[postgis-tickets] [PostGIS] #4730: Overlay GEOS 3.9 regress failures
trac at osgeo.org
Wed Jul 29 14:54:43 PDT 2020
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.1.0
Component: postgis | Version: master
Resolution: | Keywords:
Description changed by robe:
Old description:
> Just a placeholder of what to fix:
> This is compiling against GEOS Head wit CMAKE windows 64-bit, mingw64,
> msys2 GCC 8.1.0
> With switches
> cmake -G "MSYS Makefiles" CMAKE_BUILD_TYPE=Release
> -DDISABLE_OVERLAYNG=OFF -DDISABLE_GEOS_INLINE=OFF -DBUILD_SHARED_LIBS=ON
> Creating database 'postgis_reg'
> Loading unpackaged components from /projects/postgis/postgis-
> git/regress/00-regress-install/share/contrib/postgis
> Loading PostGIS into 'postgis_reg'
> /projects/postgis/postgis-git/regress/00-regress-
> install/share/contrib/postgis/postgis.sql
> install/share/contrib/postgis/postgis_comments.sql
> install/share/contrib/postgis/spatial_ref_sys.sql
> PostgreSQL 13beta2 on x86_64-w64-mingw32, compiled by gcc.exe (x86_64
> -posix-seh-rev0, Built by MinGW-W64 project) 8.1.0, 64-bit
> Postgis 3.1.0dev - (3.1.0alpha2-5-gdcfb1258c) - 2020-07-29 21:47:14
> scripts 3.1.0dev 3.1.0alpha2-5-gdcfb1258c
> GEOS: 3.9.0-CAPI-1.14.0
> PROJ: 6.2.1
> Running tests
> ../loader/Point .............. ok in 1453 ms
> ../loader/PointM .............. ok in 1401 ms
> ../loader/PointZ .............. ok in 1390 ms
> ../loader/MultiPoint .............. ok in 1381 ms
> ../loader/MultiPointM .............. ok in 1370 ms
> ../loader/MultiPointZ .............. ok in 1337 ms
> ../loader/Arc .............. ok in 1391 ms
> ../loader/ArcM .............. ok in 1415 ms
> ../loader/ArcZ .............. ok in 1346 ms
> ../loader/Polygon .............. ok in 1331 ms
> ../loader/PolygonM .............. ok in 1324 ms
> ../loader/PolygonZ .............. ok in 1333 ms
> ../loader/TSTPolygon ......... ok in 1147 ms
> ../loader/TSIPolygon ......... ok in 1142 ms
> ../loader/TSTIPolygon ......... ok in 1152 ms
> ../loader/PointWithSchema ..... ok in 752 ms
> ../loader/NoTransPoint ......... ok in 1142 ms
> ../loader/NotReallyMultiPoint ......... ok in 943 ms
> ../loader/MultiToSinglePoint ......... ok in 1194 ms
> ../loader/ReprojectPts ........ ok in 1131 ms
> ../loader/ReprojectPtsD ..... ok in 777 ms
> ../loader/ReprojectPtsGeog ........ ok in 1162 ms
> ../loader/ReprojectPtsGeogD ........ ok in 1082 ms
> ../loader/Latin1 .... ok in 712 ms
> ../loader/Latin1-implicit .... ok in 482 ms
> ../loader/mfile .... ok in 708 ms
> ../dumper/mfiledmp ..... ok in 142 ms
> ../dumper/literalsrid ....... ok in 157 ms
> ../dumper/realtable ....... ok in 149 ms
> ../dumper/nullsintable ....... ok in 155 ms
> ../dumper/null3d ..... ok in 140 ms
> affine .. ok in 110 ms
> bestsrid .. ok in 97 ms
> binary .. ok in 222 ms
> boundary .. ok in 100 ms
> chaikin .. ok in 463 ms
> filterm .. ok in 94 ms
> cluster .. ok in 117 ms
> concave_hull .. ok in 228 ms
> ctors .. ok in 105 ms
> curvetoline .. ok in 95 ms
> dump .. ok in 101 ms
> dumppoints .. ok in 103 ms
> empty .. ok in 112 ms
> estimatedextent .. ok in 444 ms
> forcecurve .. ok in 99 ms
> geography .. ok in 196 ms
> geometric_median .. ok in 100 ms
> hausdorff .. ok in 99 ms
> in_geohash .. ok in 97 ms
> in_gml .. ok in 1058 ms
> in_kml .. ok in 212 ms
> in_encodedpolyline .. ok in 99 ms
> iscollection .. ok in 98 ms
> legacy .. ok in 438 ms
> long_xact .. ok in 411 ms
> lwgeom_regress .. ok in 152 ms
> measures .. ok in 121 ms
> minimum_bounding_circle .. ok in 95 ms
> normalize .. ok in 97 ms
> operators .. ok in 114 ms
> orientation .. ok in 102 ms
> out_geometry .. ok in 137 ms
> out_geography .. ok in 117 ms
> polygonize .. ok in 103 ms
> polyhedralsurface .. ok in 102 ms
> postgis_type_name .. ok in 162 ms
> quantize_coordinates .. ok in 97 ms
> regress .. ok in 198 ms
> regress_bdpoly .. ok in 102 ms
> regress_buffer_params .. ok in 101 ms
> regress_gist_index_nd .. ok in 580 ms
> regress_index .. ok in 937 ms
> regress_index_nulls .. ok in 394 ms
> regress_management .. ok in 253 ms
> regress_selectivity .. ok in 206 ms
> regress_lrs .. ok in 111 ms
> regress_ogc .. failed (diff expected obtained:
> /projects/postgis/tmp/3.1.0dev_pg13_geos3.9_gdal3.0.2w64/test_78_diff)
> --- regress_ogc_expected 2020-07-29 16:50:12.862035600 -0400
> +++ /projects/postgis/tmp/3.1.0dev_pg13_geos3.9_gdal3.0.2w64/test_78_out
> 2020-07-29 17:52:30.518387000 -0400
> @@ -89,9 +89,9 @@
> isvalid|f
> isvalid|t
> intersection|POINT(0 0)
> -difference|MULTILINESTRING((0 10,0 2),(0 -2,0 -10))
> +difference|MULTILINESTRING((0 -2,0 -10),(0 10,0 2))
> boundary|MULTILINESTRING((0 0,0 10,10 10,10 0,0 0),(2 2,2 4,4 4,4 2,2
> 2))
> -symdifference|GEOMETRYCOLLECTION(LINESTRING(2 2,4 4),LINESTRING(10 10,20
> 20),POLYGON((0 0,0 10,10 10,10 0,0 0),(4 4,2 4,2 2,4 2,4 4)))
> +symdifference|GEOMETRYCOLLECTION(POLYGON((0 10,10 10,10 0,0 0,0 10),(2
> 4,2 2,4 2,4 4,2 4)),LINESTRING(2 2,4 4),LINESTRING(10 10,20 20))
> issimple|t
> equals|t
> pointonsurface|t
> @@ -107,7 +107,7 @@
> intersects|f
> ST_GeometryN|LINESTRING(0 0,1 1)
> ST_NumGeometries|1
> -ST_Union1|POLYGON((0 0,0 1,0.5 1,0.5 1.5,1.5 1.5,1.5 0.5,1 0.5,1 0,0 0))
> +ST_Union1|POLYGON((0 1,0.5 1,0.5 1.5,1.5 1.5,1.5 0.5,1 0.5,1 0,0 0,0 1))
> ST_EndPoint1|POINT(2 2)
> ST_PointN1|POINT(1 1)
> ST_PointN2|POINT(2 2)
> regress_ogc_cover .. ok in 97 ms
> regress_ogc_prep .. ok in 107 ms
> regress_proj .. ok in 2967 ms
> relate .. ok in 185 ms
> remove_repeated_points .. ok in 98 ms
> removepoint .. ok in 101 ms
> reverse .. ok in 107 ms
> setpoint .. ok in 105 ms
> simplify .. ok in 101 ms
> simplifyvw .. ok in 100 ms
> size .. ok in 101 ms
> snaptogrid .. ok in 106 ms
> split .. failed (diff expected obtained:
> /projects/postgis/tmp/3.1.0dev_pg13_geos3.9_gdal3.0.2w64/test_91_diff)
> --- split_expected 2020-07-29 16:50:13.020034200 -0400
> +++ /projects/postgis/tmp/3.1.0dev_pg13_geos3.9_gdal3.0.2w64/test_91_out
> 2020-07-29 17:52:36.732479300 -0400
> @@ -6,25 +6,25 @@
> ERROR: ST_Split: Operation on mixed SRID geometries (LineString, 10) !=
> (LineString, 5)
> 4|SRID=10;GEOMETRYCOLLECTION(LINESTRING(0 0,10 0))
> 5|SRID=10;GEOMETRYCOLLECTION(LINESTRING(0 0,10 0))
> -6|SRID=10;GEOMETRYCOLLECTION(LINESTRING(0 0,5 0),LINESTRING(5 0,10 0))
> -7|SRID=10;GEOMETRYCOLLECTION(LINESTRING(0 0,5 0),LINESTRING(5 0,10 0,10
> 10,5 10),LINESTRING(5 10,0 10,0 20,5 20),LINESTRING(5 20,10 20))
> +6|SRID=10;GEOMETRYCOLLECTION(LINESTRING(0 0,5 0,10 0))
> +7|SRID=10;GEOMETRYCOLLECTION(LINESTRING(0 0,5 0,10 0,10 10,5 10,0 10,0
> 20,5 20,10 20))
> ERROR: Splitter line has linear intersection with input
> -20|SRID=12;GEOMETRYCOLLECTION(POLYGON((5 0,0 0,0 10,5 10,5
> 0)),POLYGON((5 10,10 10,10 0,5 0,5 10)))
> -21|SRID=12;GEOMETRYCOLLECTION(POLYGON((5 0,0 0,0 10,5 10,5 8,2 8,2 2,5
> 2,5 0)),POLYGON((5 10,10 10,10 0,5 0,5 2,8 2,8 8,5 8,5 10)))
> -22|SRID=12;GEOMETRYCOLLECTION(POLYGON((2 0,0 0,0 10,2 10,2
> 0)),POLYGON((2 10,10 10,10 0,2 0,2 10),(5 2,8 2,8 8,5 8,5 2)))
> -23|SRID=12;GEOMETRYCOLLECTION(POLYGON((5 0,0 0,0 10,5 10,5 8,2 8,2 6,5
> 6,5 4,2 4,2 2,5 2,5 0)),POLYGON((5 10,10 10,10 0,5 0,5 2,8 2,8 4,5 4,5
> 6,8 6,8 8,5 8,5 10)))
> -30|SRID=10;GEOMETRYCOLLECTION(LINESTRING(0 0,5 0),LINESTRING(5 0,10
> 0),LINESTRING(0 5,5 5),LINESTRING(5 5,10 5))
> -31|SRID=10;GEOMETRYCOLLECTION(LINESTRING(0 0,5 0),LINESTRING(5 0,10
> 0),LINESTRING(0 5,10 5))
> +20|SRID=12;GEOMETRYCOLLECTION(POLYGON((5 0,0 0,0 10,5 10,5
> 0)),POLYGON((5 0,5 10,10 10,10 0,5 0)))
> +21|SRID=12;GEOMETRYCOLLECTION(POLYGON((5 0,0 0,0 10,5 10,5 8,2 8,2 2,5
> 2,5 0)),POLYGON((5 0,5 2,8 2,8 8,5 8,5 10,10 10,10 0,5 0)))
> +22|SRID=12;GEOMETRYCOLLECTION(POLYGON((2 0,0 0,0 10,2 10,2
> 0)),POLYGON((2 0,2 10,10 10,10 0,2 0),(5 2,8 2,8 8,5 8,5 2)))
> +23|SRID=12;GEOMETRYCOLLECTION(POLYGON((5 0,0 0,0 10,5 10,5 8,2 8,2 6,5
> 6,5 4,2 4,2 2,5 2,5 0)),POLYGON((5 0,5 2,8 2,8 4,5 4,5 6,8 6,8 8,5 8,5
> +30|SRID=10;GEOMETRYCOLLECTION(LINESTRING(0 0,5 0,10 0),LINESTRING(0 5,5
> 5,10 5))
> +31|SRID=10;GEOMETRYCOLLECTION(LINESTRING(0 0,5 0,10 0),LINESTRING(0 5,10
> 5))
> 32|SRID=10;GEOMETRYCOLLECTION(LINESTRING(0 0,10 0),LINESTRING(0 5,10 5))
> 40|SRID=10;GEOMETRYCOLLECTION(LINESTRING(0 0,5 0),LINESTRING(5 0,10
> -50|SRID=12;GEOMETRYCOLLECTION(POLYGON((5 0,0 0,0 10,5 10,5 8,2 8,2 6,5
> 6,8 6,8 8,5 8,5 10)),POLYGON((20 0,20 10,30 10,30 0,20 0),(25 5,28 5,25
> 8,25 5)))
> -60|SRID=12;GEOMETRYCOLLECTION(POLYGON((5 0,0 0,0 10,5 10,5 8,2 8,2 6,5
> 8,25 5)),LINESTRING(0 0,5 0),LINESTRING(5 0,10 0),LINESTRING(0 5,5
> -70|SRID=11;GEOMETRYCOLLECTION(LINESTRING(1691983.26 4874594.81
> 312.24,1691984.86 4874593.69 312.24,1691982 4874589.60428571
> 312.24),LINESTRING(1691982 4874589.60428571 312.24,1691981.30515131
> 4874588.61164472 312.24),LINESTRING(1691981.30515131 4874588.61164472
> 312.24,1691979.54 4874586.09 312.24,1691978.03 4874587.16 298.36))
> +50|SRID=12;GEOMETRYCOLLECTION(POLYGON((5 0,0 0,0 10,5 10,5 8,2 8,2 6,5
> 10,10 10,10 0,5 0)),POLYGON((20 0,20 10,30 10,30 0,20 0),(25 5,28 5,25
> 8,25 5)))
> +60|SRID=12;GEOMETRYCOLLECTION(POLYGON((5 0,0 0,0 10,5 10,5 8,2 8,2 6,5
> 8,25 5)),LINESTRING(0 0,5 0,10 0),LINESTRING(0 5,5 5,10 5))
> +70|SRID=11;GEOMETRYCOLLECTION(LINESTRING(1691983.26 4874594.81
> 312.24,1691981.30515131 4874588.61164472 312.24,1691979.54 4874586.09
> 80|GEOMETRYCOLLECTION(LINESTRING(0 1,0 1,0 1))
> 81|GEOMETRYCOLLECTION(LINESTRING(0 1,0 1))
> 82|t
> -83|SRID=3;GEOMETRYCOLLECTION(LINESTRING(1 -1,1 0),LINESTRING(1 0,1 1))
> -84|SRID=3;GEOMETRYCOLLECTION(LINESTRING(1 -1,1 0),LINESTRING(1 0,1 1))
> -85|SRID=3;GEOMETRYCOLLECTION(LINESTRING(1 -2,1 -1),LINESTRING(1 -1,1 1,3
> 1),LINESTRING(3 1,4 1))
> +83|SRID=3;GEOMETRYCOLLECTION(LINESTRING(1 -1,1 0,1 1))
> +84|SRID=3;GEOMETRYCOLLECTION(LINESTRING(1 -1,1 0,1 1))
> +85|SRID=3;GEOMETRYCOLLECTION(LINESTRING(1 -2,1 -1,1 1,3 1,4 1))
> 86|SRID=3;GEOMETRYCOLLECTION(LINESTRING(8 0,10 0),LINESTRING(0 0,5
> 0),LINESTRING(5 0,8 0),LINESTRING(5 0,5 5),LINESTRING(5 -2,5
> 0),LINESTRING(5 -5,5 -2),LINESTRING(8 20,10 20),LINESTRING(2 20,5
> 20),LINESTRING(0 20,2 20),LINESTRING(5 20,8 20))
> sql-mm-serialize .. ok in 138 ms
> sql-mm-circularstring .. ok in 158 ms
> sql-mm-compoundcurve .. ok in 168 ms
> sql-mm-curvepoly .. ok in 164 ms
> sql-mm-general .. ok in 98 ms
> sql-mm-multicurve .. ok in 161 ms
> sql-mm-multisurface .. ok in 151 ms
> swapordinates .. ok in 104 ms
> summary .. ok in 97 ms
> temporal .. ok in 106 ms
> temporal_knn .. ok in 148 ms
> tickets .. failed (diff expected obtained:
> /projects/postgis/tmp/3.1.0dev_pg13_geos3.9_gdal3.0.2w64/test_103_diff)
> --- tickets_expected 2020-07-29 16:50:13.183034800 -0400
> +++ /projects/postgis/tmp/3.1.0dev_pg13_geos3.9_gdal3.0.2w64/test_103_out
> 2020-07-29 17:52:44.202877700 -0400
> @@ -1,4 +1,4 @@
> -#2|POLYGON((1 1,1 2,2 2,3 2,3 1,2 1,1 1))
> +#2|POLYGON((1 2,2 2,3 2,3 1,2 1,1 1,1 2))
> #11|0
> #21|SRID=31293;MULTIPOINTM(6220.13 5337367.145 4566)
> t
> @@ -128,7 +128,7 @@
> #723|f
> #804|<gml:Point srsName="urn:ogc:def:crs:EPSG::4326"><gml:pos
> srsDimension="2">0 0</gml:pos></gml:Point>
> #845|t
> -#834|GEOMETRYCOLLECTION(POINT(0 0 5),LINESTRING(10 10 5,10 0 5))
> +#834|LINESTRING(10 10,10 0)
> #884|1|f
> #884|2|t
> #938|
> @@ -236,7 +236,7 @@
> #2110.3|t
> #2145|6792004
> #2232|M 0 0 l 0 0 1 0 0 0 1 0 0 0
> -#2307|MULTIPOLYGON(((-41.1932 -7.3257,-41.1616 -7.3257,-41.1569
> -7.3257,-41.1569 -7.3483,-41.1932 -7.3483,-41.1932 -7.3257),(-41.1616
> -7.3257,-41.1879 -7.3257,-41.1879 -7.3425,-41.1616 -7.3425,-41.1616
> -7.3257)))
> +#2307|MULTIPOLYGON(((-41.1616 -7.3257,-41.1569 -7.3257,-41.1569
> -7.3483,-41.1932 -7.3483,-41.1932 -7.3257,-41.1616 -7.3257),(-41.1616
> -7.3257)))
> #2409|GeometryCollection[B] with 2 elements:
> MultiSurface[] with 2 elements:
> Polygon[] with 1 ring:
> @@ -252,7 +252,7 @@
> #2412|LINESTRING(0 0,10 0,20 0)
> #2420.1|LINESTRING(0 0,10 0,10 10,0 10,0 0)
> #2420.2|LINESTRING(0 0,10 0,10 10,0 10)
> -#2423|POLYGON((-10 0,-9.2388 3.82683,-7.07107 7.07107,-3.82683 9.2388,0
> 10,3.82683 9.2388,7.07107 7.07107,9.2388 3.82683,10 0,-10 0))
> +#2423|POLYGON((-9.80785 1.9509,-8.3147 5.5557,-5.5557 8.3147,-1.9509
> 9.80785,1.9509 9.80785,5.5557 8.3147,8.3147 5.5557,9.80785 1.9509,10
> 0,-10 0,-9.80785 1.9509))
> #2424|MULTILINESTRING((0 0,10 0,24 3,30 10))
> #2427|POINT(-1 0)
> #2168|5340.76237395|5340.76237395|0
> @@ -327,10 +327,10 @@
> #4011|ST_MultiLineString|MULTILINESTRING EMPTY|t|t
> #4011|ST_GeometryCollection|MULTILINESTRING((0 0,0 0))|f|f
> #4025|
> -ERROR: lwgeom_intersection: GEOS Error: TopologyException: Input geom 0
> is invalid: Self-intersection
> -ERROR: lwgeom_difference: GEOS Error: TopologyException: Input geom 0
> -ERROR: lwgeom_symdifference: GEOS Error: TopologyException: Input geom
> 0 is invalid: Self-intersection
> -ERROR: lwgeom_union: GEOS Error: TopologyException: Input geom 0 is
> +ERROR: lwgeom_intersection: GEOS Error: TopologyException: side
> location conflict at 5 5
> +ERROR: lwgeom_difference: GEOS Error: TopologyException: side location
> conflict at 5 5
> +ERROR: lwgeom_symdifference: GEOS Error: TopologyException: side
> +ERROR: lwgeom_union: GEOS Error: TopologyException: side location
> conflict at 5 5
> #4055a|4326
> #4055b|4326
> #4089|LINESTRING Z (1 1 1,3 3 1)
> twkb .. ok in 113 ms
> typmod .. ok in 18169 ms
> wkb .. ok in 140 ms
> wkt .. ok in 133 ms
> wmsservers .. ok in 270 ms
> offsetcurve .. ok in 115 ms
> relatematch .. ok in 100 ms
> isvaliddetail .. ok in 106 ms
> sharedpaths .. ok in 115 ms
> snap .. ok in 98 ms
> node .. ok in 103 ms
> unaryunion .. failed (diff expected obtained:
> /projects/postgis/tmp/3.1.0dev_pg13_geos3.9_gdal3.0.2w64/test_115_diff)
> --- unaryunion_expected 2020-07-29 16:50:13.215036100 -0400
> +++ /projects/postgis/tmp/3.1.0dev_pg13_geos3.9_gdal3.0.2w64/test_115_out
> 2020-07-29 17:53:05.655517100 -0400
> @@ -1,3 +1,3 @@
> -1|MULTILINESTRING((0 0,5 0),(5 0,10 0),(5 -5,5 0),(5 0,5 5))
> -2|POLYGON((10 5,10 0,0 0,0 10,5 10,5 15,15 15,15 5,10 5))
> -3|GEOMETRYCOLLECTION(POINT(-5 4),LINESTRING(2 -10,2 0),LINESTRING(2 10,2
> 20),POLYGON((10 5,10 0,2 0,0 0,0 10,2 10,5 10,5 15,15 15,15 5,10 5)))
> +1|MULTILINESTRING((0 0,5 0),(5 -5,5 0),(5 0,5 5),(5 0,10 0))
> +2|POLYGON((0 10,5 10,5 15,15 15,15 5,10 5,10 0,0 0,0 10))
> +3|GEOMETRYCOLLECTION(POINT(-5 4),POLYGON((0 0,0 10,2 10,5 10,5 15,15
> 15,15 5,10 5,10 0,2 0,0 0)),LINESTRING(2 -10,2 0),LINESTRING(2 10,2 20))
> clean .. failed (diff expected obtained:
> /projects/postgis/tmp/3.1.0dev_pg13_geos3.9_gdal3.0.2w64/test_116_diff)
> --- clean_expected 2020-07-29 16:50:12.265596300 -0400
> +++ /projects/postgis/tmp/3.1.0dev_pg13_geos3.9_gdal3.0.2w64/test_116_out
> 2020-07-29 17:53:05.979517300 -0400
> @@ -27,5 +27,5 @@
> RT|16.4|t|t|f
> RT|17.1|t|t|f
> #1719.1|POINT(0 0)
> -#1719.2|GEOMETRYCOLLECTION(POINT(0 0),MULTIPOINT(3 4,5 2),POINT(4
> 4),MULTIPOLYGON(((0 0,5 5,10 0,0 0)),((5 5,0 10,10 10,5 5))))
> +#1719.2|GEOMETRYCOLLECTION(POINT(0 0),MULTIPOINT(3 4,5 2),POINT(4
> 4),MULTIPOLYGON(((5 5,10 0,0 0,5 5)),((5 5,0 10,10 10,5 5))))
> #1719.3|MULTIPOINT(3 4,5 2)
> relate_bnr .. ok in 243 ms
> delaunaytriangles .. ok in 105 ms
> clipbybox2d .. ok in 114 ms
> subdivide .. failed (diff expected obtained:
> /projects/postgis/tmp/3.1.0dev_pg13_geos3.9_gdal3.0.2w64/test_120_diff)
> --- subdivide_expected 2020-07-29 16:50:13.105035200 -0400
> +++ /projects/postgis/tmp/3.1.0dev_pg13_geos3.9_gdal3.0.2w64/test_120_out
> 2020-07-29 17:53:11.565273800 -0400
> @@ -4,7 +4,7 @@
> ERROR: lwgeom_subdivide: cannot subdivide to fewer than 5 vertices per
> output
> #3522|POINT(1 1)
> #3744|1600000000000000
> -4|29321996468.6|29321996468.6|1857|256
> +4|29321996468.6|29321996468.6|1856|256
> #4211|0.00008316000
> #4217|0.00002463668
> #4301|0.00213614552
> voronoi .. ok in 115 ms
> regress_brin_index .. ok in 598 ms
> regress_brin_index_3d .. ok in 440 ms
> regress_brin_index_geography .. ok in 222 ms
> minimum_clearance .. ok in 105 ms
> oriented_envelope .. ok in 97 ms
> point_coordinates .. ok in 107 ms
> out_geojson .. ok in 145 ms
> frechet .. ok in 102 ms
> geos38 .. ok in 98 ms
> geos39 .. ok in 106 ms
> in_geojson .. ok in 121 ms
> regress_spgist_index_2d .. ok in 335 ms
> regress_spgist_index_3d .. ok in 667 ms
> regress_spgist_index_nd .. ok in 680 ms
> mvt .. ok in 231 ms
> mvt_jsonb .. ok in 102 ms
> geobuf .. ok in 105 ms
> uninstall . /projects/postgis/postgis-git/regress/00-regress-
> install/share/contrib/postgis/uninstall_postgis.sql
> . ok (4831)
> Run tests: 139
> Failed: 6
> make[2]: *** [Makefile:237: check] Error 6
> make[2]: Leaving directory '/projects/postgis/postgis-git/regress/core'
> make[1]: *** [Makefile:47: check-regress] Error 2
> make[1]: Leaving directory '/projects/postgis/postgis-git/regress'
> make: *** [GNUmakefile:20: check-regress] Error 1
New description:
msys2 GCC 8.1.0
With switches
PROJ: 6.2.1
Running tests
@@ -89,9 +89,9 @@
isvalid|f
isvalid|t
boundary|MULTILINESTRING((0 0,0 10,10 10,10 0,0 0),(2 2,2 4,4 4,4 2,2 2))
issimple|t
equals|t
pointonsurface|t
@@ -107,7 +107,7 @@
intersects|f
ST_NumGeometries|1
@@ -6,25 +6,25 @@
(LineString, 5)
20,5 20,10 20))
-20|SRID=12;GEOMETRYCOLLECTION(POLYGON((5 0,0 0,0 10,5 10,5 0)),POLYGON((5
-22|SRID=12;GEOMETRYCOLLECTION(POLYGON((2 0,0 0,0 10,2 10,2 0)),POLYGON((2
6,5 4,2 4,2 2,5 2,5 0)),POLYGON((5 10,10 10,10 0,5 0,5 2,8 2,8 4,5 4,5 6,8
6,8 8,5 8,5 10)))
+20|SRID=12;GEOMETRYCOLLECTION(POLYGON((5 0,0 0,0 10,5 10,5 0)),POLYGON((5
+22|SRID=12;GEOMETRYCOLLECTION(POLYGON((2 0,0 0,0 10,2 10,2 0)),POLYGON((2
5,10 5))
5))
6,8 8,5 8,5 10)),POLYGON((20 0,20 10,30 10,30 0,20 0),(25 5,28 5,25 8,25
5)))
8,25 5)))
82|t
@@ -1,4 +1,4 @@
#11|0
t
@@ -128,7 +128,7 @@
#723|f
#845|t
#884|1|f
#884|2|t
#938|
@@ -236,7 +236,7 @@
#2110.3|t
#2145|6792004
-7.3257)))
-7.3257)))
@@ -252,7 +252,7 @@
9.80785,1.9509 9.80785,5.5557 8.3147,8.3147 5.5557,9.80785 1.9509,10 0,-10
0,-9.80785 1.9509))
#2427|POINT(-1 0)
#4025|
-ERROR: lwgeom_difference: GEOS Error: TopologyException: Input geom 0 is
-ERROR: lwgeom_symdifference: GEOS Error: TopologyException: Input geom 0
+ERROR: lwgeom_intersection: GEOS Error: TopologyException: side location
conflict at 5 5
conflict at 5 5
conflict at 5 5
#4055a|4326
#4055b|4326
wkb .. ok in 140 ms
wkt .. ok in 133 ms
snap .. ok in 98 ms
@@ -1,3 +1,3 @@
@@ -27,5 +27,5 @@
RT|16.4|t|t|f
RT|17.1|t|t|f
#1719.1|POINT(0 0)
@@ -4,7 +4,7 @@
output
#3522|POINT(1 1)
#4211|0.00008316000
#4217|0.00002463668
#4301|0.00213614552
mvt .. ok in 231 ms
. ok (4831)
Run tests: 139
Failed: 6
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4730#comment:1>
