[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-25-g5a37d81
git at osgeo.org
git at osgeo.org
Wed Jul 29 18:07:39 PDT 2020
the project "PostGIS".
via 5a37d81ad14b7eeb3a41732ca49bfc0e41ec307e (commit)
from a41108ffac49d726ec13b3420ba3e08a43ef94f8 (commit)
revisions in full, below.
commit 5a37d81ad14b7eeb3a41732ca49bfc0e41ec307e
Author: Regina Obe <lr at pcorp.us>
Date: Wed Jul 29 21:07:30 2020 -0400
Address some geos3.9 overlay failures by normalizing - references #4730 for postgis 3.1.0
diff --git a/regress/core/regress_ogc.sql b/regress/core/regress_ogc.sql
index 4c70348..12f5e56 100644
--- a/regress/core/regress_ogc.sql
+++ b/regress/core/regress_ogc.sql
@@ -158,9 +158,9 @@ SELECT 'isvalid', ST_isvalid('POLYGON((0 0, 0 10, 10 10, 10 0, 0 0))'::geometry)
SELECT 'isvalid', ST_isvalid('POLYGON((0 0, 0 10, 10 10, -5 10, 10 0, 0 0))'::geometry);
SELECT 'isvalid', ST_isvalid('GEOMETRYCOLLECTION EMPTY'::geometry);
SELECT 'intersection', ST_astext(ST_intersection('LINESTRING(0 10, 0 -10)'::geometry, 'LINESTRING(0 0, 1 1)'::geometry));
-SELECT 'difference', ST_astext(ST_difference('LINESTRING(0 10, 0 -10)'::GEOMETRY, 'LINESTRING(0 2, 0 -2)'::GEOMETRY));
+SELECT 'difference', ST_astext(ST_Normalize(ST_difference('LINESTRING(0 10, 0 -10)'::GEOMETRY, 'LINESTRING(0 2, 0 -2)'::GEOMETRY)));
SELECT 'boundary', ST_astext(ST_boundary('POLYGON((0 0, 0 10, 10 10, 10 0, 0 0),(2 2, 2 4, 4 4, 4 2, 2 2))'::geometry));
-SELECT 'symdifference', ST_astext(ST_symdifference('POLYGON((0 0, 0 10, 10 10, 10 0, 0 0),(2 2, 2 4, 4 4, 4 2, 2 2))'::geometry, 'LINESTRING(0 0, 20 20)'::geometry));
+SELECT 'symdifference', ST_astext(ST_Normalize(ST_symdifference('POLYGON((0 0, 0 10, 10 10, 10 0, 0 0),(2 2, 2 4, 4 4, 4 2, 2 2))'::geometry, 'LINESTRING(0 0, 20 20)'::geometry)));
SELECT 'issimple', ST_issimple('POLYGON((0 0, 0 10, 10 10, 10 0, 0 0),(2 2, 2 4, 4 4, 4 2, 2 2))'::geometry);
SELECT 'equals', ST_equals('LINESTRING(0 0, 1 1)'::geometry, 'LINESTRING(1 1, 0 0)'::geometry);
WITH inp AS ( SELECT
@@ -188,7 +188,7 @@ select 'intersects', ST_intersects(
select 'ST_GeometryN', ST_asewkt(ST_GeometryN('LINESTRING(0 0, 1 1)'::geometry, 1));
select 'ST_NumGeometries', ST_NumGeometries('LINESTRING(0 0, 1 1)'::geometry);
-select 'ST_Union1', ST_AsText(ST_Union(ARRAY['POLYGON((0 0, 0 1, 1 1, 1 0, 0 0))'::geometry, 'POLYGON((0.5 0.5, 1.5 0.5, 1.5 1.5, 0.5 1.5, 0.5 0.5))'::geometry]));
+select 'ST_Union1', ST_AsText(ST_Normalize(ST_Union(ARRAY['POLYGON((0 0, 0 1, 1 1, 1 0, 0 0))'::geometry, 'POLYGON((0.5 0.5, 1.5 0.5, 1.5 1.5, 0.5 1.5, 0.5 0.5))'::geometry])));
select 'ST_EndPoint1', ST_AsText(ST_Endpoint('LINESTRING(0 0, 1 1, 2 2)'::geometry));
select 'ST_PointN1', ST_AsText(ST_PointN('LINESTRING(0 0, 1 1, 2 2)'::geometry,2));
select 'ST_PointN2', ST_AsText(ST_PointN('LINESTRING(0 0, 1 1, 2 2)'::geometry,3));
@@ -208,4 +208,4 @@ select 'ST_StartPoint1',ST_AsText(ST_StartPoint('LINESTRING(0 0, 1 1, 2 2)'::geo
select 'ST_StartPoint2',ST_AsText(ST_StartPoint('CIRCULARSTRING(2 2, 1 1, 1 0)'::geometry));
select 'ST_StartPoint3',ST_AsText(ST_StartPoint('COMPOUNDCURVE(CIRCULARSTRING(3 3, 1 1, 1 0),(1 0, 0 1))'::geometry));
select 'ST_StartPoint4',ST_AsText(ST_StartPoint('CURVEPOLYGON(CIRCULARSTRING(5 5, 4 0, 4 4, 0 4, 5 5),(1 1, 3 3, 3 1, 1 1))'::geometry));
-select 'ST_StartPoint5',ST_AsText(ST_StartPoint('POLYGON((0 0, 1 1, 0 1, 0 0))'::geometry));
\ No newline at end of file
+select 'ST_StartPoint5',ST_AsText(ST_StartPoint('POLYGON((0 0, 1 1, 0 1, 0 0))'::geometry));
diff --git a/regress/core/regress_ogc_expected b/regress/core/regress_ogc_expected
index 835710e..c574735 100644
--- a/regress/core/regress_ogc_expected
+++ b/regress/core/regress_ogc_expected
@@ -89,9 +89,9 @@ NOTICE: Self-intersection
isvalid|f
isvalid|t
intersection|POINT(0 0)
-difference|MULTILINESTRING((0 10,0 2),(0 -2,0 -10))
+difference|MULTILINESTRING((0 2,0 10),(0 -10,0 -2))
boundary|MULTILINESTRING((0 0,0 10,10 10,10 0,0 0),(2 2,2 4,4 4,4 2,2 2))
-symdifference|GEOMETRYCOLLECTION(LINESTRING(2 2,4 4),LINESTRING(10 10,20 20),POLYGON((0 0,0 10,10 10,10 0,0 0),(4 4,2 4,2 2,4 2,4 4)))
+symdifference|GEOMETRYCOLLECTION(POLYGON((0 0,0 10,10 10,10 0,0 0),(2 2,4 2,4 4,2 4,2 2)),LINESTRING(10 10,20 20),LINESTRING(2 2,4 4))
issimple|t
equals|t
pointonsurface|t
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index a635345..fb6cda3 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -5,7 +5,7 @@
SET client_min_messages TO NOTICE;
-- #2 --
-SELECT '#2', ST_AsText(ST_Union(g)) FROM
+SELECT '#2', ST_AsText(ST_Normalize(ST_Union(g)) ) FROM
( VALUES
('SRID=4326;MULTIPOLYGON(((1 1,1 2,2 2,2 1,1 1)))'),
('SRID=4326;MULTIPOLYGON(((2 1,3 1,3 2,2 2,2 1)))')
@@ -776,7 +776,7 @@ round(ST_Length(St_Segmentize(ST_GeographyFromText('LINESTRING(-89.3000030518 28
SELECT '#2232', ST_AsSVG('LINESTRING(0 0, 0.4 0, 0.8 0, 1.2 0,1.6 0, 2 0)'::geometry,1,0);
-- #2307 --
-SELECT '#2307', ST_AsText(ST_MakeValid('0106000020E6100000010000000103000000010000000A0000004B7DA956B99844C0DB0790FE8B4D1DC010BA74A9AF9444C049AFFC5B8C4D1DC03FC6CC690D9844C0DD67E5628C4D1DC07117B56B0D9844C0C80ABA67C45E1DC0839166ABAF9444C0387D4568C45E1DC010BA74A9AF9444C049AFFC5B8C4D1DC040C3CD74169444C0362EC0608C4D1DC07C1A3B77169444C0DC3ADB40B2641DC03AAE5F68B99844C0242948DEB1641DC04B7DA956B99844C0DB0790FE8B4D1DC0'::geometry),4);
+SELECT '#2307', ST_AsText(ST_Normalize(ST_MakeValid('0106000020E6100000010000000103000000010000000A0000004B7DA956B99844C0DB0790FE8B4D1DC010BA74A9AF9444C049AFFC5B8C4D1DC03FC6CC690D9844C0DD67E5628C4D1DC07117B56B0D9844C0C80ABA67C45E1DC0839166ABAF9444C0387D4568C45E1DC010BA74A9AF9444C049AFFC5B8C4D1DC040C3CD74169444C0362EC0608C4D1DC07C1A3B77169444C0DC3ADB40B2641DC03AAE5F68B99844C0242948DEB1641DC04B7DA956B99844C0DB0790FE8B4D1DC0'::geometry)),4);
SELECT '#2409', ST_Summary('GEOMETRYCOLLECTION(MULTISURFACE(POLYGON((0 0, 0 1, 1 1, 1 0, 0 0)),CURVEPOLYGON(COMPOUNDCURVE((0 0, 0 1, 1 1, 1 0, 0 0),CIRCULARSTRING(0 0, 0 1, 1 1, 1 2, 0 0)))),TIN(((0 0, 0 1, 1 1, 0 0))))'::geometry);
@@ -792,9 +792,9 @@ SELECT '#2412', ST_AsText(ST_LineToCurve('LINESTRING(0 0,10 0,20 0)'));
SELECT '#2420.1', ST_AsText(ST_LineToCurve('LINESTRING(0 0,10 0,10 10,0 10,0 0)'));
SELECT '#2420.2', ST_AsText(ST_LineToCurve('LINESTRING(0 0,10 0,10 10,0 10)'));
-SELECT '#2423', ST_AsText(ST_CurveToLine(ST_LineToCurve(
+SELECT '#2423', ST_AsText(ST_Normalize(ST_CurveToLine(ST_LineToCurve(
ST_Intersection(ST_Buffer(ST_Point(0,0),10),ST_MakeEnvelope(-10,0,10,10))
-), 4), 3);
+), 4)), 3);
SELECT '#2424', ST_AsText(ST_SnapToGrid(ST_CurveToLine(
'MULTICURVE(COMPOUNDCURVE((0 0, 10 0),CIRCULARSTRING(10 0, 20 1, 30 10)))',
@@ -1294,4 +1294,4 @@ SELECT '#4670-1', ST_AsEWKT(ST_AddPoint('LINESTRING(0 0, 1 1, 3 3, 4 4)'::geomet
SELECT '#4670-2', ST_AsEWKT(ST_AddPoint('LINESTRING(0 0, 1 1, 3 3, 4 4)'::geometry, 'POINT(2 2)'::geometry, 2));
SELECT '#4670-3', ST_AsEWKT(ST_AddPoint('LINESTRING(0 0, 1 1, 3 3, 4 4)'::geometry, 'POINT(2 2)'::geometry, 3));
SELECT '#4670-4', ST_AsEWKT(ST_AddPoint('LINESTRING(0 0, 1 1, 3 3, 4 4)'::geometry, 'POINT(2 2)'::geometry, 4));
-SELECT '#4670-5', ST_AsEWKT(ST_AddPoint('LINESTRING(0 0, 1 1, 3 3, 4 4)'::geometry, 'POINT(2 2)'::geometry, 5));
+SELECT '#4670-5', ST_AsEWKT(ST_AddPoint('LINESTRING(0 0, 1 1, 3 3, 4 4)'::geometry, 'POINT(2 2)'::geometry, 5));
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index 0a60194..a495b41 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -236,7 +236,7 @@ ERROR: invalid GML representation
#2110.3|t
#2145|6792004
#2232|M 0 0 l 0 0 1 0 0 0 1 0 0 0
-#2307|MULTIPOLYGON(((-41.1932 -7.3257,-41.1616 -7.3257,-41.1569 -7.3257,-41.1569 -7.3483,-41.1932 -7.3483,-41.1932 -7.3257),(-41.1616 -7.3257,-41.1879 -7.3257,-41.1879 -7.3425,-41.1616 -7.3425,-41.1616 -7.3257)))
+#2307|MULTIPOLYGON(((-41.1932 -7.3483,-41.1932 -7.3257,-41.1616 -7.3257,-41.1569 -7.3257,-41.1569 -7.3483,-41.1932 -7.3483),(-41.1879 -7.3425,-41.1616 -7.3425,-41.1616 -7.3257,-41.1879 -7.3257,-41.1879 -7.3425)))
#2409|GeometryCollection[B] with 2 elements:
MultiSurface[] with 2 elements:
Polygon[] with 1 ring:
@@ -252,7 +252,7 @@ ERROR: invalid GML representation
#2412|LINESTRING(0 0,10 0,20 0)
#2420.1|LINESTRING(0 0,10 0,10 10,0 10,0 0)
#2420.2|LINESTRING(0 0,10 0,10 10,0 10)
-#2423|POLYGON((-10 0,-9.239 3.827,-7.071 7.071,-3.827 9.239,1.716e-15 10,3.827 9.239,7.071 7.071,9.239 3.827,10 0,-10 0))
+#2423|POLYGON((-10 0,-9.239 3.827,-7.071 7.071,-3.827 9.239,0 10,3.827 9.239,7.071 7.071,9.239 3.827,10 0,-10 0))
#2424|MULTILINESTRING((0 0,10 0,24 3,30 10))
#2427|POINT(-1 0)
#2168|5340.76237395|5340.76237395|0
Summary of changes:
regress/core/regress_ogc.sql | 8 ++++----
regress/core/regress_ogc_expected | 4 ++--
regress/core/tickets.sql | 10 +++++-----
regress/core/tickets_expected | 4 ++--
4 files changed, 13 insertions(+), 13 deletions(-)
hooks/post-receive
