[postgis-tickets] [PostGIS] #4733: MakeValid segfault GEOS 3.9 master (debbie bot)
trac at osgeo.org
Fri Jul 31 03:04:57 PDT 2020
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS GEOS
Component: buildbots | Version: master
Resolution: | Keywords: geos
Changes (by robe):
* keywords: => geos
* milestone: PostGIS 3.1.0 => PostGIS GEOS
Comment:
I'm guessing it must be this geos commit at fault then -
https://git.osgeo.org/gitea/geos/geos/commit/4ef6f82756cfc3d6bf6a85c698b0bb01b2176fff
It's better now but test is still failing
05:38:00 Test: test_geos_makevalid ...[cu_geos.c:150]
05:38:00 Expected: GEOMETRYCOLLECTION(POLYGON((92114.014
463463.469,92115.51207431706 463462.206937429,92115.512
463462.207,92127.546 463452.075,92117.173 463439.755,92133.675
463425.942,92122.136 463412.82600000006,92092.377 463437.77,92114.014
463463.469)),MULTIPOINT(92115.51207431706 463462.2069374289,92122.136
463412.826))
05:38:00 Obtained: NULL
05:38:00 FAILED
05:38:00 1. cu_geos.c:150 - CU_FAIL()
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4733#comment:3>
