+++ b/liblwgeom/cunit/cu_split.c
@@ -15,6 +15,7 @@
static void test_lwline_split_by_point_to(void)
@@ -274,6 +275,12 @@ static void test_lwgeom_split(void)
lwgeom_free(blade);
+static int
+clean_geos_split_suite(void)
+ finishGEOS();
+ return 0;
@@ -281,7 +288,7 @@ static void test_lwgeom_split(void)
void split_suite_setup(void);
- CU_pSuite suite = CU_add_suite("split", NULL, NULL);
+ CU_pSuite suite = CU_add_suite("split", NULL, clean_geos_split_suite);
PG_ADD_TEST(suite, test_lwline_split_by_point_to);
PG_ADD_TEST(suite, test_lwgeom_split);
diff --git a/liblwgeom/cunit/cu_triangulate.c b/liblwgeom/cunit/cu_triangulate.c
index b46ac90..45b8398 100644
--- a/liblwgeom/cunit/cu_triangulate.c
+++ b/liblwgeom/cunit/cu_triangulate.c
@@ -15,6 +15,7 @@
#include "cu_tester.h"
static void
test_lwgeom_delaunay_triangulation(void)
@@ -102,6 +103,13 @@ test_lwgeom_voronoi_diagram_expected_empty(void)
assert_empty_diagram("MULTIPOINT (0 0, 0 0.00001)", 0.001);
+static int
+clean_geos_triangulate_suite(void)
+ finishGEOS();
+ return 0;
@@ -109,7 +117,7 @@ void triangulate_suite_setup(void);
void
- CU_pSuite suite = CU_add_suite("triangulate", NULL, NULL);
+ CU_pSuite suite = CU_add_suite("triangulate", NULL, clean_geos_triangulate_suite);
PG_ADD_TEST(suite, test_lwgeom_delaunay_triangulation);
PG_ADD_TEST(suite, test_lwgeom_voronoi_diagram);
PG_ADD_TEST(suite, test_lwgeom_voronoi_diagram_expected_empty);
diff --git a/liblwgeom/cunit/cu_wrapx.c b/liblwgeom/cunit/cu_wrapx.c
index 9f246f3..78c757a 100644
--- a/liblwgeom/cunit/cu_wrapx.c
+++ b/liblwgeom/cunit/cu_wrapx.c
@@ -15,6 +15,7 @@
static void test_lwgeom_wrapx(void)
@@ -147,6 +148,12 @@ static void test_lwgeom_wrapx(void)
+static int
+clean_geos_wrapx_suite(void)
+ finishGEOS();
+ return 0;
@@ -154,6 +161,6 @@ static void test_lwgeom_wrapx(void)
void wrapx_suite_setup(void);
- CU_pSuite suite = CU_add_suite("wrapx", NULL, NULL);
+ CU_pSuite suite = CU_add_suite("wrapx", NULL, clean_geos_wrapx_suite);
PG_ADD_TEST(suite, test_lwgeom_wrapx);
Summary of changes:
liblwgeom/cunit/cu_node.c | 10 +++++++++-
liblwgeom/cunit/cu_split.c | 9 ++++++++-
liblwgeom/cunit/cu_triangulate.c | 10 +++++++++-
liblwgeom/cunit/cu_wrapx.c | 9 ++++++++-
4 files changed, 34 insertions(+), 4 deletions(-)
hooks/post-receive
