[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-22-gf0822be
git at osgeo.org
git at osgeo.org
Wed Jul 29 05:14:08 PDT 2020
the project "PostGIS".
via f0822be70d65421df09f74cbc3d4cb54aac38985 (commit)
via 6a0627cdef29d5fc590fe6bbb73b92fd1a82da96 (commit)
from 90a15b199ff55e946281c7200e0930e28dfdd585 (commit)
revisions in full, below.
commit f0822be70d65421df09f74cbc3d4cb54aac38985
Author: Raúl Marín <git at rmr.ninja>
Date: Tue Jul 28 18:07:19 2020 +0200
Add precision parameter to ST_AsEWKT
Closes #4698
Closes https://github.com/postgis/postgis/pull/575
diff --git a/NEWS b/NEWS
index 4cfdb46..319f74b 100644
--- a/NEWS
+++ b/NEWS
@@ -3,7 +3,7 @@ PostGIS 3.1.0beta1
Only tickets not included in 3.1.0alpha2
* New features *
+ - #4698, Add a precision parameter to ST_AsEWKT (Raúl Marín)
* Enhancements *
- #4660, Changes in double / coordinate printing (Raúl Marín)
diff --git a/doc/reference_output.xml b/doc/reference_output.xml
index f64b992..b2dd96f 100644
--- a/doc/reference_output.xml
+++ b/doc/reference_output.xml
@@ -26,15 +26,26 @@
</funcprototype>
<funcprototype>
<funcdef>text <function>ST_AsEWKT</function></funcdef>
+ <paramdef><type>geometry </type> <parameter>g1</parameter></paramdef>
+ <paramdef choice="opt"><type>integer </type> <parameter>maxdecimaldigits=15</parameter></paramdef>
+ </funcprototype>
+ <funcprototype>
+ <funcdef>text <function>ST_AsEWKT</function></funcdef>
<paramdef><type>geography </type> <parameter>g1</parameter></paramdef>
</funcprototype>
+ <funcprototype>
+ <paramdef><type>geography </type> <parameter>g1</parameter></paramdef>
+ </funcprototype>
</funcsynopsis>
</refsynopsisdiv>
<refsection>
<title>Description</title>
- <para>Returns the Well-Known Text representation of the geometry prefixed with the SRID.</para>
+ <para>Returns the Well-Known Text representation of the geometry prefixed with the SRID. Optional argument may be used to reduce the maximum number
+ of decimal digits after floating point used in output (defaults to 15).</para>
<note>
<para>The WKT spec does not include the SRID. To get the OGC WKT format use ST_AsText.</para>
@@ -46,6 +57,7 @@
<para>ST_AsEWKT is the reverse of <xref linkend="ST_GeomFromEWKT" />. Use <xref linkend="ST_GeomFromEWKT" /> to convert to a postgis geometry from ST_AsEWKT representation.</para>
</note>
<para>Enhanced: 2.0.0 support for Geography, Polyhedral surfaces, Triangles and TIN was introduced.</para>
+ <para>Enhanced: 3.1.0 support for optional precision parameter.</para>
<para>&Z_support;</para>
<para>&curve_support;</para>
<para>&P_support;</para>
diff --git a/postgis/geography.sql.in b/postgis/geography.sql.in
index 6a2d3d9..7d7b6da 100644
--- a/postgis/geography.sql.in
+++ b/postgis/geography.sql.in
@@ -710,6 +710,12 @@ CREATE OR REPLACE FUNCTION ST_AsEWKT(geography)
LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
_COST_MEDIUM;
+CREATE OR REPLACE FUNCTION ST_AsEWKT(geography, int4)
+ RETURNS TEXT
+ AS 'MODULE_PATHNAME','LWGEOM_asEWKT'
+ LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
+ _COST_MEDIUM;
-- Availability: 2.0.0 - this is just a hack to prevent unknown from causing ambiguous name because of geography
CREATE OR REPLACE FUNCTION ST_AsEWKT(text)
RETURNS text AS
diff --git a/postgis/lwgeom_functions_basic.c b/postgis/lwgeom_functions_basic.c
index e6b76d8..1ed7942 100644
--- a/postgis/lwgeom_functions_basic.c
+++ b/postgis/lwgeom_functions_basic.c
@@ -2384,8 +2384,11 @@ Datum LWGEOM_asEWKT(PG_FUNCTION_ARGS)
GSERIALIZED *geom = PG_GETARG_GSERIALIZED_P(0);
LWGEOM *lwgeom = lwgeom_from_gserialized(geom);
- POSTGIS_DEBUG(2, "LWGEOM_asEWKT called.");
- PG_RETURN_TEXT_P(lwgeom_to_wkt_varlena(lwgeom, WKT_EXTENDED, OUT_DEFAULT_DECIMAL_DIGITS));
+ int precision = OUT_DEFAULT_DECIMAL_DIGITS;
+ if (PG_NARGS() > 1)
+ precision = PG_GETARG_INT32(1);
+ PG_RETURN_TEXT_P(lwgeom_to_wkt_varlena(lwgeom, WKT_EXTENDED, precision));
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 0dfa55e..8fcd15f 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -1549,6 +1549,13 @@ CREATE OR REPLACE FUNCTION ST_AsEWKT(geometry)
_COST_MEDIUM;
+-- Availability: 3.1.0
+CREATE OR REPLACE FUNCTION ST_AsEWKT(geometry, int4)
+ RETURNS TEXT
+ _COST_MEDIUM;
-- Availability: 2.2.0
CREATE OR REPLACE FUNCTION ST_AsTWKB(geom geometry, prec int4 default NULL, prec_z int4 default NULL, prec_m int4 default NULL, with_sizes boolean default NULL, with_boxes boolean default NULL)
RETURNS bytea
diff --git a/regress/core/out_geometry.sql b/regress/core/out_geometry.sql
index fdc9a5c..b8f41b9 100644
--- a/regress/core/out_geometry.sql
+++ b/regress/core/out_geometry.sql
@@ -166,3 +166,10 @@ SELECT 'pgcast_06',ST_AsText('((0,0),(0,1),(1,1),(1,0))'::polygon::geometry);
-- Precision
SELECT 'text_precision_01', ST_AsText(GeomFromEWKT('SRID=4326;POINT(111.1111111 1.1111111)'));
SELECT 'text_precision_02', ST_AsText(GeomFromEWKT('SRID=4326;POINT(111.1111111 1.1111111)'),2);
+-- ST_AsEWKT
+SELECT 'EWKT_' || i, ST_AsEWKT('SRID=4326;POINT(12345678.123456789 1)'::geometry, i)
+FROM generate_series(0, 20) AS t(i)
+ORDER BY i;
\ No newline at end of file
diff --git a/regress/core/out_geometry_expected b/regress/core/out_geometry_expected
index 4707206..13f0c88 100644
--- a/regress/core/out_geometry_expected
+++ b/regress/core/out_geometry_expected
@@ -90,3 +90,24 @@ pgcast_05|t
pgcast_06|POLYGON((0 0,0 1,1 1,1 0,0 0))
text_precision_01|POINT(111.1111111 1.1111111)
text_precision_02|POINT(111.11 1.11)
+EWKT_0|SRID=4326;POINT(12345678 1)
+EWKT_1|SRID=4326;POINT(12345678.1 1)
+EWKT_2|SRID=4326;POINT(12345678.12 1)
+EWKT_3|SRID=4326;POINT(12345678.123 1)
+EWKT_4|SRID=4326;POINT(12345678.1235 1)
+EWKT_5|SRID=4326;POINT(12345678.12346 1)
+EWKT_6|SRID=4326;POINT(12345678.123457 1)
+EWKT_7|SRID=4326;POINT(12345678.1234568 1)
+EWKT_8|SRID=4326;POINT(12345678.12345679 1)
+EWKT_9|SRID=4326;POINT(12345678.12345679 1)
+EWKT_10|SRID=4326;POINT(12345678.12345679 1)
+EWKT_11|SRID=4326;POINT(12345678.12345679 1)
+EWKT_12|SRID=4326;POINT(12345678.12345679 1)
+EWKT_13|SRID=4326;POINT(12345678.12345679 1)
+EWKT_14|SRID=4326;POINT(12345678.12345679 1)
+EWKT_15|SRID=4326;POINT(12345678.12345679 1)
+EWKT_16|SRID=4326;POINT(12345678.12345679 1)
+EWKT_17|SRID=4326;POINT(12345678.12345679 1)
+EWKT_18|SRID=4326;POINT(12345678.12345679 1)
+EWKT_19|SRID=4326;POINT(12345678.12345679 1)
+EWKT_20|SRID=4326;POINT(12345678.12345679 1)
commit 6a0627cdef29d5fc590fe6bbb73b92fd1a82da96
Date: Wed Jul 29 14:10:37 2020 +0200
Adapt regress tests to match Windows output
References #4660
diff --git a/regress/core/regress_buffer_params.sql b/regress/core/regress_buffer_params.sql
index a1bbe24..2e05a7f 100644
--- a/regress/core/regress_buffer_params.sql
+++ b/regress/core/regress_buffer_params.sql
@@ -5,8 +5,8 @@
-- Ouput is snapped to grid to account for small floating numbers
-- differences between architectures
-SELECT 'point quadsegs=2', ST_AsText(st_buffer('POINT(0 0)', 1, 'quad_segs=2'), 5);
-SELECT 'line quadsegs=2', ST_AsText(st_buffer('LINESTRING(0 0, 10 0)', 2, 'quad_segs=2'), 5);
+SELECT 'point quadsegs=2', ST_AsText(st_buffer('POINT(0 0)', 1, 'quad_segs=2'), 4);
+SELECT 'line quadsegs=2', ST_AsText(st_buffer('LINESTRING(0 0, 10 0)', 2, 'quad_segs=2'), 3);
SELECT 'line quadsegs=2 endcap=flat', ST_AsText(st_buffer('LINESTRING(0 0, 10 0)', 2, 'quad_segs=2 endcap=flat'), 5);
SELECT 'line quadsegs=2 endcap=butt', ST_AsText(st_buffer('LINESTRING(0 0, 10 0)', 2, 'quad_segs=2 endcap=butt'), 5);
SELECT 'line quadsegs=2 endcap=square', ST_AsText(st_buffer('LINESTRING(0 0, 10 0)', 2, 'quad_segs=2 endcap=square'), 5);
diff --git a/regress/core/regress_buffer_params_expected b/regress/core/regress_buffer_params_expected
index 27c1e9f..5eb856b 100644
--- a/regress/core/regress_buffer_params_expected
+++ b/regress/core/regress_buffer_params_expected
@@ -1,5 +1,5 @@
-point quadsegs=2|POLYGON((1 0,0.70711 -0.70711,1.61554e-15 -1,-0.70711 -0.70711,-1 -3.23109e-15,-0.70711 0.70711,-4.62459e-15 1,0.70711 0.70711,1 0))
-line quadsegs=2|POLYGON((10 2,11.41421 1.41421,12 0,11.41421 -1.41421,10 -2,0 -2,-1.41421 -1.41421,-2 2.44929e-16,-1.41421 1.41421,0 2,10 2))
+point quadsegs=2|POLYGON((1 0,0.7071 -0.7071,1.6155e-15 -1,-0.7071 -0.7071,-1 -3.2311e-15,-0.7071 0.7071,-4.6246e-15 1,0.7071 0.7071,1 0))
+line quadsegs=2|POLYGON((10 2,11.4142 1.4142,12 0,11.4142 -1.4142,10 -2,0 -2,-1.4142 -1.4142,-2 2.4493e-16,-1.4142 1.4142,0 2,10 2))
line quadsegs=2 endcap=flat|POLYGON((10 2,10 -2,0 -2,0 2,10 2))
line quadsegs=2 endcap=butt|POLYGON((10 2,10 -2,0 -2,0 2,10 2))
line quadsegs=2 endcap=square|POLYGON((10 2,12 2,12 -2,0 -2,-2 -2,-2 2,10 2))
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index 61078b3..a635345 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -794,7 +794,7 @@ SELECT '#2420.2', ST_AsText(ST_LineToCurve('LINESTRING(0 0,10 0,10 10,0 10)'));
SELECT '#2423', ST_AsText(ST_CurveToLine(ST_LineToCurve(
ST_Intersection(ST_Buffer(ST_Point(0,0),10),ST_MakeEnvelope(-10,0,10,10))
-), 4), 4);
+), 4), 3);
SELECT '#2424', ST_AsText(ST_SnapToGrid(ST_CurveToLine(
'MULTICURVE(COMPOUNDCURVE((0 0, 10 0),CIRCULARSTRING(10 0, 20 1, 30 10)))',
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index 917d374..0a60194 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -252,7 +252,7 @@ ERROR: invalid GML representation
#2412|LINESTRING(0 0,10 0,20 0)
#2420.1|LINESTRING(0 0,10 0,10 10,0 10,0 0)
#2420.2|LINESTRING(0 0,10 0,10 10,0 10)
-#2423|POLYGON((-10 0,-9.2388 3.8268,-7.0711 7.0711,-3.8268 9.2388,1.7157e-15 10,3.8268 9.2388,7.0711 7.0711,9.2388 3.8268,10 0,-10 0))
+#2423|POLYGON((-10 0,-9.239 3.827,-7.071 7.071,-3.827 9.239,1.716e-15 10,3.827 9.239,7.071 7.071,9.239 3.827,10 0,-10 0))
#2424|MULTILINESTRING((0 0,10 0,24 3,30 10))
#2427|POINT(-1 0)
#2168|5340.76237395|5340.76237395|0
Summary of changes:
NEWS | 2 +-
doc/reference_output.xml | 14 +++++++++++++-
postgis/geography.sql.in | 6 ++++++
postgis/lwgeom_functions_basic.c | 7 +++++--
postgis/postgis.sql.in | 7 +++++++
regress/core/out_geometry.sql | 7 +++++++
regress/core/out_geometry_expected | 21 +++++++++++++++++++++
regress/core/regress_buffer_params.sql | 4 ++--
regress/core/regress_buffer_params_expected | 4 ++--
regress/core/tickets.sql | 2 +-
regress/core/tickets_expected | 2 +-
11 files changed, 66 insertions(+), 10 deletions(-)
hooks/post-receive
