[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-31-g2a7ebd0
Thu Jul 30 07:50:55 PDT 2020
the project "PostGIS".
       via  2a7ebd0111b02aed3aa24752aad0ba89aef5d431 (commit)
       via  eb88a3359bcfc93f8ae795d1e8d11cf906730c6d (commit)
      from  0d0cd34136dee1b3f6f6f13747f85f2664a965d8 (commit)
revisions in full, below.
commit 2a7ebd0111b02aed3aa24752aad0ba89aef5d431
Author: Raúl Marín <git at rmr.ninja>
Date:   Thu Jul 30 15:23:45 2020 +0200
    Address valgrind warnings in regress tests
    Closes #4654
diff --git a/liblwgeom/gbox.c b/liblwgeom/gbox.c
index 141f3c2..8df7038 100644
--- a/liblwgeom/gbox.c
+++ b/liblwgeom/gbox.c
@@ -647,7 +647,7 @@ ptarray_calculate_gbox_cartesian(const POINTARRAY *pa, GBOX *gbox)
 static int lwcircstring_calculate_gbox_cartesian(LWCIRCSTRING *curve, GBOX *gbox)
-	GBOX tmp;
+	GBOX tmp = {0};
 	POINT4D p1, p2, p3;
 	uint32_t i;
@@ -704,7 +704,7 @@ static int lwpoly_calculate_gbox_cartesian(LWPOLY *poly, GBOX *gbox)
 static int lwcollection_calculate_gbox_cartesian(LWCOLLECTION *coll, GBOX *gbox)
-	GBOX subbox;
+	GBOX subbox = {0};
 	uint32_t i;
 	int result = LW_FAILURE;
 	int first = LW_TRUE;
diff --git a/liblwgeom/gserialized.c b/liblwgeom/gserialized.c
index e90a6d4..bed0386 100644
--- a/liblwgeom/gserialized.c
+++ b/liblwgeom/gserialized.c
@@ -312,7 +312,7 @@ inline static int gserialized_cmp_srid(const GSERIALIZED *g1, const GSERIALIZED
 /* ORDER BY hash(g), g::bytea, ST_SRID(g), hasz(g), hasm(g) */
 int gserialized_cmp(const GSERIALIZED *g1, const GSERIALIZED *g2)
-	GBOX box1, box2;
+	GBOX box1 = {0}, box2 = {0};
 	uint64_t hash1, hash2;
 	size_t sz1 = LWSIZE_GET(g1->size);
 	size_t sz2 = LWSIZE_GET(g2->size);
diff --git a/liblwgeom/lwalgorithm.c b/liblwgeom/lwalgorithm.c
index dcd6f14..eb9feba 100644
--- a/liblwgeom/lwalgorithm.c
+++ b/liblwgeom/lwalgorithm.c
@@ -857,8 +857,8 @@ int lwgeom_geohash_precision(GBOX bbox, GBOX *bounds)
 lwvarlena_t *
 lwgeom_geohash(const LWGEOM *lwgeom, int precision)
-	GBOX gbox;
-	GBOX gbox_bounds;
+	GBOX gbox = {0};
+	GBOX gbox_bounds = {0};
 	double lat, lon;
 	int result;
diff --git a/liblwgeom/lwgeodetic.c b/liblwgeom/lwgeodetic.c
index 602054c..1409f29 100644
--- a/liblwgeom/lwgeodetic.c
+++ b/liblwgeom/lwgeodetic.c
@@ -2992,7 +2992,7 @@ static int lwtriangle_calculate_gbox_geodetic(const LWTRIANGLE *triangle, GBOX *
 static int lwcollection_calculate_gbox_geodetic(const LWCOLLECTION *coll, GBOX *gbox)
-	GBOX subbox;
 	uint32_t i;
diff --git a/liblwgeom/lwout_geojson.c b/liblwgeom/lwout_geojson.c
index d13939a..a427e99 100644
--- a/liblwgeom/lwout_geojson.c
+++ b/liblwgeom/lwout_geojson.c
@@ -50,7 +50,7 @@ lwgeom_to_geojson(const LWGEOM *geom, const char *srs, int precision, int has_bb
 	int type = geom->type;
 	GBOX *bbox = NULL;
-	GBOX tmp;
+	GBOX tmp = {0};
 	if (has_bbox)
diff --git a/postgis/gserialized_estimate.c b/postgis/gserialized_estimate.c
index 21b3ccc..56d0ab6 100644
--- a/postgis/gserialized_estimate.c
+++ b/postgis/gserialized_estimate.c
@@ -1440,7 +1440,7 @@ compute_gserialized_stats_mode(VacAttrStats *stats, AnalyzeAttrFetchFunc fetchfu
 	for ( i = 0; i < sample_rows; i++ )
 		Datum datum;
-		GBOX gbox;
+		GBOX gbox = {0};
 		ND_BOX *nd_box;
 		bool is_null;
diff --git a/postgis/gserialized_gist_2d.c b/postgis/gserialized_gist_2d.c
index 1dc159d..202ba25 100644
--- a/postgis/gserialized_gist_2d.c
+++ b/postgis/gserialized_gist_2d.c
@@ -509,7 +509,7 @@ gserialized_datum_get_gbox_p(Datum gsdatum, GBOX *gbox)
 int
 gserialized_datum_get_box2df_p(Datum gsdatum, BOX2DF *box2df)
-	GBOX gbox;
+	GBOX gbox = {0};
 	if (gserialized_datum_get_gbox_p(gsdatum, &gbox) == LW_FAILURE)
 		return LW_FAILURE;
diff --git a/postgis/lwgeom_in_gml.c b/postgis/lwgeom_in_gml.c
index 1a5eecf..f5028c6 100644
--- a/postgis/lwgeom_in_gml.c
+++ b/postgis/lwgeom_in_gml.c
@@ -588,7 +588,7 @@ static POINTARRAY* parse_gml_coordinates(xmlNodePtr xnode, bool *hasz)
 	int gml_dims;
 	char *p, *q;
 	bool digit;
-	POINT4D pt;
+	POINT4D pt = {0};
 	/* We begin to retrieve coordinates string */
 	gml_coord = xmlNodeGetContent(xnode);
@@ -702,7 +702,7 @@ static POINTARRAY* parse_gml_coord(xmlNodePtr xnode, bool *hasz)
 	POINTARRAY *dpa;
 	bool x,y,z;
 	xmlChar *c;
-	POINT4D p;
+	POINT4D p = {0};
 	/* HasZ?, !HasM, 1 Point */
 	dpa = ptarray_construct_empty(1, 0, 1);
diff --git a/postgis/lwgeom_in_kml.c b/postgis/lwgeom_in_kml.c
index 0688918..d398751 100644
--- a/postgis/lwgeom_in_kml.c
+++ b/postgis/lwgeom_in_kml.c
@@ -108,8 +108,6 @@ Datum geom_from_kml(PG_FUNCTION_ARGS)
 		lwgeom = hlwgeom;
-	lwgeom_add_bbox(lwgeom);
 	/* KML geometries could be either 2 or 3D
 	 * So we deal with 3D in all structures allocation, and flag hasz
commit eb88a3359bcfc93f8ae795d1e8d11cf906730c6d
Date:   Thu Jul 30 14:28:01 2020 +0200
    Adapt output to work with Raspberry
    References #4660
diff --git a/regress/core/sql-mm-circularstring.sql b/regress/core/sql-mm-circularstring.sql
index 9898c16..0790022 100644
--- a/regress/core/sql-mm-circularstring.sql
+++ b/regress/core/sql-mm-circularstring.sql
@@ -188,10 +188,10 @@ SELECT 'ST_CurveToLine-402', ST_AsText(ST_CurveToLine(the_geom_3dm, 4), 3) FROM
 SELECT 'ST_CurveToLine-403', ST_AsText(ST_CurveToLine(the_geom_3dz, 4), 3) FROM public.circularstring;
 SELECT 'ST_CurveToLine-404', ST_AsText(ST_CurveToLine(the_geom_4d, 4), 3) FROM public.circularstring;
-SELECT 'ST_CurveToLine01', ST_AsText(ST_CurveToLine(the_geom_2d), 3) FROM public.circularstring;
-SELECT 'ST_CurveToLine02', ST_AsText(ST_CurveToLine(the_geom_3dm), 3) FROM public.circularstring;
-SELECT 'ST_CurveToLine03', ST_AsText(ST_CurveToLine(the_geom_3dz), 3) FROM public.circularstring;
-SELECT 'ST_CurveToLine04', ST_AsText(ST_CurveToLine(the_geom_4d), 3) FROM public.circularstring;
+SELECT 'ST_CurveToLine01', ST_AsText(ST_CurveToLine(the_geom_2d), 2) FROM public.circularstring;
+SELECT 'ST_CurveToLine02', ST_AsText(ST_CurveToLine(the_geom_3dm), 2) FROM public.circularstring;
+SELECT 'ST_CurveToLine03', ST_AsText(ST_CurveToLine(the_geom_3dz), 2) FROM public.circularstring;
+SELECT 'ST_CurveToLine04', ST_AsText(ST_CurveToLine(the_geom_4d), 2) FROM public.circularstring;
 -- TODO: ST_SnapToGrid is required to remove platform dependent precision
 -- issues.  Until ST_SnapToGrid is updated to work against curves, these
diff --git a/regress/core/sql-mm-circularstring_expected b/regress/core/sql-mm-circularstring_expected
index 5a31f78..8c1fda2 100644
--- a/regress/core/sql-mm-circularstring_expected
+++ b/regress/core/sql-mm-circularstring_expected
@@ -60,14 +60,14 @@ ST_CurveToLine-403|LINESTRING Z (0 0 0,0.152 0.765 2.25,0.586 1.414 1)
 ST_CurveToLine-403|LINESTRING Z (-5 0 0,-4.619 1.913 0.25,-3.536 3.536 0.5,-1.913 4.619 0.75,3.062e-16 5 1,1.913 4.619 1.25,3.536 3.536 1.5,4.619 1.913 1.75,5 0 2,5.381 -1.913 2.25,6.464 -3.536 2.5,8.087 -4.619 2.75,10 -5 3,11.913 -4.619 3.25,13.536 -3.536 3.5,14.619 -1.913 3.75,15 0 4)
 ST_CurveToLine-404|LINESTRING ZM (0 0 0 0,0.152 0.765 2.25 -1.5,0.586 1.414 1 2)
 ST_CurveToLine-404|LINESTRING ZM (-5 0 0 4,-4.619 1.913 0.25 3.75,-3.536 3.536 0.5 3.5,-1.913 4.619 0.75 3.25,3.062e-16 5 1 3,1.913 4.619 1.25 2.75,3.536 3.536 1.5 2.5,4.619 1.913 1.75 2.25,5 0 2 2,5.381 -1.913 2.25 1.75,6.464 -3.536 2.5 1.5,8.087 -4.619 2.75 1.25,10 -5 3 1,11.913 -4.619 3.25 0.75,13.536 -3.536 3.5 0.5,14.619 -1.913 3.75 0.25,15 0 4 0)
-ST_CurveToLine01|LINESTRING(0 0,0.002 0.098,0.01 0.196,0.022 0.293,0.038 0.39,0.06 0.486,0.086 0.581,0.117 0.674,0.152 0.765,0.192 0.855,0.236 0.943,0.285 1.028,0.337 1.111,0.394 1.191,0.454 1.269,0.518 1.343,0.586 1.414)
-ST_CurveToLine01|LINESTRING(-5 0,-4.994 0.245,-4.976 0.49,-4.946 0.734,-4.904 0.975,-4.85 1.215,-4.785 1.451,-4.708 1.684,-4.619 1.913,-4.52 2.138,-4.41 2.357,-4.289 2.571,-4.157 2.778,-4.016 2.978,-3.865 3.172,-3.705 3.358,-3.536 3.536,-3.358 3.705,-3.172 3.865,-2.978 4.016,-2.778 4.157,-2.571 4.289,-2.357 4.41,-2.138 4.52,-1.913 4.619,-1.684 4.708,-1.451 4.785,-1.215 4.85,-0.975 4.904,-0.734 4.946,-0.49 4.976,-0.245 4.994,3.062e-16 5,0.245 4.994,0.49 4.976,0.734 4.946,0.975 4.904,1.215 4.85,1.451 4.785,1.684 4.708,1.913 4.619,2.138 4.52,2.357 4.41,2.571 4.289,2.778 4.157,2.978 4.016,3.172 3.865,3.358 3.705,3.536 3.536,3.705 3.358,3.865 3.172,4.016 2.978,4.157 2.778,4.289 2.571,4.41 2.357,4.52 2.138,4.619 1.913,4.708 1.684,4.785 1.451,4.85 1.215,4.904 0.975,4.946 0.734,4.976 0.49,4.994 0.245,5 0,5.006 -0.245,5.024 -0.49,5.054 -0.734,5.096 -0.975,5.15 -1.215,5.215 -1.451,5.292 -1.684,5.381 -1.913,5.48 -2.138,5.59 -2.357,5.711 -2.571,5.843 -2.778,5.984 -2.978,6.135 -3.172,6.295 -3.35
 8,6.464 -3.536,6.642 -3.705,6.828 -3.865,7.022 -4.016,7.222 -4.157,7.429 -4.289,7.643 -4.41,7.862 -4.52,8.087 -4.619,8.316 -4.708,8.549 -4.785,8.785 -4.85,9.025 -4.904,9.266 -4.946,9.51 -4.976,9.755 -4.994,10 -5,10.245 -4.994,10.49 -4.976,10.734 -4.946,10.975 -4.904,11.215 -4.85,11.451 -4.785,11.684 -4.708,11.913 -4.619,12.138 -4.52,12.357 -4.41,12.571 -4.289,12.778 -4.157,12.978 -4.016,13.172 -3.865,13.358 -3.705,13.536 -3.536,13.705 -3.358,13.865 -3.172,14.016 -2.978,14.157 -2.778,14.289 -2.571,14.41 -2.357,14.52 -2.138,14.619 -1.913,14.708 -1.684,14.785 -1.451,14.85 -1.215,14.904 -0.975,14.946 -0.734,14.976 -0.49,14.994 -0.245,15 0)
-ST_CurveToLine02|LINESTRING M (0 0 0,0.002 0.098 -0.187,0.01 0.196 -0.375,0.022 0.293 -0.562,0.038 0.39 -0.75,0.06 0.486 -0.938,0.086 0.581 -1.125,0.117 0.674 -1.313,0.152 0.765 -1.5,0.192 0.855 -1.687,0.236 0.943 -1.875,0.285 1.028 -1.75,0.337 1.111 -1,0.394 1.191 -0.25,0.454 1.269 0.5,0.518 1.343 1.25,0.586 1.414 2)
-ST_CurveToLine02|LINESTRING M (-5 0 4,-4.994 0.245 3.969,-4.976 0.49 3.938,-4.946 0.734 3.906,-4.904 0.975 3.875,-4.85 1.215 3.844,-4.785 1.451 3.812,-4.708 1.684 3.781,-4.619 1.913 3.75,-4.52 2.138 3.719,-4.41 2.357 3.688,-4.289 2.571 3.656,-4.157 2.778 3.625,-4.016 2.978 3.594,-3.865 3.172 3.562,-3.705 3.358 3.531,-3.536 3.536 3.5,-3.358 3.705 3.469,-3.172 3.865 3.438,-2.978 4.016 3.406,-2.778 4.157 3.375,-2.571 4.289 3.344,-2.357 4.41 3.312,-2.138 4.52 3.281,-1.913 4.619 3.25,-1.684 4.708 3.219,-1.451 4.785 3.188,-1.215 4.85 3.156,-0.975 4.904 3.125,-0.734 4.946 3.094,-0.49 4.976 3.062,-0.245 4.994 3.031,3.062e-16 5 3,0.245 4.994 2.969,0.49 4.976 2.938,0.734 4.946 2.906,0.975 4.904 2.875,1.215 4.85 2.844,1.451 4.785 2.812,1.684 4.708 2.781,1.913 4.619 2.75,2.138 4.52 2.719,2.357 4.41 2.688,2.571 4.289 2.656,2.778 4.157 2.625,2.978 4.016 2.594,3.172 3.865 2.562,3.358 3.705 2.531,3.536 3.536 2.5,3.705 3.358 2.469,3.865 3.172 2.438,4.016 2.978 2.406,4.157 2.778 2.375,4.289 2.571 2.3
 44,4.41 2.357 2.312,4.52 2.138 2.281,4.619 1.913 2.25,4.708 1.684 2.219,4.785 1.451 2.188,4.85 1.215 2.156,4.904 0.975 2.125,4.946 0.734 2.094,4.976 0.49 2.062,4.994 0.245 2.031,5 0 2,5.006 -0.245 1.969,5.024 -0.49 1.938,5.054 -0.734 1.906,5.096 -0.975 1.875,5.15 -1.215 1.844,5.215 -1.451 1.812,5.292 -1.684 1.781,5.381 -1.913 1.75,5.48 -2.138 1.719,5.59 -2.357 1.688,5.711 -2.571 1.656,5.843 -2.778 1.625,5.984 -2.978 1.594,6.135 -3.172 1.562,6.295 -3.358 1.531,6.464 -3.536 1.5,6.642 -3.705 1.469,6.828 -3.865 1.438,7.022 -4.016 1.406,7.222 -4.157 1.375,7.429 -4.289 1.344,7.643 -4.41 1.312,7.862 -4.52 1.281,8.087 -4.619 1.25,8.316 -4.708 1.219,8.549 -4.785 1.188,8.785 -4.85 1.156,9.025 -4.904 1.125,9.266 -4.946 1.094,9.51 -4.976 1.062,9.755 -4.994 1.031,10 -5 1,10.245 -4.994 0.969,10.49 -4.976 0.938,10.734 -4.946 0.906,10.975 -4.904 0.875,11.215 -4.85 0.844,11.451 -4.785 0.813,11.684 -4.708 0.781,11.913 -4.619 0.75,12.138 -4.52 0.719,12.357 -4.41 0.688,12.571 -4.289 0.656,12.778 -4.157
  0.625,12.978 -4.016 0.594,13.172 -3.865 0.563,13.358 -3.705 0.531,13.536 -3.536 0.5,13.705 -3.358 0.469,13.865 -3.172 0.437,14.016 -2.978 0.406,14.157 -2.778 0.375,14.289 -2.571 0.344,14.41 -2.357 0.313,14.52 -2.138 0.281,14.619 -1.913 0.25,14.708 -1.684 0.219,14.785 -1.451 0.187,14.85 -1.215 0.156,14.904 -0.975 0.125,14.946 -0.734 0.094,14.976 -0.49 0.062,14.994 -0.245 0.031,15 0 0)
-ST_CurveToLine03|LINESTRING Z (0 0 0,0.002 0.098 0.281,0.01 0.196 0.563,0.022 0.293 0.844,0.038 0.39 1.125,0.06 0.486 1.406,0.086 0.581 1.687,0.117 0.674 1.969,0.152 0.765 2.25,0.192 0.855 2.531,0.236 0.943 2.813,0.285 1.028 2.875,0.337 1.111 2.5,0.394 1.191 2.125,0.454 1.269 1.75,0.518 1.343 1.375,0.586 1.414 1)
-ST_CurveToLine03|LINESTRING Z (-5 0 0,-4.994 0.245 0.031,-4.976 0.49 0.063,-4.946 0.734 0.094,-4.904 0.975 0.125,-4.85 1.215 0.156,-4.785 1.451 0.187,-4.708 1.684 0.219,-4.619 1.913 0.25,-4.52 2.138 0.281,-4.41 2.357 0.313,-4.289 2.571 0.344,-4.157 2.778 0.375,-4.016 2.978 0.406,-3.865 3.172 0.437,-3.705 3.358 0.469,-3.536 3.536 0.5,-3.358 3.705 0.531,-3.172 3.865 0.563,-2.978 4.016 0.594,-2.778 4.157 0.625,-2.571 4.289 0.656,-2.357 4.41 0.687,-2.138 4.52 0.719,-1.913 4.619 0.75,-1.684 4.708 0.781,-1.451 4.785 0.813,-1.215 4.85 0.844,-0.975 4.904 0.875,-0.734 4.946 0.906,-0.49 4.976 0.937,-0.245 4.994 0.969,3.062e-16 5 1,0.245 4.994 1.031,0.49 4.976 1.062,0.734 4.946 1.094,0.975 4.904 1.125,1.215 4.85 1.156,1.451 4.785 1.188,1.684 4.708 1.219,1.913 4.619 1.25,2.138 4.52 1.281,2.357 4.41 1.312,2.571 4.289 1.344,2.778 4.157 1.375,2.978 4.016 1.406,3.172 3.865 1.438,3.358 3.705 1.469,3.536 3.536 1.5,3.705 3.358 1.531,3.865 3.172 1.562,4.016 2.978 1.594,4.157 2.778 1.625,4.289 2.571 1.6
 56,4.41 2.357 1.688,4.52 2.138 1.719,4.619 1.913 1.75,4.708 1.684 1.781,4.785 1.451 1.812,4.85 1.215 1.844,4.904 0.975 1.875,4.946 0.734 1.906,4.976 0.49 1.938,4.994 0.245 1.969,5 0 2,5.006 -0.245 2.031,5.024 -0.49 2.062,5.054 -0.734 2.094,5.096 -0.975 2.125,5.15 -1.215 2.156,5.215 -1.451 2.188,5.292 -1.684 2.219,5.381 -1.913 2.25,5.48 -2.138 2.281,5.59 -2.357 2.312,5.711 -2.571 2.344,5.843 -2.778 2.375,5.984 -2.978 2.406,6.135 -3.172 2.438,6.295 -3.358 2.469,6.464 -3.536 2.5,6.642 -3.705 2.531,6.828 -3.865 2.562,7.022 -4.016 2.594,7.222 -4.157 2.625,7.429 -4.289 2.656,7.643 -4.41 2.688,7.862 -4.52 2.719,8.087 -4.619 2.75,8.316 -4.708 2.781,8.549 -4.785 2.812,8.785 -4.85 2.844,9.025 -4.904 2.875,9.266 -4.946 2.906,9.51 -4.976 2.938,9.755 -4.994 2.969,10 -5 3,10.245 -4.994 3.031,10.49 -4.976 3.062,10.734 -4.946 3.094,10.975 -4.904 3.125,11.215 -4.85 3.156,11.451 -4.785 3.188,11.684 -4.708 3.219,11.913 -4.619 3.25,12.138 -4.52 3.281,12.357 -4.41 3.312,12.571 -4.289 3.344,12.778 -4.157
  3.375,12.978 -4.016 3.406,13.172 -3.865 3.437,13.358 -3.705 3.469,13.536 -3.536 3.5,13.705 -3.358 3.531,13.865 -3.172 3.563,14.016 -2.978 3.594,14.157 -2.778 3.625,14.289 -2.571 3.656,14.41 -2.357 3.688,14.52 -2.138 3.719,14.619 -1.913 3.75,14.708 -1.684 3.781,14.785 -1.451 3.812,14.85 -1.215 3.844,14.904 -0.975 3.875,14.946 -0.734 3.906,14.976 -0.49 3.938,14.994 -0.245 3.969,15 0 4)
-ST_CurveToLine04|LINESTRING ZM (0 0 0 0,0.002 0.098 0.281 -0.187,0.01 0.196 0.563 -0.375,0.022 0.293 0.844 -0.562,0.038 0.39 1.125 -0.75,0.06 0.486 1.406 -0.938,0.086 0.581 1.687 -1.125,0.117 0.674 1.969 -1.313,0.152 0.765 2.25 -1.5,0.192 0.855 2.531 -1.687,0.236 0.943 2.813 -1.875,0.285 1.028 2.875 -1.75,0.337 1.111 2.5 -1,0.394 1.191 2.125 -0.25,0.454 1.269 1.75 0.5,0.518 1.343 1.375 1.25,0.586 1.414 1 2)
-ST_CurveToLine04|LINESTRING ZM (-5 0 0 4,-4.994 0.245 0.031 3.969,-4.976 0.49 0.063 3.938,-4.946 0.734 0.094 3.906,-4.904 0.975 0.125 3.875,-4.85 1.215 0.156 3.844,-4.785 1.451 0.187 3.812,-4.708 1.684 0.219 3.781,-4.619 1.913 0.25 3.75,-4.52 2.138 0.281 3.719,-4.41 2.357 0.313 3.688,-4.289 2.571 0.344 3.656,-4.157 2.778 0.375 3.625,-4.016 2.978 0.406 3.594,-3.865 3.172 0.437 3.562,-3.705 3.358 0.469 3.531,-3.536 3.536 0.5 3.5,-3.358 3.705 0.531 3.469,-3.172 3.865 0.563 3.438,-2.978 4.016 0.594 3.406,-2.778 4.157 0.625 3.375,-2.571 4.289 0.656 3.344,-2.357 4.41 0.687 3.312,-2.138 4.52 0.719 3.281,-1.913 4.619 0.75 3.25,-1.684 4.708 0.781 3.219,-1.451 4.785 0.813 3.188,-1.215 4.85 0.844 3.156,-0.975 4.904 0.875 3.125,-0.734 4.946 0.906 3.094,-0.49 4.976 0.937 3.062,-0.245 4.994 0.969 3.031,3.062e-16 5 1 3,0.245 4.994 1.031 2.969,0.49 4.976 1.062 2.938,0.734 4.946 1.094 2.906,0.975 4.904 1.125 2.875,1.215 4.85 1.156 2.844,1.451 4.785 1.188 2.812,1.684 4.708 1.219 2.781,1.913 4.619 1.2
 5 2.75,2.138 4.52 1.281 2.719,2.357 4.41 1.312 2.688,2.571 4.289 1.344 2.656,2.778 4.157 1.375 2.625,2.978 4.016 1.406 2.594,3.172 3.865 1.438 2.562,3.358 3.705 1.469 2.531,3.536 3.536 1.5 2.5,3.705 3.358 1.531 2.469,3.865 3.172 1.562 2.438,4.016 2.978 1.594 2.406,4.157 2.778 1.625 2.375,4.289 2.571 1.656 2.344,4.41 2.357 1.688 2.312,4.52 2.138 1.719 2.281,4.619 1.913 1.75 2.25,4.708 1.684 1.781 2.219,4.785 1.451 1.812 2.188,4.85 1.215 1.844 2.156,4.904 0.975 1.875 2.125,4.946 0.734 1.906 2.094,4.976 0.49 1.938 2.062,4.994 0.245 1.969 2.031,5 0 2 2,5.006 -0.245 2.031 1.969,5.024 -0.49 2.062 1.938,5.054 -0.734 2.094 1.906,5.096 -0.975 2.125 1.875,5.15 -1.215 2.156 1.844,5.215 -1.451 2.188 1.812,5.292 -1.684 2.219 1.781,5.381 -1.913 2.25 1.75,5.48 -2.138 2.281 1.719,5.59 -2.357 2.312 1.688,5.711 -2.571 2.344 1.656,5.843 -2.778 2.375 1.625,5.984 -2.978 2.406 1.594,6.135 -3.172 2.438 1.562,6.295 -3.358 2.469 1.531,6.464 -3.536 2.5 1.5,6.642 -3.705 2.531 1.469,6.828 -3.865 2.562 1.438,7.
 022 -4.016 2.594 1.406,7.222 -4.157 2.625 1.375,7.429 -4.289 2.656 1.344,7.643 -4.41 2.688 1.312,7.862 -4.52 2.719 1.281,8.087 -4.619 2.75 1.25,8.316 -4.708 2.781 1.219,8.549 -4.785 2.812 1.188,8.785 -4.85 2.844 1.156,9.025 -4.904 2.875 1.125,9.266 -4.946 2.906 1.094,9.51 -4.976 2.938 1.062,9.755 -4.994 2.969 1.031,10 -5 3 1,10.245 -4.994 3.031 0.969,10.49 -4.976 3.062 0.938,10.734 -4.946 3.094 0.906,10.975 -4.904 3.125 0.875,11.215 -4.85 3.156 0.844,11.451 -4.785 3.188 0.813,11.684 -4.708 3.219 0.781,11.913 -4.619 3.25 0.75,12.138 -4.52 3.281 0.719,12.357 -4.41 3.312 0.688,12.571 -4.289 3.344 0.656,12.778 -4.157 3.375 0.625,12.978 -4.016 3.406 0.594,13.172 -3.865 3.437 0.563,13.358 -3.705 3.469 0.531,13.536 -3.536 3.5 0.5,13.705 -3.358 3.531 0.469,13.865 -3.172 3.563 0.437,14.016 -2.978 3.594 0.406,14.157 -2.778 3.625 0.375,14.289 -2.571 3.656 0.344,14.41 -2.357 3.688 0.313,14.52 -2.138 3.719 0.281,14.619 -1.913 3.75 0.25,14.708 -1.684 3.781 0.219,14.785 -1.451 3.812 0.187,14.85 -1
 .215 3.844 0.156,14.904 -0.975 3.875 0.125,14.946 -0.734 3.906 0.094,14.976 -0.49 3.938 0.062,14.994 -0.245 3.969 0.031,15 0 4 0)
+ST_CurveToLine01|LINESTRING(0 0,0 0.1,0.01 0.2,0.02 0.29,0.04 0.39,0.06 0.49,0.09 0.58,0.12 0.67,0.15 0.77,0.19 0.86,0.24 0.94,0.28 1.03,0.34 1.11,0.39 1.19,0.45 1.27,0.52 1.34,0.59 1.41)
+ST_CurveToLine01|LINESTRING(-5 0,-4.99 0.25,-4.98 0.49,-4.95 0.73,-4.9 0.98,-4.85 1.21,-4.78 1.45,-4.71 1.68,-4.62 1.91,-4.52 2.14,-4.41 2.36,-4.29 2.57,-4.16 2.78,-4.02 2.98,-3.87 3.17,-3.7 3.36,-3.54 3.54,-3.36 3.7,-3.17 3.87,-2.98 4.02,-2.78 4.16,-2.57 4.29,-2.36 4.41,-2.14 4.52,-1.91 4.62,-1.68 4.71,-1.45 4.78,-1.21 4.85,-0.98 4.9,-0.73 4.95,-0.49 4.98,-0.25 4.99,3.06e-16 5,0.25 4.99,0.49 4.98,0.73 4.95,0.98 4.9,1.21 4.85,1.45 4.78,1.68 4.71,1.91 4.62,2.14 4.52,2.36 4.41,2.57 4.29,2.78 4.16,2.98 4.02,3.17 3.87,3.36 3.7,3.54 3.54,3.7 3.36,3.87 3.17,4.02 2.98,4.16 2.78,4.29 2.57,4.41 2.36,4.52 2.14,4.62 1.91,4.71 1.68,4.78 1.45,4.85 1.21,4.9 0.98,4.95 0.73,4.98 0.49,4.99 0.25,5 0,5.01 -0.25,5.02 -0.49,5.05 -0.73,5.1 -0.98,5.15 -1.21,5.22 -1.45,5.29 -1.68,5.38 -1.91,5.48 -2.14,5.59 -2.36,5.71 -2.57,5.84 -2.78,5.98 -2.98,6.13 -3.17,6.3 -3.36,6.46 -3.54,6.64 -3.7,6.83 -3.87,7.02 -4.02,7.22 -4.16,7.43 -4.29,7.64 -4.41,7.86 -4.52,8.09 -4.62,8.32 -4.71,8.55 -4.78,8.79 -4.85,9.02 -4.9,9.
 27 -4.95,9.51 -4.98,9.75 -4.99,10 -5,10.25 -4.99,10.49 -4.98,10.73 -4.95,10.98 -4.9,11.21 -4.85,11.45 -4.78,11.68 -4.71,11.91 -4.62,12.14 -4.52,12.36 -4.41,12.57 -4.29,12.78 -4.16,12.98 -4.02,13.17 -3.87,13.36 -3.7,13.54 -3.54,13.7 -3.36,13.87 -3.17,14.02 -2.98,14.16 -2.78,14.29 -2.57,14.41 -2.36,14.52 -2.14,14.62 -1.91,14.71 -1.68,14.78 -1.45,14.85 -1.21,14.9 -0.98,14.95 -0.73,14.98 -0.49,14.99 -0.25,15 0)
+ST_CurveToLine02|LINESTRING M (0 0 0,0 0.1 -0.19,0.01 0.2 -0.38,0.02 0.29 -0.56,0.04 0.39 -0.75,0.06 0.49 -0.94,0.09 0.58 -1.12,0.12 0.67 -1.31,0.15 0.77 -1.5,0.19 0.86 -1.69,0.24 0.94 -1.88,0.28 1.03 -1.75,0.34 1.11 -1,0.39 1.19 -0.25,0.45 1.27 0.5,0.52 1.34 1.25,0.59 1.41 2)
+ST_CurveToLine02|LINESTRING M (-5 0 4,-4.99 0.25 3.97,-4.98 0.49 3.94,-4.95 0.73 3.91,-4.9 0.98 3.88,-4.85 1.21 3.84,-4.78 1.45 3.81,-4.71 1.68 3.78,-4.62 1.91 3.75,-4.52 2.14 3.72,-4.41 2.36 3.69,-4.29 2.57 3.66,-4.16 2.78 3.62,-4.02 2.98 3.59,-3.87 3.17 3.56,-3.7 3.36 3.53,-3.54 3.54 3.5,-3.36 3.7 3.47,-3.17 3.87 3.44,-2.98 4.02 3.41,-2.78 4.16 3.38,-2.57 4.29 3.34,-2.36 4.41 3.31,-2.14 4.52 3.28,-1.91 4.62 3.25,-1.68 4.71 3.22,-1.45 4.78 3.19,-1.21 4.85 3.16,-0.98 4.9 3.12,-0.73 4.95 3.09,-0.49 4.98 3.06,-0.25 4.99 3.03,3.06e-16 5 3,0.25 4.99 2.97,0.49 4.98 2.94,0.73 4.95 2.91,0.98 4.9 2.88,1.21 4.85 2.84,1.45 4.78 2.81,1.68 4.71 2.78,1.91 4.62 2.75,2.14 4.52 2.72,2.36 4.41 2.69,2.57 4.29 2.66,2.78 4.16 2.62,2.98 4.02 2.59,3.17 3.87 2.56,3.36 3.7 2.53,3.54 3.54 2.5,3.7 3.36 2.47,3.87 3.17 2.44,4.02 2.98 2.41,4.16 2.78 2.38,4.29 2.57 2.34,4.41 2.36 2.31,4.52 2.14 2.28,4.62 1.91 2.25,4.71 1.68 2.22,4.78 1.45 2.19,4.85 1.21 2.16,4.9 0.98 2.12,4.95 0.73 2.09,4.98 0.49 2.06,4.99 0.25
 2.03,5 0 2,5.01 -0.25 1.97,5.02 -0.49 1.94,5.05 -0.73 1.91,5.1 -0.98 1.87,5.15 -1.21 1.84,5.22 -1.45 1.81,5.29 -1.68 1.78,5.38 -1.91 1.75,5.48 -2.14 1.72,5.59 -2.36 1.69,5.71 -2.57 1.66,5.84 -2.78 1.63,5.98 -2.98 1.59,6.13 -3.17 1.56,6.3 -3.36 1.53,6.46 -3.54 1.5,6.64 -3.7 1.47,6.83 -3.87 1.44,7.02 -4.02 1.41,7.22 -4.16 1.38,7.43 -4.29 1.34,7.64 -4.41 1.31,7.86 -4.52 1.28,8.09 -4.62 1.25,8.32 -4.71 1.22,8.55 -4.78 1.19,8.79 -4.85 1.16,9.02 -4.9 1.12,9.27 -4.95 1.09,9.51 -4.98 1.06,9.75 -4.99 1.03,10 -5 1,10.25 -4.99 0.97,10.49 -4.98 0.94,10.73 -4.95 0.91,10.98 -4.9 0.87,11.21 -4.85 0.84,11.45 -4.78 0.81,11.68 -4.71 0.78,11.91 -4.62 0.75,12.14 -4.52 0.72,12.36 -4.41 0.69,12.57 -4.29 0.66,12.78 -4.16 0.63,12.98 -4.02 0.59,13.17 -3.87 0.56,13.36 -3.7 0.53,13.54 -3.54 0.5,13.7 -3.36 0.47,13.87 -3.17 0.44,14.02 -2.98 0.41,14.16 -2.78 0.37,14.29 -2.57 0.34,14.41 -2.36 0.31,14.52 -2.14 0.28,14.62 -1.91 0.25,14.71 -1.68 0.22,14.78 -1.45 0.19,14.85 -1.21 0.16,14.9 -0.98 0.13,14.95 -0.73 0.09
 ,14.98 -0.49 0.06,14.99 -0.25 0.03,15 0 0)
+ST_CurveToLine03|LINESTRING Z (0 0 0,0 0.1 0.28,0.01 0.2 0.56,0.02 0.29 0.84,0.04 0.39 1.13,0.06 0.49 1.41,0.09 0.58 1.69,0.12 0.67 1.97,0.15 0.77 2.25,0.19 0.86 2.53,0.24 0.94 2.81,0.28 1.03 2.87,0.34 1.11 2.5,0.39 1.19 2.12,0.45 1.27 1.75,0.52 1.34 1.37,0.59 1.41 1)
+ST_CurveToLine03|LINESTRING Z (-5 0 0,-4.99 0.25 0.03,-4.98 0.49 0.06,-4.95 0.73 0.09,-4.9 0.98 0.13,-4.85 1.21 0.16,-4.78 1.45 0.19,-4.71 1.68 0.22,-4.62 1.91 0.25,-4.52 2.14 0.28,-4.41 2.36 0.31,-4.29 2.57 0.34,-4.16 2.78 0.37,-4.02 2.98 0.41,-3.87 3.17 0.44,-3.7 3.36 0.47,-3.54 3.54 0.5,-3.36 3.7 0.53,-3.17 3.87 0.56,-2.98 4.02 0.59,-2.78 4.16 0.63,-2.57 4.29 0.66,-2.36 4.41 0.69,-2.14 4.52 0.72,-1.91 4.62 0.75,-1.68 4.71 0.78,-1.45 4.78 0.81,-1.21 4.85 0.84,-0.98 4.9 0.88,-0.73 4.95 0.91,-0.49 4.98 0.94,-0.25 4.99 0.97,3.06e-16 5 1,0.25 4.99 1.03,0.49 4.98 1.06,0.73 4.95 1.09,0.98 4.9 1.12,1.21 4.85 1.16,1.45 4.78 1.19,1.68 4.71 1.22,1.91 4.62 1.25,2.14 4.52 1.28,2.36 4.41 1.31,2.57 4.29 1.34,2.78 4.16 1.37,2.98 4.02 1.41,3.17 3.87 1.44,3.36 3.7 1.47,3.54 3.54 1.5,3.7 3.36 1.53,3.87 3.17 1.56,4.02 2.98 1.59,4.16 2.78 1.62,4.29 2.57 1.66,4.41 2.36 1.69,4.52 2.14 1.72,4.62 1.91 1.75,4.71 1.68 1.78,4.78 1.45 1.81,4.85 1.21 1.84,4.9 0.98 1.88,4.95 0.73 1.91,4.98 0.49 1.94,4.99 0.25
 1.97,5 0 2,5.01 -0.25 2.03,5.02 -0.49 2.06,5.05 -0.73 2.09,5.1 -0.98 2.12,5.15 -1.21 2.16,5.22 -1.45 2.19,5.29 -1.68 2.22,5.38 -1.91 2.25,5.48 -2.14 2.28,5.59 -2.36 2.31,5.71 -2.57 2.34,5.84 -2.78 2.38,5.98 -2.98 2.41,6.13 -3.17 2.44,6.3 -3.36 2.47,6.46 -3.54 2.5,6.64 -3.7 2.53,6.83 -3.87 2.56,7.02 -4.02 2.59,7.22 -4.16 2.62,7.43 -4.29 2.66,7.64 -4.41 2.69,7.86 -4.52 2.72,8.09 -4.62 2.75,8.32 -4.71 2.78,8.55 -4.78 2.81,8.79 -4.85 2.84,9.02 -4.9 2.88,9.27 -4.95 2.91,9.51 -4.98 2.94,9.75 -4.99 2.97,10 -5 3,10.25 -4.99 3.03,10.49 -4.98 3.06,10.73 -4.95 3.09,10.98 -4.9 3.12,11.21 -4.85 3.16,11.45 -4.78 3.19,11.68 -4.71 3.22,11.91 -4.62 3.25,12.14 -4.52 3.28,12.36 -4.41 3.31,12.57 -4.29 3.34,12.78 -4.16 3.38,12.98 -4.02 3.41,13.17 -3.87 3.44,13.36 -3.7 3.47,13.54 -3.54 3.5,13.7 -3.36 3.53,13.87 -3.17 3.56,14.02 -2.98 3.59,14.16 -2.78 3.62,14.29 -2.57 3.66,14.41 -2.36 3.69,14.52 -2.14 3.72,14.62 -1.91 3.75,14.71 -1.68 3.78,14.78 -1.45 3.81,14.85 -1.21 3.84,14.9 -0.98 3.88,14.95 -0.73 3.91
 ,14.98 -0.49 3.94,14.99 -0.25 3.97,15 0 4)
+ST_CurveToLine04|LINESTRING ZM (0 0 0 0,0 0.1 0.28 -0.19,0.01 0.2 0.56 -0.38,0.02 0.29 0.84 -0.56,0.04 0.39 1.13 -0.75,0.06 0.49 1.41 -0.94,0.09 0.58 1.69 -1.12,0.12 0.67 1.97 -1.31,0.15 0.77 2.25 -1.5,0.19 0.86 2.53 -1.69,0.24 0.94 2.81 -1.88,0.28 1.03 2.87 -1.75,0.34 1.11 2.5 -1,0.39 1.19 2.12 -0.25,0.45 1.27 1.75 0.5,0.52 1.34 1.37 1.25,0.59 1.41 1 2)
+ST_CurveToLine04|LINESTRING ZM (-5 0 0 4,-4.99 0.25 0.03 3.97,-4.98 0.49 0.06 3.94,-4.95 0.73 0.09 3.91,-4.9 0.98 0.13 3.88,-4.85 1.21 0.16 3.84,-4.78 1.45 0.19 3.81,-4.71 1.68 0.22 3.78,-4.62 1.91 0.25 3.75,-4.52 2.14 0.28 3.72,-4.41 2.36 0.31 3.69,-4.29 2.57 0.34 3.66,-4.16 2.78 0.37 3.62,-4.02 2.98 0.41 3.59,-3.87 3.17 0.44 3.56,-3.7 3.36 0.47 3.53,-3.54 3.54 0.5 3.5,-3.36 3.7 0.53 3.47,-3.17 3.87 0.56 3.44,-2.98 4.02 0.59 3.41,-2.78 4.16 0.63 3.38,-2.57 4.29 0.66 3.34,-2.36 4.41 0.69 3.31,-2.14 4.52 0.72 3.28,-1.91 4.62 0.75 3.25,-1.68 4.71 0.78 3.22,-1.45 4.78 0.81 3.19,-1.21 4.85 0.84 3.16,-0.98 4.9 0.88 3.12,-0.73 4.95 0.91 3.09,-0.49 4.98 0.94 3.06,-0.25 4.99 0.97 3.03,3.06e-16 5 1 3,0.25 4.99 1.03 2.97,0.49 4.98 1.06 2.94,0.73 4.95 1.09 2.91,0.98 4.9 1.12 2.88,1.21 4.85 1.16 2.84,1.45 4.78 1.19 2.81,1.68 4.71 1.22 2.78,1.91 4.62 1.25 2.75,2.14 4.52 1.28 2.72,2.36 4.41 1.31 2.69,2.57 4.29 1.34 2.66,2.78 4.16 1.37 2.62,2.98 4.02 1.41 2.59,3.17 3.87 1.44 2.56,3.36 3.7 1.47 2.5
 3,3.54 3.54 1.5 2.5,3.7 3.36 1.53 2.47,3.87 3.17 1.56 2.44,4.02 2.98 1.59 2.41,4.16 2.78 1.62 2.38,4.29 2.57 1.66 2.34,4.41 2.36 1.69 2.31,4.52 2.14 1.72 2.28,4.62 1.91 1.75 2.25,4.71 1.68 1.78 2.22,4.78 1.45 1.81 2.19,4.85 1.21 1.84 2.16,4.9 0.98 1.88 2.12,4.95 0.73 1.91 2.09,4.98 0.49 1.94 2.06,4.99 0.25 1.97 2.03,5 0 2 2,5.01 -0.25 2.03 1.97,5.02 -0.49 2.06 1.94,5.05 -0.73 2.09 1.91,5.1 -0.98 2.12 1.87,5.15 -1.21 2.16 1.84,5.22 -1.45 2.19 1.81,5.29 -1.68 2.22 1.78,5.38 -1.91 2.25 1.75,5.48 -2.14 2.28 1.72,5.59 -2.36 2.31 1.69,5.71 -2.57 2.34 1.66,5.84 -2.78 2.38 1.63,5.98 -2.98 2.41 1.59,6.13 -3.17 2.44 1.56,6.3 -3.36 2.47 1.53,6.46 -3.54 2.5 1.5,6.64 -3.7 2.53 1.47,6.83 -3.87 2.56 1.44,7.02 -4.02 2.59 1.41,7.22 -4.16 2.62 1.38,7.43 -4.29 2.66 1.34,7.64 -4.41 2.69 1.31,7.86 -4.52 2.72 1.28,8.09 -4.62 2.75 1.25,8.32 -4.71 2.78 1.22,8.55 -4.78 2.81 1.19,8.79 -4.85 2.84 1.16,9.02 -4.9 2.88 1.12,9.27 -4.95 2.91 1.09,9.51 -4.98 2.94 1.06,9.75 -4.99 2.97 1.03,10 -5 3 1,10.25 -4.99 3.03
  0.97,10.49 -4.98 3.06 0.94,10.73 -4.95 3.09 0.91,10.98 -4.9 3.12 0.87,11.21 -4.85 3.16 0.84,11.45 -4.78 3.19 0.81,11.68 -4.71 3.22 0.78,11.91 -4.62 3.25 0.75,12.14 -4.52 3.28 0.72,12.36 -4.41 3.31 0.69,12.57 -4.29 3.34 0.66,12.78 -4.16 3.38 0.63,12.98 -4.02 3.41 0.59,13.17 -3.87 3.44 0.56,13.36 -3.7 3.47 0.53,13.54 -3.54 3.5 0.5,13.7 -3.36 3.53 0.47,13.87 -3.17 3.56 0.44,14.02 -2.98 3.59 0.41,14.16 -2.78 3.62 0.37,14.29 -2.57 3.66 0.34,14.41 -2.36 3.69 0.31,14.52 -2.14 3.72 0.28,14.62 -1.91 3.75 0.25,14.71 -1.68 3.78 0.22,14.78 -1.45 3.81 0.19,14.85 -1.21 3.84 0.16,14.9 -0.98 3.88 0.13,14.95 -0.73 3.91 0.09,14.98 -0.49 3.94 0.06,14.99 -0.25 3.97 0.03,15 0 4 0)
 isValid01|t
 isValid01|t
 isValid02|t
Summary of changes:
 liblwgeom/gbox.c                            |  4 ++--
 liblwgeom/gserialized.c                     |  2 +-
 liblwgeom/lwalgorithm.c                     |  4 ++--
 liblwgeom/lwgeodetic.c                      |  2 +-
 liblwgeom/lwout_geojson.c                   |  2 +-
 postgis/gserialized_estimate.c              |  2 +-
 postgis/gserialized_gist_2d.c               |  2 +-
 postgis/lwgeom_in_gml.c                     |  4 ++--
 postgis/lwgeom_in_kml.c                     |  2 --
 regress/core/sql-mm-circularstring.sql      |  8 ++++----
 regress/core/sql-mm-circularstring_expected | 16 ++++++++--------
 11 files changed, 23 insertions(+), 25 deletions(-)
hooks/post-receive
