[postgis-tickets] [PostGIS] #4686: Faster bbox access for PG12+
trac at osgeo.org
Tue Jul 28 07:03:51 PDT 2020
Reporter: Algunenano | Owner: Algunenano
Type: enhancement | Status: assigned
Priority: medium | Milestone: PostGIS 3.1.0
Component: postgis | Version: master
Resolution: | Keywords:
Comment (by Algunenano):
PR: https://github.com/postgis/postgis/pull/572
Numbers:
* ANALYZE:
------------------ POINTS -------------------
-- ANALYZE benchmark_7773a711c8441d4b494a51fd9feebeac7a9b9c734619398620293
(the_geom, the_geom_webmercator);
-- Master: 116.324
-- Faster bbox: 117.262
-- Perf: 0.99x
---------------- BIG POLYGONS -------------------
-- ANALYZE benchmark_4c7214d90a79aa6760367a084a4d4a2f61fbe1c6cc4f7f9e76020
-- Master: 70.258
-- Faster bbox: 2.339
-- Perf: 30.03x
* ST_PointOutside:
-- EXPLAIN ANALYZE Select _ST_PointOutside(the_geog) from test_geog;
-- Master: 16.925
-- Faster bbox: 0.158
-- Perf: 107.12x
* ST_CombineBbox:
-------------- SMALL POLYGONS ---------------
EXPLAIN ANALYZE Select ST_CombineBbox(NULL::box2d, the_geom) from
benchmark_af85af967525e69373b7b8678f3bd409a8e78f447671344b7535d;
-- Master: 290.640
-- Faster bbox: 311.152
-- Perf: 0.93x
-- EXPLAIN ANALYZE Select ST_CombineBbox(NULL::box2d, the_geom) from
benchmark_4c7214d90a79aa6760367a084a4d4a2f61fbe1c6cc4f7f9e76020;
-- Master: 17.288
-- Faster bbox: 0.165
-- Perf: 104.77x
* ST_ClipByBox2D (fully inside):
-- EXPLAIN ANALYZE Select count(*) FROM
benchmark_af85af967525e69373b7b8678f3bd409a8e78f447671344b7535d WHERE
ST_ClipByBox2D(the_geom_webmercator, ST_TileEnvelope(0,0,0)) IS NOT NULL;
-- Master: 155.528
-- Faster bbox: 129.040
-- Perf: 1.21x
benchmark_4c7214d90a79aa6760367a084a4d4a2f61fbe1c6cc4f7f9e76020 WHERE
-- Master: 19.266
-- Faster bbox: 0.220
-- Perf: 87.39x
* ST_ClipByBox2D (fully outside):
ST_ClipByBox2D(the_geom_webmercator, ST_TileEnvelope(20,0,0)) IS NOT NULL;
-- Master: 171.451
-- Faster bbox: 147.365
-- Perf: 1.16x
-- Master: 19.265
-- Faster bbox: 0.226
-- Perf: 85.24x
* ST_BoundingDiagonal (fully outside):
-- EXPLAIN ANALYZE Select ST_BoundingDiagonal(the_geom) from
-- Master: 566.389
-- Faster bbox: 446.435
-- Perf: 1.26x
-- Master: 19.279
-- Faster bbox: 0.153
-- Perf: 126x
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4686#comment:3>
