[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-33-g626556b
Thu Jul 30 08:52:49 PDT 2020
the project "PostGIS".
       via  626556b359e39ef94f24f14e28621860b866283a (commit)
      from  90cee0e81cf28f3c46aac77a964e3208ded79ccd (commit)
revisions in full, below.
commit 626556b359e39ef94f24f14e28621860b866283a
Author: Regina Obe <lr at pcorp.us>
Date:   Thu Jul 30 11:52:28 2020 -0400
    Put note that both ST_Split and ST_WrapX require GEOS
diff --git a/doc/reference_processing.xml b/doc/reference_processing.xml
index e62a9cb..205a872 100644
--- a/doc/reference_processing.xml
+++ b/doc/reference_processing.xml
@@ -2831,8 +2831,7 @@ This is useful to "recenter" long-lat input to have features
 of interest not spawned from one side to the other.
     </para></note>
-        <para>Availability: 2.3.0</para>
+        <para>Availability: 2.3.0 requires GEOS</para>
         <para>&Z_support;</para>
 <!-- TODO: check these
         <para>&P_support;</para>
@@ -3233,7 +3232,7 @@ LINESTRING M (5 2 3.40282346638529e+38,3 8 29,6 20 1.5,7 25 49.5,10 10 3.4028234
             should always yield the original geometry.
             </para>
-            <para>Availability: 2.0.0</para>
+            <para>Availability: 2.0.0 requires GEOS</para>
             <para>Enhanced: 2.2.0 support for splitting a line by a multiline, a multipoint or (multi)polygon boundary was introduced.</para>
             <para>Enhanced: 2.5.0 support for splitting a polygon by a multiline was introduced.</para>
Summary of changes:
 doc/reference_processing.xml | 5 ++---
 1 file changed, 2 insertions(+), 3 deletions(-)
hooks/post-receive
